Fujitsu Lifebook AH532
WOn't boot. Been in recovery and utility mode for an hour or so with message "Preparing now. Please wait for a while."
MNfisherman
  • 11896 Answers
SOURCE: my Fujitsu LIFEBOOK N3430 Notebook does not boot
Remove the battery for 5 minutes, press and hold the power button for 3 seconds, wait 5 more minutes, put battery back in and see if everything works now. It should. This usually works.
If it doesn't, you may have a faulty memory chip causing you the black screen.
You can try removing one at a time to see if it corrects the problem.
Lastly, the ribbon cable from screen to motherboard can become piched and non responsive.
Posted on Nov 25, 2009
LCPLgeek
  • 125 Answers
SOURCE: Fujitsu Lifebook N6470 will not boot
Hi there, try hitting F8 in the start up sequence, and go under last good configuration. Try hitting that, and may fix it. If not, you need to bring it in to a computer shop to repair.
Posted on Jan 18, 2010
Sunnyrepairs
  • 808 Answers
SOURCE: How do I update the BIOS for my Fujitsu Lifebook
U can chek this link for bios update http://www.pc-ap.fujitsu.com/support/manual_lb.html Or http://driverscollection.com/?H=C2210&By=Fujitsu
Posted on Jul 28, 2010
  • 8909 Answers
SOURCE: i have a toshiba recovery
I would say that was too long and there is a problem somewhere. I would run CHKDSK/F straight away to clear any disk errors and try again.
Hope that helps.
Posted on Feb 24, 2011
  • 68 Answers
SOURCE: my samsung will not boot and recovery mode just
That means that theres a program corructed in your Laptop that even recovery mode will not work, you need to reformat and setup it again for cleaner and fresher running.
Good luck and don't forget my rating, thanks...
Posted on Apr 04, 2011
My fujitsu wont work without its charger and when the charger is plugged in it wont actually charge the battery itself.
Probably your battery is dead because if there would have been any problem with your charger port, you cant be able to use it on plugged mode. Buy a new battery ASAP.
Dec 29, 2014 | Fujitsu LifeBook AH532 Notebook
When system is start key f2 and f12 not work
It is tricky to get the timing right. Press F2 repatedly just before the boot screen.
Nov 30, 2014 | Fujitsu LifeBook AH532 Notebook
I want to find AH532 lifebook user manua
here you are :)
http://globalsp.ts.fujitsu.com/dmsp/Publications/public/ds-LIFEBOOK-AH532.pdf
Jan 28, 2014 | Fujitsu LifeBook AH532 Notebook
Factory restore
1. Turn on or reboot your system. When the Fujitsu logo appears, press the [F12] key.
2. From the Boot Menu, that appears, check whether the <Recovery and Utility> option is present.
If it is not present, it means that the utility must be used from the disc.
Proceed to "Running Recovery and Utility from the Bootable Disc" , if <Recovery and Utility> is unavailable.
http://support.fujitsupc.com/CS/Portal/s...
Dec 22, 2013 | Fujitsu LifeBook AH530 NoteBook
My fujitsu lifebook s6010 will not start in normal mode after system restore
Run the Check Disk Utility
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Jun 10, 2012 | Fujitsu LIFEBOOK S6010 Notebook
Problems with first use setup
LOL, ok does this lifebook have a CD Drive on it? If so you can try the Check Disk Utility.
But before trying the check disk utility, just turn it off and power it back up, it just might work.
If not try the check disk utility.
May 02, 2012 | Fujitsu LifeBook AH531
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
