Question about Watches
Cannot open back to replace battery - Watches
    Top Expert:
  • Watches Master
  • 34,733 Answers
Some watches require special tools to open. You may have to refer battery replacement to a jeweler.
Posted on Nov 25, 2013
Battery size for emporio armani ceramic ladies watch
  • To determine battery type: open back
  • Locate battery holder and identify type. Note battery mounting
  • Place opened watch in plastic bag to keep it dust-free while you obtain a replacement battery
  • Remove watch from plastic bag and install new battery
  • Check operation
  • Install back
Finally, reset watch as necessary
Aug 28, 2016 | Emporio Armani Watches
What size battery does a diesel dz7247 take?
Remove back
Find battery location and identify type. Note how it is installed.
You might as well leave the watch open while you get a replacement battery. I put mine in a snack/sandwich bag while it is open.
Install the replacement battery, check operation, and install the back
Aug 11, 2016 | Watches
My Timex Indeglo watch does not have any means of opening the watch so I can replace the battery. It kept perfect time when it ran, but now it does not run at all. Is it supposed to be a disposable watch...
  • If you don't already know what size battery you need, you can find this information on the back plate of your watch. Once you have your replacement battery, you will need to open the back of the watch to gain access to the battery compartment. Depending on the watch, the back plate will either screw off or be attached by a few small screws. If attached with screws, you will need a set of precision screwdrivers such as a jewelry or eyeglass kit.
    Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
  • Mar 02, 2011 | Timex Indiglo Analog Watch
    How do you open the back of the Timex Ironkids wristwatch in order to replace the battery? It has four small screws and part of the plastic wristband keeps me from prying off the back to replace the...
    mcdevito75 here, Those 4 screws hold the back onto your Timex. Do not try to pry off the back cover, rather you"ll need jewlers screwdrivers to un--screw that back cover to replace the battery.
    Jul 31, 2010 | Timex IRONKIDS 70491 wristwatch
    Battery replacement
    do you mean you want to replace the battery for your watch?
    This isn't a difficult task to carry out. Simply get a small flat screw driver, use the screw driver to open the back cover of the watch, then you will see the battery of your watch. Remove the battery and replace with a new batter, cover back the watch and that's all.
    Note that you will apply force with the screw driver when you are trying to open the back cover of the watch.
    Good luck.
    May 18, 2010 | Casio Atomic Timekeeping Waveceptor Watch...
    How do you open the back of a raymond weil men's
    I suggest you take it to a watch shop. DIY battery replacement is not as easy as it seems.
    Frequently there are cries for help after a battery has been replaced and the watch no longer works!
    Feb 10, 2010 | Raymond Weil Parsifal W1 watch
    Dead battery, how do I open?
    I believe a local watch repairer will replace the battery for around 5$ that should include the battery, depends on the person.
    Generally the battery is replaced by opening the back cover of the watch, in some cases special tools might be required.
    the details of the battery read on top the one currently inside it.
    Jan 30, 2010 | Watches
    After changing the battery nothing can be changed, no function possible and"open" remains written on the display, the type of the battery is clt 1616
    The battery is CTL 1616 and I had the same occurance when I opened up my model Casio model 3043. I needed to use the battery to test my model 2767 and find out if a new battery would bring it back to life (yes, it still lives). After replacing the battey back into my 3043, I jumped the (ac) to (-) and at first the watch would indicate all was well but then it would revert back to "open". I tried over and over to try and get the "open" display to clear but I was not successful. I then thought to go ahead and replace the back on the case to see if the three contact springs would change the display and sure enough, "open" no longer was in the display. The watch works perfectly as before. As for the 2767, as soon as I jumped the (ac) to (-) the "open" display went away. There is only one spring contact to the back case on the 2767 model. Unfortunately I do have an extra spring that fell out when I opened it up and I have no clue as to where it goes. I have not found anyone who can help me on the location for the shorter spring. Any advice would be most helpful.
    May 20, 2009 | Casio Triple Sensor Pathfinder PRG60-1AV...
    Battery....can I get a battery replacement anywhere?
    Most Skagen watches have a snap-in, snap-out back. You will need a tool to open the back such as a slotted jeweler's screwdriver or knife blade to pry it open. Be careful opening the back as the battery may pop out. Examine and make note of which side of the battery is up. Get the number off the battery, or take the battery with you to Wal-Mart, Radio Shack or anywere else they sell batteries. Buy a replacement, install it, and try to reinstall the back. You may even consider taking the watch with you to the above retailers...some of them are willing and able to change the battery for you.
    Dec 08, 2008 | Skagen Watches
    Concord Impresario battery replacement
    The watch has a tiny screw holding the back of the watch. You must use a very small jeweler's screwdriver to open it carefully and replace the battery.
    Aug 04, 2008 | Watches
    Watches Logo
    85 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
