Question about Frigidaire GLRS237ZA Side by Side Refrigerator
Frigidare side by side Gallery fridge
Ice maker does not work i have an ice build up in the back at the bottom and water on the floor.I do not know if they come standart with a water filter if so would this be what is causing the problem. The fridge is about 12 years old the ice maker has not worked for the last year. The water dispenser still works.
  • 291 Answers
Sounds like you water is spilling out instead of going into ice maker... check the inlet spout for ice or other blockage
Posted on Oct 11, 2007
SOURCE:
Constant build up of water at the bottom of the fridge - what can I do to solve the problem
Check if the pipe or hose that supply water for the ice maker is not leaking. Look in the back of the fridge at the bottom part to see if frost is building up on the pipe then melting and putting water on the floor. Build up of frost on the line indicates low on freon or something is wrong with the fridge. It will still get cold but the frost will melt and put water on the floor.
Jun 26, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
Frigidaire Gallery Professionaly series broken ice maker
If you hook up the water to the fridge, that means you connected the water line to the 'Water Inlet Valve' of the machine. There should be a two wire harness connected to the water valve back. Look for that....
But please note following...
Some water valves in fridges are complicated with one harness for water dispenser line valve and another harness for ice maker water line.
Also seeing a disconnected wire harness does not mean it is for the water valve. May be most likely. But be careful sometime there are test wire harness for technicians to get power readings for components.
Oct 25, 2017 | Frigidaire Professional Side By Side...
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have ice build up at the bottom of my frigidare freezer compart
Sounds like the defrost condensate drain behind the rear panel inside the freezer is frozen over. You will need to unplug the refrigerator and remove the panel. Defrost with a hair dryer and pour warm water into the tray that collects the defrost condensate and takes it down to a pan below your refrigerator to be heated and put back into the air inside your home. If for some reason it is not ice blocking the opening you will need to use a wet and dry vacuum cleaner to try to dislodge whatever is blocking the flow. Let me know what you find, Thanks, Sea Breeze
Jul 21, 2009 | Frigidaire FRS26H5AS Side by Side...
Water from the icemaker shoots down the back of the freezer
are you sure the water comming from the icemaker or the defrost drain line clogged
Apr 07, 2009 | Refrigerators
There is a water leak inside the freezer
You need to remove the bottom two baskets, or more to make space. Using a hairdryer, defrost the back area. You should be able to locate a drain hole in the center below the freezer coils. This drain hole is connected on the outside to a drainpipe which has a p trap and often gets blocked up. You need to force water down the drain hole. You can use a turkey baster or similar type of plunger filled with water. Once you have cleared the blockage pour hot water till it runs freely. Hope this sorts your problem, don't forget to rate me.
Mar 11, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water on the floor left side of refrigerator
well theres a couple of things it will do at that frequency.defrost cycles and may be making ice.defrost water goes down a drain.ice maker fills thru tubes.also the defrost drain could be blocked you would see ice on frezeer floor.you have to us your fingers and trace out those places to find leak
Dec 31, 2008 | Frigidaire FRS23F4C Side by Side...
Leaky fridge
This is defrost condensate.  You have a hose going to a tray below the box that is blocked.  Rod it out with soft wire or similar.  Clean the condenser while you're in there!
Nov 23, 2008 | Refrigerators
Frigidaire GLRS237ZA Side by Side Refrigerator Logo
158 people viewed this question
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
