Question about Sony MDR-XD200 Consumer Headphones
Wire repair - Sony MDR-XD200 Consumer Headphones
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Putting a 2006 fisher plow on a 2007 Chevrolet no low beam head lites how to switch wires to fix
The Internet has a large number of web sites
where you can buy service manuals and schematics
from bookstores, publishers, and other collectors.
Factory Auto manuals
http://www.factoryautomanuals.com/
search for : factory service auto repair manuals
Repair Service auto Manuals
where to buy Factory Service Auto Repair manuals
http://www.repairservicemanuals.com/
the largest collection of Automotive Repair Service
Manuals and Owners Guides on the internet. Our
database currently holds over 54,000 entries dating
back from 1940 to more recent 2011.
Chilton Repair and Service Manuals
http://www.chilton.cengage.com/
Haynes Repair and Service Manuals
http://www.haynes.com/
Jan 14, 2016 | Chevrolet Cars & Trucks
Can burned out wiring be repaired on outdoor ac unit ?
it all depends on what wiring burned up of course .but find the cause of it before trying to repair
Sep 11, 2015 | Heating & Cooling
How to Replace a p1355 on a 2000 volkswagen new beetle
Is this for a ignition coil output stage open circuit? If so you need to rerun the ground wire. Just but the wire close enough to the coil that you can still get to the wire and splice another wire to it. Just splice a wire to the brown wire and run the rest of the wire to a ground lug under the battery. You will need to remove the battery and the tray. Also when you hook the battery back up make sure the key is on. This will reset alarm and radio. Remember, you are grounding the coil so the wire should go from the coil to ground. Hope this helps
May 29, 2014 | 2000 Volkswagen Beetle
I have a 2002 mitsubishi, galant e.s. cruise quit working with running lights turned on.
Check the cruise control fuse. Do a visual check of all wiring relating to the cruise control system. Look for melted insulation, broken wires, burned wires and twisted wires without a wire connector. Repair any wire damage with the splicing and wire connecting tool and the right size wire connector for the wire you are repairing.
Aug 30, 2013 | 2007 Dodge Ram Truck
Chevy cavalier - rear brake lights don't work. The center rear brake light does work as well as all other lights. Replaced the bulbs and fuse - no luck. From what I have been told, the turn signal...
Stop Lamp Circuit Description
The STOP HAZ fuse in the IP junction block supplies battery positive voltage to the normally open stop lamp switch. When the driver presses the brake pedal, the switch contacts close and battery positive voltage is supplied to the center mounted stop lamp (CHMSL) and both left and right stop lamp assemblies. The left stop lamp is grounded at G304 and the right stop lamp is grounded at G304.
Check the ground ! Testing an not guessing is the way to find the problem . Do you know how to test automotive electrical systems an circuits using a DVOM - digital volt ohm meter ? How to use an read a wiring diagram to pin point testing areas in a wiring harness ?
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
How to Use Multimeter to Troubleshoot Common Problems
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Stop Lamps Inoperative
Step
Action
Yes
No
Inspect the 20 Amp STOP HAZ fuse.
Is the STOP HAZ fuse open?
YES - Go to Step 11
NO - Go to Step 3
Use a test lamp in order to backprobe connector C1 of the brake switch connector between terminal A and ground. Refer to Circuit Testing in Wiring Systems.
Does the test lamp light?
YES - Go to Step 4
NO - Go to Step 5
With the brake switch closed, Test for positive battery voltage at terminal B of connector C1. Refer to Circuit Testing in Wiring Systems.
Is voltage present?
YES - Go to Step 6
NO - Go to Step 7
5
Repair the open or short to ground in the Fuse Output-Battery between the fuse block and the brake switch. Refer to Wiring Repairs in Wiring Systems.
Is the repair complete?
YES - System OK
6
Use a test lamp in order to backprobe the turn/hazard headlamp switch assembly connector C2 terminal A and ground.
Depress the brake pedal.
YES - Go to Step 8
NO - Go to Step 9
7
Inspect the adjustment of the brake switch. If the adjustment is correct, replace the brake switch.
YES - System OK
8
Replace the turn/hazard headlamp switch assembly.
System OK
9
Repair the open in Stop Lamp Switch Output between the brake switch and the turn/hazard headlamp switch assembly. Refer to Wiring Repairs in Wiring Systems.
System OK
10
With brake switch open test terminal A of the brake switch for continuity to ground. Refer to Circuit Testing in Wiring Systems.
Is ground present?
YES - Go to Step 11
NO - Go to Step 12
11
Repair short to ground in Fuse Output-Battery Circuit. Refer to Wiring Repairs in Wiring Systems.
Is repair complete?
System OK
12
Test the Stop Lamp Switch Output Circuit for continuity to ground. Refer to Circuit Testing in Wiring Systems.
Is ground present?
YES - Go to Step 13
NO - Go to Step 14
13
Repair short to ground in the Stop Lamp Switch Output Circuit. Refer to Wiring Repairs in Wiring Systems.
Is repair complete?
System OK
14
Test terminals F,G,B and C on the Hazard Warning Switch for continuity to ground. Refer to Circuit Testing in Wiring Systems.
Is ground present?
Go to Step 15
15
Repair short to ground in suspect CKT. Refer to Wiring Repairs in Wiring Systems.
Is repair complete?
System OK
Jul 03, 2017 | 2000 Chevrolet Cavalier
2003 Mitsubishi Outlander power window repair. I
just repair the broken wire with heatshrink[after youve respliced it] and check operation of motor.if it works,make sure wiring is securely cabletied out of the way,when reassembled
Sep 12, 2010 | 2003 Mitsubishi Outlander
Power window failure, motor replaced, switches replaced no resolve?
Then I would suspect that there is a broken wire or wires, and you should find them inside of the drivers door weather boot that runs from the door to the body of the vehicle, and it contains the wiring for the door electronics. I have repaired wiring in that location an un-countable amount of times, and if you repair any wires be sure that you do solder them together well and do not use wire connectors, that is if you want the repair to be a permanent one. You might also have to repair wiring inside of the passenger side weather boot as well.
Jun 08, 2010 | 2003 Ford Explorer
I have a sharper image ionic breeze professional series and paid a preety penny too. one of the wires inside rusted and broke, it lights up but no breeze is comming from it and the green light doesnt come...
If you're referring to one of the ionizer wires (wire that has beads on it to clean the wires) then unfortunately, I'm afraid the unit can't be repaired. As Sharper Image has no authorized repair centers or replacement parts. If you're referring to wiring in the base of the machine, then a repair could be affected by either cleaning off the wire ends and reattaching them with a small piece of wire or soldering the broken wire back to the unit itself. Sadly, many of us (myself included) spent a lot of money on these units and the only place I've found parts is a website called http://breezerepair.com/parts.html (not an authorized repair center) but of the parts they have carry, they don't have the wire you referred to. Sorry to be the bearer of bad news.
Nov 07, 2009 | Sharper Image Professional Plus Ionic...
Sony MDR-XD200 Consumer Headphones Logo
24 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
