Question about Pool & Spa
Valve Setting - Pool & Spa
  • 3,103 Answers
For what???
Posted on Jan 11, 2014
Whirlpool Ultimate care 2 washer doesnt fill on start or rinse or spray in spin all other functions fine whats wrong?
The water valve has a 'Hot' and 'Cold' side, make sure to test if the unit will fill at a different water temp. setting, as a Cold/Cold setting will paralyze the machine if the Cold side of the water valve has failed... Some newer machines have temperature sensors attached to the valve and will not fill if the sensor fails... Washing Machine Water Inlet Valve 285805
May 23, 2016 | Whirlpool Washing Machines
What is the valve lash setting
There are lots of good videos to learn about valve lash setting on YouTube here:
Measuring Valve Clearance Lash
I hope this helps you!
Mar 31, 2016 | Measuring Tools & Sensors
How to adjust tappet clearaNCE OF FORD RANGER 12 VALVE
Unless the is a modified engine, there is no setting on the valve clearance. It has hydraulic valve lifters and they don't require any setting of the valve tappets.If they are making noise when it is running the you have a bad valve lifter. Unless you can get some kind of lubricant to add to the oil that will clean the lifters, you may have to install new ones.
May 31, 2015 | Ford Ranger Cars & Trucks
My D55141 heavy duty 2gal (7.6L) 150 psi max builds pressure up to around 150 releases pop off valve then keeps running, what causes this problem?
The pressure switch is either out of adjustment or has failed. The compressor should shut off at a much lower pressure than the safety valve (~100 psi)
Nov 20, 2014 | Air Tools & Compressors
I have model SF114PXSB2 and want to know can I turn the lowest heat setting to a lower setting on the range top. Right now the lowest setting is still too high.
This should be a gas range according to #. Sounds like burner valve worn out.
You should replace your burner valve for that burner. I don' t believe they are adjustable.
$50 part at Sears.
Feedback appreciated
Aug 03, 2011 | Whirlpool Kitchen Ranges
While vacuuming my swimming pool and the valve setting is on filter, the dirty water is returning into the pool. Ive just changed a brand new spider gasket, replaced #20 silica sand. Did i miss anything...
Try changing the setting on your pool filters control valve to waste. This will bypass the filter and vacuum directly to waste. If this works, it could be a problem with the filter's "filter" setting and you may need to service or replace your control valve.
Feb 15, 2011 | Hayward SAND FILTER, PRO SERIES
Compressor stops then leaks down to low setting
That little copper line is an unloading line, to bleed compressed air out of the compressor head so that the motor can more easily start the compressor. Pressor switch should be threadded into top of air tank, and the unloading valve is built into the side of the switch. When the tank reaches the high pressure setting the switch disconnects power to the motor and opens the unloading valve at the same time. The unloading valve should be connected to the compressor discharge line through a check valve with an unloading valve port upstream of the check valve. These valves are usually threaded into the top of the air tank as well. Sounds to me like your valve was leaking and someone bypassed it.
Sep 14, 2009 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
Kenmore 90 series washer no hot water
CHeck to see if the screens in the water valve are plugged. If not the hot water side of the valve went out. Replace the water valve and it will fix both the hot and cold problem.
Nov 18, 2008 | Washing Machines
Pool & Spa Logo
13 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
