Question about Sony HWSBTA2W Bluetooth Wireless Adapter
Windows 8.1 cannot bluetooth connect to hwsbta2w
Have several blue tooth connections in windows 8.1 for printer, cell phone and laptop. the hwsbta2w connected to Nook HD+, no problem, but will not connect to windows 8.1 HP 23" touch screen desktop
Sounds like you may have a device conflict on the device you to connect to. Check your desktop to make sure no other device is already connected via Bluetooth such as BT headset.
Posted on Dec 10, 2013
Bluetooth has power and buttons click when pushed, but does not respond.
I just got my blue tooth ear phone to work with my laptop, sounds like you want blue tooth car to pickup on your phone speech and sound. You probably have to enable blue tooth on your phone and connect to the bluetooth receiver in the car. Probably be good if blue tooth receiver is on so phone sees the signal, that's the way mine worked, it showed that device, I clicked it to connect. Hope that helps.
Jul 08, 2016 | 2008 Hyundai Veracruz
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
When i tryto use bluetooth this messages appear "no local bluetooth devise was detect"
If your laptop blue-tooth switch is enabled, then you need a second device with blue-tooth like a phone or laptop in range. Make sure the devices' blue-tooth adapter is switched on.
Dec 13, 2010 | Lenovo 3000 Y410 Notebook
How to connect jawbone bluetooth device to htc evo 4g
HOW TO CONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Oct 02, 2010 | HTC EVO 4G Smartphone
Plsits just that my phone's bluetooth refuse to work. It says 'unable to perform bluetooth operation'. Wat can i do to get this prob solved?
first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
(hubpages.com/hub/How-to-Flash-your-cell-phone)
and
(unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
Take care.
Jun 28, 2010 | Nokia N73 Cellular Phone
I just got a new iphone 3gs, having bluetooth
Hi, I have an iPhone also, you don't connect to other phones anymore, like if you did with normal mobile, if say you searched in a full room of people with the iPhone you would just find the printer in the corner!?!?, bizarre i know, but thats Apple for you, (2 steps forward, 5 backwards) you just connect to Bluetooth appliances like, your car, printer, pc/mac.. Thanks Mark
May 04, 2010 | Apple iPhone 3G
Motorola Bluetooth Won't connect
hello there! there are actually several cell phone brands that don't have any easy access if opening the blue tooth..one of its main reason is that some phones are just reconditions. in your case, try consulting the nearest center wherein you had purchased your phone and inquire on how you can on your bluetooth. it happened to me already with my nokia recon phone, i can't work my blue tooth myself so i tried asking the assistance of a nearest gadget center and poof! they solve it right away. for more inquiry, please keep in touch with me. thanks!
Apr 10, 2009 | LG Shine CU720 Cellular Phone
How do I turn bluetooth on and connect a Mobile phone to a Acer Aspire 5710G
Windows Mobility Center includes Acer-specific settings like Bluetooth Add
Device (if applicable), sharing folders overview/sharing service on or off, and a
shortcut to the Acer user guide, drivers and utilities.
To launch Windows Mobility Center:
Start Windows Mobility Center from the Control panel
Start Windows Mobility Center from the Accessories program group in the
Start menu
You should be able to turn on blutooth from there.
Please let me know if this helps.
Mar 17, 2008 | Computers & Internet
Bluetooth conection
you have to activate blue tooth connectivity on your phone
Dec 02, 2007 | Toshiba Tecra A8-S8514 Notebook
Conecting Blue tooth phone to acer laptop
has your model actually got bluetooth built in as most Acer laptops have the switch, but do not have it fitted, if you do check in control panel> device manager and see if it reports any problems by way of an exclamation mark. You will probably have to purchase a bluetooth usb dongle for about £9.00 or $18 US and use that
Sep 14, 2007 | Computers & Internet
Sony HWSBTA2W Bluetooth Wireless Adapter Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
