Question about Car Audio & Video
2001 Subaru outback stuck in valet mode
I've tried the recommended fix, I.e., hold down unlock with driver door open. Doesn't work. Anything else? Manual locking and unlocking very inconvenient!
  • 2039 Answers
SOURCE: 1998 subaru legacy outback rear hatch
put the kee in the lock turn the kee and hold it there in the same time use the screw driver and pull the lacht down thanks for using fixya pierre
Posted on Feb 10, 2008
SOURCE: 2001 Subaru Outback security code won't stop flashing !
im a service manager at a Subaru dealer. The security system is in valet mode. Open the drivers door, with the drivers door open hold the small unlock button on the remote and keep holding it until the light stops flashing.
Posted on Dec 06, 2008
  • 124 Answers
SOURCE: driver door lock stuck
if you get it open spray the latch with PB blaster. do the same with other doors
Posted on Mar 11, 2009
SOURCE: how do i unlock my gas tank on volvo 2001 s80
open the trunk and pull the carpet away from the side on hte r and you should be able to manually retract the locking mechanism from the door.
Posted on Mar 16, 2009
jeffbvegas1
  • 520 Answers
SOURCE: 2003 Subaru Legacy Outback: Driver's door lock brocken, tab feels
alot of times a lock smith has "slim jimmed" the car before and that subsequently can break clips or knock off lock rods to the latch. not too hard to fix if you can get the door open in order to remove inner door panel accessing that latch and rods...if the door wont open i have used a very long ,slendy screwdriver and poked down the window opening to mannually open the door latch ...it takes a little time and some gentle poking to hit the lever on that door latch
Posted on Jun 23, 2009
2001 Subaru outback limited security light flashing rapidly!!?
Reset the system by removing both battery terminals
Hold the positive and negative together for 30 seconds
The. Reinstall both terminals
The system will re learn for the next 10 miles or so
If it happens again to the light
We will have to try another approach
Best of luck
Feb 22, 2015 | 2001 Subaru Outback
Subaru outback
Try:
http://www.cars101.com/subaru/keyless.html
Apr 10, 2014 | 2004 Subaru Outback
The driver's door of my Subaru outback won't unlock
It appears that the plastic clip on the door controls has broken . need to remove the door cover or trim card and repair/ replace clips . not verry expensive to buy
Nov 26, 2012 | 2001 Subaru Legacy Outback
I have a Subaru Outback. The security light behind the steering wheel is blinking twice, which I guess means it is in valet mode. The solution doesn't work though (hold down unlock button with driver's...
I think you have to have the key in the ignition, and set to "ON" with the driver door open and holding the unlock button down for several seconds. At least that works on my Forester.
Jan 08, 2010 | 2001 Subaru Outback
Security system status indicator light is flashing two times. It will not go out.
the keyless entry is in valet mode,i believe you must hold the unlock button down with the drivers door open to switch between valet and regular operation,this info is also in the owners manual good luck!
Jul 09, 2009 | 2000 Subaru Outback
'99 subaru legacy gets 2 flashes from LED and
try opening door and holding unlock button ,it sounds like its in valet mode
Jun 15, 2009 | 2001 Subaru Outback
Driver door lock stuck
Mar 11, 2009 | 2004 Subaru Outback
Jan 04, 2009 | 2003 Subaru Outback
Security system not working as it used to
i read this on the subaru tech bulletin page
i had the same problem - apparently i had inadvertently put the system into "valet" mode
to get back to normal, unlock with remote - open drivers door - hold down the unlock button on your remote for 2-3 sec - the flashing light will go out and your system should be back to normal
it's too bad the manual doesn't supply information about activating and deactivating "valet" mode
good luck
Oct 13, 2008 | 2001 Subaru Forester
Apr 09, 2008 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
