Kenmorewashingmachine Washing machine en ore
I tried to clean the filter of my bosch classixx 1400 I removed the black screw at the bottom right and have replaced it but now the machine is leaking.
Sarah, you have scratched or damaged the gasket/oring.. or you have trash around the gasket/oring sealing area
Jun 06, 2017 | Bosch Washing Machines
How long is the wash cycle?
seems abnormally long as most full wash cycles ore only 60 minutes unless you include a soak section in the wash which will take longer
check for a deep rinse also adds time
Jan 31, 2016 | Kenmore Washing Machines
Delivery hose leaking at shower unit how can i fix it?
There is a little oring at head of shower make sure its in place
Dec 01, 2015 | Washing Machines
How can i fix?
Look for oring could be in shower tray
Ken ore 500 washer will not spin. Fix?
check door switch, the motor coupler, belt, clutch etc
Feb 15, 2015 | Kenmore 500 Whirlpool Washer Timer...
What does En mean?
Could be short for 'END'
Dec 12, 2014 | Washing Machines
Why does my Bosch WAE18060AU washing machine's internal stainless steel tub seems like it is loose and slightly flopping a bit and a small amount of plastic seems to on the clothes from the washing ma
your are in big trouble the bearings ore gone and seems like you have used it while the bearings were gone and the shaft could be damaged im afraid its a new machine for you it would be very expensive to fix
Oct 15, 2014 | Washing Machines
My D51822 Type 1 dewalt nail gun blows air out at the nose took it apart and cleaned the junk out of it, put it back together still leaks and now it rapid fires like a machine gun
Needs rebuild kit or if you have a source for orings just replace all the vinyl (gold /yellow/clear in color) with buna or black orings. There are two vinyl orings in the trigger valve (metal stem) that fail and cause machine gun effect or replace trigger valve complete. Air out the nose indicates weak oring contact between the body of the gun and the white plastic cylinder spacer and also the cylinder spacer and the cylinder. I suspect the orings between the cylinder spacer and the cylinder (actually installed on the cylinder) . Good luck
Aug 15, 2013 | Tools & Hardware - Others
What is invoved with doing an annual service/clean. Machine is 5 years old and have purchased it described as needs service
Usually it would be a clean of the brew head, possibly the replacement of the head seal and then run the machine through the descaling cycle using good quality solution.
Some machines have extra seals, orings etc that can be replaced by the user.
Have a look at this link: http://www.saeco-usa.com/en/Support-maintenance/Support-maintenance.html
Hope that helps, please rate my help if it does. Thanks
Nov 03, 2010 | Saeco Incanto Classic Espresso Machine
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
