Question about Panasonic Televison & Video
What to do when panasonic tv sparks at the outlet it is pluged into
    Top Expert:
  • Panasonic Master
  • 75,581 Answers
If TV do now work at all, and the spark occurs when you plug it into the wall power outlet, surely there should be some short circuit inside any circuit board, and you should contact any service technician to rectify the problem. google.com/+GopakumarGopalan
Posted on Nov 25, 2013
When tv is unpluged and pluged back in it wont power on and no lights blinck
Sure the plug is getting power from wall outlet? If power is there you might want to check out the power supply board first for issues.
Oct 13, 2015 | Televison & Video
Modle number tc-p42x5
The sudden drop in operating voltage may have caused the power supply to fail.
Mar 05, 2014 | Panasonic VIERA Televison & Video
Pluged t.v in and saw spark and shut off. will not turn back on.
Hello vitto616,
This happened to one of my tv but may not be the same for you. Seems like the tv got surged. Look to see if a power light comes on. If not try different power outlets as well. If nothing then yes probably got surged. Unfortunately you may need to contact your manufacture or any local tv repair techs. Just make sure you don't get ripped off by them and see if there is anyone that will do a diagnosis for free. I hope this helps, give me your feedback if it doesn't. Good luck.
- Joe
Aug 31, 2011 | Vizio VW26L 26 in. LCD TV
I Have No Audio I Have Regular Standard Cable and Its pluged To Tv And We Bought A Audio Cable Plug And Also Pluged it To The Cable box and Tv And still do not have audio
Hi:
Check you menu options and make sure under audio menu the speakers are not set to off posistion. Also reset the cable box by unpluging from the wall outlet and wait for about 1 minute and pluging it back in. Make sure box or television is not in mute mode.
Dec 08, 2009 | HP PL4260N 42 in. Plasma HDTV
Pops power supply fuse when I plug it in
Check to fuse box to see if the fuse is working properly. Next, see if the TV "pops" the power supply when pluged into a different outlet in a different power supply area. If the TV works without poping the fuse, the fuse with the original outlet needs replacing. If both outlets "pop", either the electrical system needs checking. Or if this is a new problem that started when you first tried the TV, the TV could be wanting more power than the electrical system will allow. Check the power requiremnets in the TV manual.
Jul 28, 2009 | Recoton Advent Advent TS2066A TV
Wii got pluged to a 220 volt outlet
I'm going to go ahead and say it probably fried the Wii. I would maybe try getting a new adapter either way if it's at reasonable cost and see if it works again though.
Jul 19, 2009 | Nintendo Wii Console
Sony color rear video projector tv, videoscope, 1994
first things check the outlet for power.
chech and make shure your surge protector is in the on posishion.
try pluging sumthig else in wer the tv will be pluging into.
at least you know if its the outlet or the tv set.
ok now press the power button on the tv set not the remote.
dose it work.
ok problem solved.
if it did not work you can have a tech see if the internal fusse is good or bad.
i will need the model number to look futher into tech repair.
I will do this for you if you need it done.
thanks.
daniel
Jan 13, 2009 | Sony KP-51WS510 51" Rear Projection...
ILO TELEVISION
Make sure that the outlet you pluged it into does not require a switch. Try pluging it into other outlets. If this doesnt work you may need to consider a new television. Otherwise you can call the manufacture and explain your problem with them. If you require any more assictance you may email me at SDZAKKMF@charter.net.
Feb 24, 2008 | iLO 2600 Television
27 inch Panasonic TAU tv won't turn on, then sparks when you unplug and replug it in
You first need to rplace the outlet if it sparks where the surge protector is plugged in as it should not spark for any reason. then you need to make sure thast its not the outlet causing your problem by running an long extensition corn or moving the set to a differant outlet.
Sep 11, 2006 | Panasonic CT-32G11 32" TV
3year old Panasonic ct-32sx12f dead?
Sure, Why not? It is worth the effort. If the set is 'dead', it is the easiest to repair.Only 'tampered' sets pose problems. It could be a simple blown Fuse, or the Power Regulator IC. This should not cost you more than $100-150 as Technician charges + 15-20$ for spares. It could also be a defective Horizontal Outut Transistor and short cicuiterd FBT, (tho' it seems remote), but if yes, add another $100. definitely worth calling a professional techie
Aug 22, 2006 | Panasonic CT-32SX12 32" TV
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
