Question about Cadco XAF-193 Full Size Manual Convection Oven, Electric"
How do you remove the fan off the motor shaft on a cadco unox convection oven
It is a cadco XAF013 convection oven
3 Suggested Answers
SOURCE: cadco unox Mod XAF193
You can order the XC605 "air reduction kit" from the manufacturer catalogue.
Posted on Nov 14, 2008
  • 193 Answers
SOURCE: I need to replace the
Cadco sells parts to the end use through a parts distributer. The phone number is 800 458 5593. Have your model and serial number ready when you call.
Posted on Oct 12, 2010
Unox oven
i have an unox commerical oven the lights everything works but when i press start the oven the rcd trips and all electricty goes off ???
Jul 03, 2014 | Ovens
Cadco oven wont start ...give error code pre and por
It looks like the controller board is shot. Get on the web with Cadco and request a complete parts list for the controller circuits. Meanwhile, pull the cover off the stove controls and blow in clean, dry compressed air over the circuit boards. Chances are you have a short or two in the circuitry!
Dec 15, 2012 | Cadco Ovens
Need to glue outer cold glass door to the door frame.. in cadco convection oven
not sure which to use but id go to a window auto glass shop and inquire
Dec 12, 2012 | Cadco Ovens
F8 heat low it goes up to 494 and stops there
It generally is the IR Element that has gone bad. Look for burned wiring where the IR Element enters the oven cavity. Check for continuity through the IR Element.
1. Check that the blower motor is moving air.
o Blower motor is not moving air: Check blower motor assembly
and verify motor is stalled. Unplug oven and correct obstruction or
replace motor. (For access to motor shaft, remove top panel.)
o Blower motor is moving air: Verify high-limit thermostat is
not tripped. See the high-limit thermostat information below.
High-Limit Thermostat:
o Thermostat tripped: Reset and determine why the thermostat
tripped (See Figure 38, Item 114). Look for excess build up of
grease inside the oven or any other source for a fire.
o Thermostat is not tripped: Check main convection heater.
1. Convection heater is defective: Unplug oven and replace the
convection heater and verify the K4 SSR (Figure 37) is not
shorted across output.
2. Convection heater OK: Check the K4 SSR.
o K4 defective: Unplug oven and replace.
o K4 OK: Unplug oven and verify all wiring. Verify P1 voltage on
I/O board is 5.0VDC (+/- 0.02) -
Aug 28, 2010 | TurboChef TORNADO Electric Oven
Kitchenaid convection oven fan rattles/noisey
Sometimes the fan blade mounting nut gets loose. Remove the cover from the fan and see if the blade wobbles. If so,tighten the nut on the fan motor.
Jul 27, 2009 | Moffat Half Size Electric Convection Oven...
Cadco unox Mod XAF193
Oct 16, 2008 | Cadco Ovens
Jen-air convection oven blower Model # WW2750
From the inside you will find the fan. This will have 1 set screw or 2 set screws on the inside of the shaft housing.If you can remove the fan the motor will be on the backside of the oven mounted outside the cooking box.
May 14, 2008 | Ovens
Cadco XAF 115 fan not working
make sure you have selected convect bake, otherwise remove oven from wall to acces the back and test voltage at the fan, most likely the fan is bad, if you use conv. bake alot
Mar 29, 2008 | Ovens
Grinding noise every now and then
If this is a self-cleaning model it is possible that the movement of the mechanical parts are at fault. Toward the back you should be able to find the motor and drive rod. Check these first and yes, there could be a loose or faulty fan motor.
How long is the sound there ?
Jan 22, 2008 | Cadco OV-400 Electric Single Oven
Cadco XAF-193 Full Size Manual Convection Oven, Electric" Logo
96 people viewed this question
Top Cadco Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Cadco Oven Expert? Answer questions, earn points and help others
