Question about kawasaki Full Suspension Mountain Bike Men
I have a 94 gpz 500 s it wont run with the fuel tank on take it off and it runs fine
  • mark baker May 07, 2009
    thanks m8 checked that it has a vacum fuel tap on it **** on the vac side it lets fuel out but still dont run remove the tank and its fine
    the breather is fine checked that its just odd it wont run with the tank on its as tho the electrical system fails never seen anything like it
    Problem Solver:
  • 5 Answers
If the tank is on its side when you take it off, it may be down to the fuel filter being clogged up
Posted on May 07, 2009
  • stephencharl May 07, 2009
    could it be that the fuel tank is strangling the air supply?theres 3 basic thing for a running engine, thats air, fuel and ignition.check all 3 and you cant be wrong
Hi, i have a gpz500 93 plate that wont start up
there's so many things it could be but if you have covered all you say thoroughly, have you checked the timing? As it is fixed the only timing you can double check is the cams and crank. do you have a manual?
The older rotors used to crack up and ruin things to do with timing but i think the D models have improved rotors.
Apr 11, 2010 | 1994 kawasaki GPZ 500 S - GPX 500 R
I put a new fuel pump on a 94 Mazda and now it won't work in the car but runs fine when I take it off and try it. Is there a relay or something like fuel cutoff? If so where is it
There are fuses for the fuel pump and should be located under the hood.You should not run the pump out of the fuel tank the fuel keeps the pump cool and it only takes about 15 seconds to destroy a new pump when running it out of the tank.Chances are you might have ruined the pump by running it out of the tank.
Feb 17, 2010 | 1994 Mazda 323
Hi, I have a gpz500 A series on a 94 plate. I
Try changing the plugs & draining down the carbs by way of the drain bolt at the bottom of the carbs
If this doesnt work then get back in touch as it could be many things
Good Luck
Hope this helps.
(If it does then please mark this as 'useful')
Ride Safe
Bike-Doc
Jan 28, 2010 | 1994 kawasaki GPZ 500 S - GPX 500 R
94 Blazer, 4.3L Vortec Engin runs fine for a
Could be a fuel issue, Start by changing the fuel filter, if that doesnt work you might want to drop the gas tank and check the strainer on the fuel pump and make sure the tank is clean.
Jan 20, 2010 | Chevrolet Blazer Cars & Trucks
1883 Kawasaki gpz with macooni carbs wont
http://www.kawasakimotorcycle.org/forum/faqs/22157-kawasaki-gpz-550-a.html
Sep 22, 2009 | 1995 kawasaki GPZ 1100
Stevie-J my gpz 500s as a fuel starvation problem it will run forever on tickover but under load cuts out at after about 1 mile as the carb bowl is empty
check to make sure you have good fuel flow coming fro the lines going to the carb. if it flows well, then you need a float adjustment. there should be a metal tab just under the needle that cuts your fuel off when the carb is full. depending on what style float is in there, it may be just a metal piece or it may be attatched to the float assembly. either way, take that tab under the needle, and ben it DOWN, towards the bottom of the carb. not much though, maybe only a mm. or two is all it would take. move it too much, and your carb will overflow. this will let a bit more fuel in before that needle seals the fuel inlet on the carb, and should fix your problem. when the carb is off, it may also be a good idea to remove the float and needle and use carburetor cleaner or compressed air to blow through the fuel inlet, just to be sure there are no obstructions.
Aug 05, 2009 | 1988 kawasaki GPZ 500 S - GPX 500 R
I need igniter of kawasaki gpz 400r type
Google " motorcycle salvage Kawasaki " You can probably fine it there.
May 07, 2009 | 1987 kawasaki GPZ 500 S - GPX 500 R
Kawazaki gpz carbs will fire when you put petrol directlt in them
Check the routing of the wires under the tank. Also check the wire connections. It sounds like the installation of the tank is pulling on the wires causing a momentary disconnection of a power wire.
Alternate to that, are the spark plug wires grounding against the tank?
Please rate this solution. Thanks!
Mar 28, 2009 | 1996 kawasaki GPZ 500 S - GPX 500 R
Clacky engine on Gpz 500
had the same problem. Changed The Oil And Used Some Good Semi-synthetic Which Has Eased It A Little, It Doen't Sound So Rough Now, But I Have Been Told To Definately Get The Cam Chain Checked! Reply With Quote
Nov 20, 2008 | 2004 kawasaki GPZ 500 S - GPX 500 R
kawasaki Full Suspension Mountain Bike Men Logo
90 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
