Question about Seville Classics MSC10166 Tower Fan
Bad motor Seville Classics Model 10187
The fan doesn't work. All modes turn the LED lights but fan doesn't work. Looks like bad motor. Where to buy replacemnt>
3 Suggested Answers
SOURCE: seville classics model 10166
how to clean and take apart
Posted on May 23, 2008
SOURCE: Seville Classics MSC10166 Tower Fan
Possible Solution :
Taken From :
http://www.fixya.com/support/t193631-am_trying_fix_oscillating_tower_fan
"Most fan motors for fan over running have an internal overload. once it trips, it will not reset. it is a solid state device. it looks like a flat device or a small bullet device. if you've figured out how to take the fan apart, you could just remove the device and connect the two wires together and the fan will run. you won't have any protection on the motor however. the windings run warm, but if the bearings run dry the motor will slow down and the windings will get hot. this is the reason for the overlaod device - protection. its your call what you want to have."
Posted on Aug 22, 2008
My seville classics tower fan no longer oscillates - how can that be fixed?
Throw it away and buy a new one for 20 box at Wal-Mart. It's as simple as that cause to fix it, it'll take a new machine which cost twice the price. I think they made it to last one summer max. Friendly yours
Jul 01, 2014 | Seville Classics MSC10166 Tower Fan
Why blades are not rotating or throwing air?
some of these have a expansion pin that holds the fan blade assembly onto the shaft, this may have fallen out or ? broke,,,
May 13, 2014 | Seville Classics MSC10166 Tower Fan
The fan has power and will rotate, but no air is being blown out. any troubleshooting tips or is it a goner?
Try to free up top fan bearing, it is under switch cover. Pry cover with small screw driver, insert screw driver blade in access hole and pry, top fan bearing is held by two screws, remove, clean and lubricate with oil or grease. It works!
Sep 29, 2010 | Seville Classics MSC10166 Tower Fan
Running hotter than normal looks like it started leaking bad under motor now
There is well-established procedure for trouble shouting the over heating.
Does the car overheat in driving mode?
Yes.
Are you losing coolant?
No. Check water pump (including belt) and thermostat.
If yes make a radiator compression test. You might have a bad cylinder head gasket.
The car doesn’t overheat in driving mode, but overheat in idle.
Does the fan runs?
No.
Check the fan assembly for a bad motor, loose fan blades, or bad connector.
Check the codes for a bad temperature sensor.
Check cooling fan relay and fuse.
If this isn’t enough to solve problem, then send the car at dealer for a “check and advice”.
Aug 24, 2010 | 2002 Chevrolet Malibu
My fan makes a loud squealing noise upon starting
open the tower if you can and check if some obstruction of wire is there or not. caution turn of the pwr before doing that . if no obstruction then the fan has to be replaced. open the fan carefully take it to best buy or wallmart and get it replaced.
it is possible for the older computer that the fan goes bad or moves faster than its normal speed . its a common problem with all brands of computer.
May 07, 2010 | Seville Classics MSC10166 Tower Fan
The fan fuse 1.5A/250V is keep blown up as soon as
Unplug the fan.
Open it up carefully.
Look at the the wiring for damage or shorts.
Check that the fan impeller is free to turn.
If all of the above is OK then possibly the motor has gone? If so then it will probably be cheeper to buy a new one.
Jul 02, 2009 | Seville Classics MSC10166 Tower Fan
To take apart: see solution #1 (not a complete disassemble but helps)
Aug 15, 2008 | Seville Classics MSC10166 Tower Fan
Possible Solution :
Taken From :
Aug 14, 2008 | Seville Classics MSC10166 Tower Fan
Seville classics model 10166
bottom stand was broken. how to get new bottom part.
Dec 06, 2007 | Seville Classics MSC10166 Tower Fan
Seville Classics MSC10166 Tower Fan Logo
64 people viewed this question
Top Seville Classics Dryers Experts
Dan Webster
Dan Webster
Are you a Seville Classics Dryer Expert? Answer questions, earn points and help others
