Question about Sony Grand WEGA KDF55E2000 55" Projection HDTV
I cant get a picture to display after just replacing the lamp
I just bought a new lamp for my tv i cant get a picture and the red light indicator flashes three times. what am i doing wrong
  • gutterman24k May 07, 2009
    Its inplace and in the lock position
  • 10,594 Answers
After replacement of lamp, please put back Lamp Cover securely as TV shows error of lamp cover (3 times blink)
Posted on May 07, 2009
  • Shahid Electronics
    Shahid Electronics May 07, 2009
    There is a tiny switch that pressed by lamp cover, that switch tells system control that lamp cover is placed properly.
    Make sure that lamp cover is pressing that safety switch, it its open, system control will not power up TV and gives an error of 3 blinks.
    Also double check that lamp is placed securely in its position.
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
When i turn my tv on it goes of straight away and keeps flashing red can you help
After replacing the lame, the lamp time should reset. Otherwise, TV won't start. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you check the site in Timeslide option, which can be selected from the dropdown list at the top left side of the display window, it will make search easy.
Apr 22, 2013 | Sony Lamp For The Kdf E50A12U Rear...
Why does my tv turn on for a little bit but cant see the screen and a red light flashes
Tv red LED lights indication front of the bazel screen flashing are most common problems.When was the last time the projection lamp was replaced in this tv?The lamp in the tv now,is it in the the tv about 1 1/2 or 2 years and tv on watches about 4 or 5 hours a day in used?The projection lamp life are over.Require a new projection lamp.
Aug 03, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
Tv wont turn on
The lamp life span is over,need a new projection lamp replacement.This tv lamp has not been replaced at least 1 1/2 or 2 years?The tv lamp in the tv now,tv on an used at least 4 or 5 hours a day too.
Jun 29, 2010 | Hitachi 42V710 42" Rear Projection HDTV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Red lamp light on Mitsubishi DLP 65" WD-C657
Lamp is always First to go unless power surge gets it Call Mats for Lamp 1-800-628-1118 or Find one on E-Bay got mine there for 85.00 free shipping.
Sep 21, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have sound and no picture. Red light on in front of tv indicating lamp. Can be fixed w/o repairman?
Yes the Lamp can fail within that time frame. Much of it depends on how many hours the set is running. Most Lamps have a 3000 to 5000 hrs of life. But with any Halogen style Lamp, this is not written in stone.
Hope this helps,
Skyassoc
May 11, 2009 | Mitsubishi WD-65833 65" HDTV
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF55E2000 55" Projection HDTV Logo
294 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
