My 85 c4 vetes transmission started shifting between 3rd and OD.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Sounds like the selectors could be on the way out in the transmission. I suggest taking it to a transmission specialist.
Posted on Nov 26, 2013
Transmission started changing gears in OD 85 vete 5.7
Nov 25, 2013 | Computers & Internet
76 Cadillac automatic won't shift from 3rd to 4th
For Automatic transmission problem,Check the list of help links below.click the link below:----Automatic transmission troubleshooting:----
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Automatic transmission shift lever issues?-------
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
AUTOMATIC TRANSMISSION FLUID LEVEL? --
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
AUTOMATIC TRANSMISSION FLUID AND FILTER?
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
Transmission fault light on car dash?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
Transmission shifting problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
****** wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Automatic transmission will not go into reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
This will help.
Thanks.
Feb 12, 2012 | 1976 Cadillac Deville
Transmision starts out in 1st shifts to 2nd then third but will not shift into overdrive , but once it reaches 3rd gear ,it stays there when you come to a stop . after that it will only shift manually...
Sounds like your transmission is in limp mode. This is a fault mode in which the transmission either loses electrical power or the PCM deactivates all of the electronics. The transmission will default to max line pressure. The driver will have Reverse and 3rd, with manual 2nd available by putting the gearshift in 2 or 1 (doesn't matter). 1st, 4th, and TCC lockup will not be available. It will not hurt the car to drive it like this for short periods, but use manual 2nd to get the car moving, and be aware that the trans will generate more heat than normal while operating in limp-home mode due to increased torque converter slippage during 2nd gear starts and no lockup in 3rd gear.
The other from what you described, trans shifts 2nd to 3rd by itself in D or OD and locks the converter : ShiftA solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Thank you for using fixya and have your Safari scanned for the DTC codes that would indicate what issues your transmission is having to put you in to limp mode.
Sep 21, 2010 | 1994 GMC Safari
What does it mean that my 66 pony has a green dot trany?
the '65/'66 C4, was known as the "Green Dot" C4 & has a different shift pattern to the '67/later C4's.
So your C4 tranny is the green dot which is an UPGRADED option. A better tranny better gears and stronger parts and what not, there was also the white dot tranny that was the cheaper or less performance transmission. As far as i understand the white dot was available for better fuel consumption HAHAHA which no one really cared about in 66 anyways.
In '65/'66 it was something like this:
P - Park
R - Reverse
N - Nuetral
White Dot - Starts in 2nd, automatically shifts to 3rd
Green Dot - Starts in 1st, automatically shifts to 2nd and 3rd
Apr 18, 2010 | 1966 Ford Mustang
Only runs in 1st and 2nd gear and reverse.
Trans shifts into gear harshly, car feels sluggish off the line
, No 1st, 4th or TCC lockup available, Manual 2nd, 3rd and Reverse are only available gears, CEL is on: Transmission is either in limp-home mode or has lost electrical power. If there are lots of error codes in the PCM, check the under hood fuse that powers the transmission, and if it pops again, look for a short in that circuit like an O2 sensor harness touching exhaust. Otherwise, check PCM codes for a particular fault in the transmission causing the PCM to put it in limp-home mode.
No 1st or 4th available; trans shifts 2nd to 3rd by itself in D or OD and locks the converter : ShiftA solenoid failed. Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Car goes into gear but feels very sluggish like the brakes are dragging, but it will roll easily (starts out in 4th gear), you manually shift to 2 to get it moving, once it's moving you put it back in OD and the car shifts 3rd to 4th on its own and locks the converter at the appropriate time: ShiftB solenoid failed: Easy fix in the pan. Or a wiring problem from PCM to trans.. or PCM.
Dec 14, 2009 | 2006 Hummer H3
4L60E Shifts fine in 1st, 2nd, & 3rd but will not shift into OD
The EMC detected and problem so it's in limp mode, As long as it's in limp mode the 4th and OD will not activate. Take care not to burn up the transmission by running it hard while your in the limp mode.
Your going to have to get the truck scanned to clear any codes and why there are DTC codes. Auto Zone scan for free and most auto shops charge $10.00 to $20.00 to scan sine they want the business.
If you want to clear the codes your self you can put the ignition to the run position and pull the ECM (Batt) fuse out for 20 sec and place it back in then start the truck. It may stall but let it, just start it again and this would have cleared all the DTC code history.
The transmission should be running fine unless there is a problem and the service engine light will be on again and you'll be in limp mode still with an updated DTC in the ECM.
Good luck and hope this helps.
May 26, 2009 | 1996 Chevrolet K1500
1989 pontiac bonneville transmission will not go into 3rd or OD
the kick down cable could me off but more than likly the trans in shot/ no good
Feb 13, 2009 | 1989 Pontiac Bonneville
1984 caprice transmission wont shift into 3rd or overdrive
you car probably has the 700 r4 transmission they are famous for this kind of failure, time for a transmission rebuild........
Oct 24, 2008 | 1984 Chevrolet Caprice
Transmission
You can retrieve the codes through the OBD dianostic connector with a scanner.
Oct 11, 2008 | 1995 Jeep Grand Cherokee
Computers & Internet Logo
David Payne
David Payne
