Question about GE Monogram ZISS480DRSS Stainless Steel
GE monogram refrigerator too cold
Refrigerator side set at 38 but actual temperature 26 or lower. had repairman here that changed out two temperature probes in main compartment and that did not help. seems colder in lower food compartment where you can chill or defrost food...16 degrees there.
  • GE Master
  • 15,628 Answers
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Posted on Nov 25, 2013
Maytag317
  • 1136 Answers
SOURCE: ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
Posted on May 30, 2009
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
  • 323 Answers
SOURCE: vegetable and meat draws freezing everything temp@16 deg. f.
Turn your thermostat down. If all the rest of the food was even 45 degrees, it would be okay. The vetable and meat drawers will always be colder, so you set the level for the rest of the fridge at what is tolerable.
Posted on May 14, 2009
SOURCE: GE Monogram will not accept freezer/fridge
My ge monogram gets warm every year this time of year. All of a sudden no ice and everything defrosts. We vacuumed vents up top last yr and it got cold again. What the heck???
Posted on Aug 01, 2009
SOURCE: freezer defrosting at will; refrigerator side uneven temperatures
Sound like it's going into showroom mode that the same problem we had, by unplugging it for awhile and then plugging it back in usually works if not this what we were told.
Sounds like you have bad thermistors ( # 4 and/or # 5 ) .To access these parts , you will have to remove the inside rear wall of the freezer . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also
Posted on Dec 16, 2009
GE monogram buildin refrigerator - climate control drawer cannot hold the temperature as set for meat. It always shows at 47F.
sounds like the damper door down there is not opening also the fan down may not be coming on to bring temp down to 32.
Sep 17, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
Ge monogram not cooling properly
It doesn't cool
  1. Condenser coils
Make sure you dust off the condenser coils to prevent dust build up and overheating due to it overworking. Simply unplug and use a long coil cleaning brush to get rid of debris.
  1. Check seals
If your refrigerator door seal is broken, warm air is pushing its way inside the unit, thus causing it to not cool properly. Prevent this from happening by replacing your seal and keeping the cool air inside.
  1. Temperature controls
Ensure that your thermostat is set correctly, usually 38-40 degrees Fahrenheit.
  1. Defective condenser fan
When this fan is defective, cold air is prevented from flowing through the vents. It may require replacement.
  1. Compressor issues
Check if there are clicking sounds coming from the compressor as it tries to start. If there is a clicking, it is one of only two options, either the start capacitor or a bad compressor. A start capacitor is fairly inexpensive whereas a sealed system repair on the compressor is very expensive and often not cost effective. Refrigerator Repair Help Troubleshooting and Parts
Aug 18, 2014 | GE Monogram Side by Side Refrigerator
GE ZIS420NX Refrigerator temp control not effective, food is freezing
you have a few things that could be wrong, a bad thermistor, a bad air defuser, or a bad main board. changing the thermistor could fix it but if not, i would call a pro that order the right part. lots of varibles.
Apr 08, 2012 | General Electric GE ZIS420NX (25.4 cu....
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram freezer side working but refrigerator side is not.
Did you clean the condenser?  Is the unit FULLY defrosted?   Defrost fully!!!!!!
Did he check the amount of gas in the unit?  If your unit has low gas...it is in need of more.  R12 is expensive.
Check gas level:  Shut unit for at least one hour.  View compressor.  Several pipes...we're looking at the largest.  Start the unit.  This pipe will begin to frost.  If it does not clear to dry, ice or wet...stays frosted...it is low.  Get the repair guy back ... but ask how much he'll charge first.
Dec 12, 2008 | Refrigerators
GE monogram
I have a Ge Monogram 42" side by side. The temp on both side are not cold enought and I tried to change the temperature setting to colder but it's went right back. All the food started to thawed. PLease help. Thanks
Jun 18, 2008 | Refrigerators
GE monogram side by side no ice water dispensed not cold
To actuate the ice maker pull the arm down and it is in the on position.
The water is actually cooled in the refrigerator section. However it is not designed for a continuous flow. It takes time for the heat to be removed between each water draw.
If your refrigerator temperature is not cold enough it will affect the water temperature also. Check the refrigerator compartment temperature with a thermometer.
May 16, 2008 | GE PSS26MGS Side by Side Refrigerator
GE Monogram ZISS480DRSS Stainless Steel Logo
209 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
