Question about Philips 9195XL Electric Shaver
How to replace the battery in a Phillips 9195XL shaver
I replaced the battery with a replacement Li-Ion battery and now the shaver doesn't work. I put the old battery back in and it still doesn't work.
SOURCE: replace batteries on phillishave HQ7780
You neet torx T9 , quite cheap.
Posted on Dec 21, 2007
SOURCE: Electric Shaver will not charge
There are 4 small philips head screws deeply recessed on the rear of the razor. Unscrew these and the back half of the case just lifts off. Unsolder the battery leads and fit new battery pack.
Posted on Mar 21, 2009
brector3
  • 1602 Answers
SOURCE: I have Phillips 6640 shaver & the retaining
You will find parts to fit your shaver at shaveroutlet.com. See links below
http://shaveroutlet.com/norelco-philips-reflex-head-holder-p-714.html
http://shaveroutlet.com/norelco-philips-reflex-actionreflex-plus-head-retainer-p-321.html
Posted on Jan 28, 2010
brector3
  • 1602 Answers
SOURCE: How to open Philips shaver 7110X to replace batery
Remove 2 screws on the back to remove outer cover. Once removed, you will see 3 more screws that must be removed on the inner cover. Remove screws and cover to get to the battery.
When installing the battery, I suggest that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs
You will find a battery for your shaver at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Posted on Feb 12, 2010
brector3
  • 1602 Answers
SOURCE: I HAVE A PHILLIPS SHAVER
The batteries are soldered into place. You will need a soldering iron and electrical solder to replace them. Unsolder the old batteries from the circuit board and solder in the new batteries
If you are not able to do this repair yourself, shaveroutlet.com can do it for you. See information at the link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Posted on Jan 21, 2011
Testimonial: "THANK YOU"
I lost my li-ion battery and when i use a batteries the camera does not work what do i do
Look on-line for li-ion replacement batteries for your camera model. Once you have the battery number, you can look for local suppliers or mail-order companies from which you can buy a replacement.
Apr 24, 2017 | Cameras
Tip
Samsung SLB-11A Battery
Batteries are very important, here has the best quality products and considerate service
Battery Type: Li-ion
Voltage: 3.80V
Capacity: 1130mAh
Color: Black
Dimension: 43.40 x 31.70 x 7.40 mm
Product Type: Replacement Battery (Brand New)
Condition: New, 1 year warranty!
Weight: 49.61 g
Inventory: In Stock
1. New Generic Samsung i8 Compatible Li-Ion Battery
2. Extra power for your Samsung i8 camera or camcorder
3. High capacity rechargeable Li-ion Battery with premium cells
4. Absolutely no memory effect so you can charge battery at anytime
5. Usually Ships Your Samsung i8 Battery in 24 Hours, 12 months warranty.
on Sep 21, 2010 | Cameras
Tip
Sony NP-BG1 battery|Cheap NP-BG1 digital camera batteries
New,1100mAh, 3.60V, Li-ion, Sony Battery Pack
  • Chemistry : Li-ion
  • Voltage : 3.60V
  • Capacity : 1100mAh
  • Dimension : 41.90 x 35.40 x 8.10 mm
  • Color : Black
  • Brand : Sony Digital Camcera Battery
Replacement SONY NP-BG1 Digital Camera Batteries, Li-ion SONY NP-BG1 Battery Pack
on Jul 20, 2010 | Cameras
My Braun7570 battery is not able to recharge and I have to repalce the new one. As this modle is old one almost 5 years ago, I start to worry about where I can buy the new battery and how to repalce it by...
You can not use lithium battery in your shaver as the charging system is not compatible. You can purchase compatible batteries for your shaver at shaveroutlet.com. See link below for the item and installation videos
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Jul 23, 2011 | Braun Syncro 7570 Electric Shaver
The battery on my Remington MB70 trimmer is no longer hold a charge. Can the battery be changed to perhaps an Li-ion variety?
The charging system in your trimmer is not designed for lithium ion batteries. Installing a lithium ion battery could cause fire and/or personal injury. You should always use the same type battery that came in the shaver originally
Oct 07, 2010 | Remington MB-70 Beard Trimmer
Logitech MX1000 Laser Cordless Mouse, I replaced the li-ion battery with a NiMh AAA battery pack, soldered in the board that was on the old battery and used it for a week before the battery pack needed...
Li-Ion battery and NiMh battery have completely different charging requirements! Li-Ion battery has much stricter charging requirement and the regulator is normally design to trickle charge at 0.1 Current rating @ 4.2V and then completely shut down.
WARNING: if you use a Ni-Mh charger on a Li-Ion battery, then it will erupt and even explode and catch fire!
Bottom line is that the rescued Li-ion regulator is not designed for your Ni-Mh pack and you will never get a full charge with it and you will need a completely different regulator board: you are better off putting in a suitably sized Li-Ion battery with inbuilt regulator but with higher current rating if possible.
Hope it helps! Let me know how you go.
Nov 14, 2009 | Logitech MX1000 Laser Cordless...
Battery replacement? laptop no longer mobile
Compatible system batteries
Description Part Number Service FRU Part Number Additional information Li-Ion battery (6 cell) 40Y8315 92P1184 Sanyo 92P1186 Sony Li-Ion battery (9 cell) 40Y8317 92P1188 Sanyo c.gif c.gif
Aug 06, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Philips 9195XL Electric Shaver Logo
76 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
