Question about Karcher K2.26 Electric Power Washer
Where can I repair my Karcher Electric power washer in Muar Johor
Water leaking from under the machine
    Top Expert:
  • Karcher Master
  • 34,193 Answers
Try contacing Karcher for a repair source.
Posted on Nov 25, 2013
Coldcut
  • 1554 Answers
SOURCE: karcher pressure washer leaking oil
all 4 stroke engines have oil, and 2 stroke can have a oil mixer reservoir to mix with engine gas or to lube the chains , gears, pumps.
If yours is 4 stroke as likely then the oil may be leaking at the seals to the main. (bad news)
Pressure wash it (lol) and locate the leak,
to speed up the leak you can pump some compressed air into the engine (be creative)
Posted on Apr 13, 2008
  • 92 Answers
SOURCE: Karcher pressure washer won't start
Dear ralph_birtwi,
Most pressure washers when their gun is released, the machine stops automaticaly. This is done ny means of a control valve. When the gun is closed...pressure is built and the control valve moves and switches a micro switch off. In your case the micro switch is still closed in off position. Now this happens if a machine is left and stored with pressure in it., This control valve could get jammed and leaving the micro switch in off position. It could also stay in off position by sticking, due to incorrect chemical.
So the control valve or even called spill valve, must be renewed.
Sometimes a little lubrication with the right type of silicon grease will get the control valve working again. This job is sometimes delicate and better done by a qualified technician.
Regards,
fulltech.
Posted on Apr 12, 2009
SOURCE: my karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Posted on Apr 25, 2009
  • 21 Answers
SOURCE: Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
Posted on May 29, 2009
delgriffith
  • 97 Answers
SOURCE: karcher 3300 G water leak out rear of unit from white plasticplug
if its just a plug, remove it with an allen key and wrap a couple layers of teflon tape around it. That should stop, or at least slow down any leaks that are coming out of the threads.
Posted on Jun 19, 2009
My K2.91 pressure washer has an oil leak.Is this repairable.
It is repairable but it may cost you near the same amount of money to repair it compared to buying a new machine. Also with a new machine you then will have a 12 month warranty which is better to have as you may fix your machine and then something else may go wrong.
The problem sounds like the seals in the pump need changing so if you ask your local karcher dealer/service center they should give you a cost.
Jan 06, 2011 | Karcher K2.26 Electric Power Washer
Pump leaking from base
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement is about $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt to prove it,Karcher will replace the whole Pressure washer under warranty.
Jul 06, 2010 | Karcher K2.26 Electric Power Washer
Karcher K2.26M water leak
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement K2.26* Part # 97501760 is $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt,Karcher will replace the whole Pressure washer under warranty.
Jul 03, 2010 | Karcher K2.26 Electric Power Washer
Water is leaking from under the chrome piece inside my Karcher 3.68m pressure washer. Hose intake and outlet look good. Any sugeestions.
Plastic Pump Manifold is cracked.
Can be replace at a local Karcher Service Center, or if you are mechanically handy. Replacement Manifold Complete, is available from www.karcher.com.
If it is under 1 year old, and under warranty Karcher will replace if you have a Receipt proof of purchase.
Jun 08, 2010 | Karcher K3.68MR Factory Refurbished 1,800...
I left my electric karcher pressure washer it in the shed during the winter and they tell me that the housing and the safety valve need replacing. Can I repair it myself? They want 180.00 to fix it which...
Is there a leak from the bottom ?
If so then there is a crack in the Manifold housing. A New Manifold Complete Replacement is approx. $61.03, can be purchased from Karcher.
If under 1 year old, and you can find a receipt, Karcher will replace the whole Pressure washer under warranty.
Apr 29, 2010 | Karcher PSI Electric Pressure Washer
Karcher k 3.99 does not pause correct
Is there a water leaking from the bottom ? If so then there maybe is a small crack in the Pump Plastic Manifold Housing. A New Manifold Complete Replacement is approx. $61.03 from Karcher, if you are mechanically inclined.
Mar 16, 2010 | Karcher K 5.85 M Electric Pressure Washer
When connected to water and working water
open case and find sorce of leak probaly busted plastic line of fitting
Mar 15, 2010 | Karcher K2.26 Electric Power Washer
Karcher K 3.97M electric presuure washer cycles on/off.
Hi;
It has an internal water leak or a seal or valve is leaking air. These machines are warrantied for 2 years and that is about all you can expect from them. Having it repaired professionally would cost about 75% the price of a new machine. If you are handy enough to get into it yourself, e-mail me and I will send you a diagram. (firehead@rogers.com) Part prices are expensive in Canada but not bad in the US. I don't know about other countries.
Sep 09, 2009 | Karcher K2.26 Electric Power Washer
Karcher K3.91 compressor run for a few seconds every 10-15 second
They have a problem. I removed both valves and lubed with lithium grease as I was told. Unit is now working for how long who knowes.
May 18, 2009 | Karcher PSI Electric Pressure Washer
Karcher K2.26 Electric Power Washer Logo
95 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
