Question about Toshiba 42HL167 42 in. LCD Television
Move channel indicator position
Move the channel indictor from the bottom left corner to the top let corner
  • Phil Percel
    Phil Percel Nov 26, 2013
    Would like to move the placement of the channel indicator when you switch channels, it only shows briefly then disappears
How do I fix a refrigerator that won't cool?
if you are sure the evap fans are running (the ones inside) then only 2 things left.... 1- there is ice build up around the evaporators blocking air flow..... 2- the unit is out of freon.... I really suspect that there is ice around evap, samsung's are not known for having freon leaks.....I would unplug unit for 24-48 hours, then remove ff shelving, then take 2 screws out,(located on the bottom left and right of the evap cover and the one that is behind a plastic plug located in the center about 2/3 of the way to the top of the cover....once you remove the screws, grasp the cover on the bottom right corner and gently pull out to remove cover, being careful not to break the foam that channels air..... once removed check to see where the ice is left.... usually in the top right corner, if so replace the sensor located there... Ken Hawk
Feb 21, 2015 | Samsung RF217ACRS Bottom Freezer French...
Flashing asterisk, BOTTOM left corner.
That's the low battery indicator.
Pull the batteries out, wipe them clean, wipe the battery contacts clean, and try again. Swap the positions of the batteries. Try the old batteries again. If you have another set of batteries, try them.
Jun 16, 2014 | HP 12c Calculator
Car will start fine, brakes work but once in drive or reverse will not move, think its the transmission. Car has 350k km.
When you move the shifter into the position P,R,N,D does the indicator on the gauge light up. For example in "P" the P indictor light up, "R" the R indicator light up and so on.
If it does then you might have a bad transmission.
If the indicator stay in one position only even when you' move your shifter back and forth. You might have a broken link cable from the shifter to the trans.
Jan 19, 2011 | 1997 Honda Civic
My power led connector (green,white) power sw connector (black,white) got out of place and i dont where they go
The eMachines T3302 desktop computer, uses an FIC K8M-800M motherboard.
(First international Computer, Inc.)
Where those wires go on the motherboard, is termed a Front panel header.
The Front Panel is the plastic front bezel of your computer.
(Where the Power On button is, Power On LED light, and so on)
Looking at the motherboard with the Processor to the Top, Ram Memory slots to the Right, the Front Panel header is at the bottom right corner, and over to the left.
Look at the jumper block in the bottom right corner. Right in the corner.
This is the LED type selector, jumper block.
Has 6 pins.
3 across the Top, 3 across the Bottom.
(This jumper block is to set whether you are using a Power On LED light, that has Dual Colors, or a Single color.
The default setting of the jumper on the block, is set to use a Dual Color LED light, for the Power On LED)
Move to the left of this jumper block. The Front Panel header is to the left of this jumper block.
(FIC terms it a Front Panel Block Connector)
It should be White in color.
Is right against the bottom edge of the motherboard. (Parallel to the outside edge of the motherboard)
Has two rows of pins sticking up.
5 across the Top.
4 across the Bottom.
The pins are numbered from the Right, going towards the Left.
(From the Power On LED jumper block, towards the Front Panel header)
On the Top row going from Right, towards the Left,
Pins 1 ,3, 5, 7, and 9.
On the Bottom row going from the Right, towards the Left,
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the Power On LED light.
Pin 1 is for the Positive ( + ) wire.
(Green)
B) Pins 5 and 7 are for the Power On switch.
Pin 5 is for the Positive ( + ) wire.
(Black)
[Although it really doesn't matter which way the wires go. It's a SWITCH]
C) Pins 2 and 4 are for the HarDDrive activity LED.
Pin 2 is for the Positive wire ( + )
D) Pins 6 and 8 are for the Reset switch.
(IF used)
If any of your LED lights are dim, after attaching the Positive wire for each LED, it's because the Positive wire is on the wrong pin.
Switch the wires around
Aug 23, 2010 | E-Machines T3302 PC Desktop
Galaxy dx99v, bad squeal when I key the mic
Your microphone wires may be shorted take the mic plug apart (small screws) Now check for frayed wires touching or twisted together!
With the wires being resolderd or taped apart put back together
with the U pointing downward you shout have :
Right corner bottom Sheild ground!
Left corner bottom Black recive
Right corner top White or yellow this is Audio wire
Left corner top RED Transmit or PTT wire
If wiring looks good the problem is in the Mic take to servicer!
May 09, 2010 | Galaxy Radios DX-99V 40-Channels Base CB...
Bluish color right coener
I'm afraid, it is problem of optics unit block (light engine), there are 3 LCDs red-green-blue for color picture formation and blue LCD sounds bad, please call local TV tech for fix.
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do you replace the drum sliders on this model?
Loosen screws holding top to front.Lift top up with it hinging on back.Unplug door switch and light connectors.Loosen two nuts at bottom left and bottom right corners.Remove two nuts at top left and right corners.Lift up front and remove.Drum slides are located at the 4 and 8 oclock position
Sep 29, 2009 | GE DPSR483EA Electric Dryer
Sony Grand Wega LCD TV, the channel indicator in the top left corner stays on permanently. How can I get it to turn off?
Press Display button on remote, channel indicator (on screen display) will disappear.
Nov 02, 2008 | Televison & Video
Toshiba 42HL167 42 in. LCD Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
