Lenovo laptop and customized desktop pc cannot detect my printer
Very simple fix.
Step 1 : Open the windows menu (start button, bottom left)
Step 2 : Type in "device" (where it says "search programs and files" at the bottom of the windows menu)
Step 3 : Select "Device Manager"
Step 4 : open the "Other" or the "Printers" tab.
Step 5 : Select the device (your printer), then right click on it.
Step 6 : then select "update driver software"
That's what usually Fixes this particular problem...
SOURCE: Windows XP SP3 will not recognize the printer is connected.
It could be the cable, but most likly it is a damaged driver. try uninstalling the printer and all the drivers then reboot and resinstall it. You could also run "sfc /scannow" to see if any system files are damaged.
SOURCE: Canon Pixma ip5200 under Windows 7 - not responding
Did you download the latest drivers from the website? It looks like they were posted this month. I would report the issue. It is quite likely there is a compatibility issue. Have you contacted canon at all about this problem? Once I have more information I can try and assist you further.
Thank you,
Lee
Also check out my tip on how to save money using less ink:
http://www.fixya.com/support/r3954871-save_money_using_less_ink_when_printing
SOURCE: Uknown device Error - Canon PIXMA M180 All-In-One
just unistall the usb printing support from the device driver then you you restart then you put the printer cd in the rom and try, post your comment
well i'm not sure but did u try to change the usb connection itself? or if it doesnt work try to chek if there are any windows errrors but most propably the connection
SOURCE: driver for canon pixma mp145 for window me.
hi there,
download your driver from the link below
http://www.driversdown.com/drivers/12694.shtml
Good Luck!!!
neo
