Question about Pioneer GM-5100T Car Audio Amplifier
Amp has power but sub won't play
I've checked all my wiring and fuses and all is good. RCA cables are all good. Sub is not blown. There is a place for system control. What should be hooked up to that? If it's the remote what colour is the wire on an alpine deck
  • 75 Answers
The system control is just a fancy name for Remote Turn On. It is usually blue on the back of most decks.
Posted on Dec 10, 2013
  • 631 Answers
SOURCE: System Remote Control Wire.
Wal Mart generally has 4g wiring kits for ~$40. Some of the kits contain everything you'll need to install your amp (including RCA cables, fuses and fuse holders).
If you want to understand more about car audio installation, read through the following site:
bcae1.com
Read the following pages specifically:
Installation Primer
Wire
Fuses
Amplifiers
Head Unit
Posted on Dec 29, 2007
mjap
  • 107 Answers
SOURCE: wiring my subs to my alpine mrv-1000
did you read your instruction manual. does it says "it could be bridged to other amp"?. you can't make a bridge to amplifier that is not bridgeable. bridging an amp is a way which it is made through transistor type ampilfier by bridging more transistor inside and more voltage is required for bridging.
I don't know if we could do to an IC type amplifier. ask an experts about bridging IC types how to bridge maybe they know how.
and if you had an successful bridging, you may have a problem through your speakers, they may hit hard but you will experience some errors through your speakers and easy to worn.
Posted on Jan 26, 2008
BenJames PPI
  • 6 Answers
SOURCE: Pioneer 6300 F
Still having problems? Let's try ruling out the RCA connections as a problem:
The amplifier (Pioneer 6300F) to head unit RCA connection may have been damaged as a result of the bad grounding of the amplifier. ie; If the amplifier cannot obtain a ground connection for its voltage rail through chassis grounding or negative votage connection point, the RCA negative signal path (outer connetion shield on RCA point) will become the only grounding point.
Normally the head unit has an internal fuse (about the size of a grain of rice) which blows at this point, requiring an internal repair. You can "temporarily" repair this by connecting a wire from the outer RCA (neg) connection to the head unit chassis, however if the same grounding problem occurs at a later stage, the connecting wire will become a "fire wire"!!!!... So it's not recommended to do this for anything other than fault finding.
In some instances the RCA cable itself will be damaged, resulting in the positive, or negative wire becoming an "open" circuit. If the inner wire (pos) becomes broken (open circuit) you will have no signal presented to the amplifier (no sound) . If you have an outer RCA wire (neg) broken, not only will you have "no sound" but you will also have an annoying "pop" which will occur every couple of seconds due to the negative preamp signal (inside your amplifier) eventually finding a ground internally. This can pop circuit breakers and fuses, as it is a rapid full blast of signal voltage being induced into the amplifiers preamp audio circuit.
Lastly, if your amplifier RCA input connection has a weak or broken (dry) solder joint internal of the amplifier it will present the same symptoms as an unserviceable RCA lead.
If you want to see if this is the problem, you can do a couple of tests which will tell you whether you have this symptom occurring:
1: connect the head unit to the amplifier using the "speaker inputs". (use the speaker outs on the h.u. for this, and disconnect the RCAs). If the system now works correctly, then continue fault finding the RCA circuit. If the same problem still occurs then the RCA connection is NOT the problem, and your amplifier has a problem with its preamp circuit.
2: If step 1 "passed", replace the RCA connection (and remove the h.u. speaker signal inputs to the amp) with a different RCA lead. If the problem is not apparrent then you've fixed it!! If the problem is still occuring then continue onto step 3
3. temporarily connect a thin wire from the metal chassis of the h.u. to the outer of the h.u. (head unit) rca connector. A simple wrapping of wire around the metal outer connection to the chassis should suffice for testing. (be ready to turn the system off if the temporary wire becomes slightly hot). Test the system and see if the problem has gone away.... If the problem has been resolved, then you will have to replace the h.u. internal RCA ground fuse (which requires soldering). If the problem is still there then continue to step 4
4 temporarily connect a thin wire from the RCA outer connection on the amplifier to the amplifier chassis and see if this fixes the problem. If the problem is now resolved, the amplifier needs to be replaced, or the preamp circuit needs repair. It could be as simple as resoldering the RCA connection inside the amp, or as complex as replacing a transistor... One thing to consider is that this fault finding technique cannot be used on "balanced line" RCA inputs... The 6300F uses "unbalanced" inputs so you should be o.k.
5... If you have done all of the above, then the problem isn't the RCA connection, so at least you have ruled that one out....
Posted on Oct 30, 2008
  • 631 Answers
SOURCE: Pioneer GM-5100T Car Audio Amplifier IS THE SYSTEM CONTROL WIRE THE SAME AS REMOTE WIRE
System control is the same as the remote turn-on from the head unit.
Posted on Nov 05, 2008
SOURCE: amplifier does not turn on when head unit is turned on
Wow guess you dont need help sound like you need a new amp! ohhhhhh wait I changed my name and NOW DO YOU SEE HOW HARD IT IS TO GET A NEW NAME YOU HALF WITT WANNA BE ******???????/ ENJOY AND GOOD LUCK BECAUSE I TALK TO OTHER PEOPLE WITH THIS NEW NAME TO.......HOW MANY NAMES DO YOU WANT ME TO COME UP WITH. i CAN COME UP WITH ONE EVERY THIRTY MINUTES.........HOW MANY TIME YOU GONNA POST A NEW QUESTION............. OHHHHH AND DONT FORGET THE ABUSE BUTTON ON THIS ONT TOOOOO BECAUSE MY NAME ISNT ON THIS ACCOUNT EITHER JUST ANOTHER FREEEEEEE E-MAIL ACCOUNT SOOOOOOOOOOO HAVE FUN AND CRY YA HEART OUT........UNLESS IT IS THE FBI YOU CANT TOUCH THIS AS OLD SCHOOL MC HAMMER SAID.
Posted on Jan 07, 2009
Why does my MCS sub 10 not turn on?
Is that the right part number, MCS 10, and not MCS100?
The MCS systems use a basic sub which is matched to the satellites. There's very few controls other than level on the MCS100. So as long as the power light is illuminated the there's very little other than the volume control that could be set wrong on the sub. So what it comes down to is either
  1. a blown fuse (no power at all at the sub);
  2. a broken input (#1 cable, #2 sub input socket, #3 blown sub plate amp);
  3. incorrect connection at the receiver end or the wrong settings
As a quick test, unplug the sub cab from the amplifier/receiver end. Switch on the sub and turn the volume down all the way. Briefly put your finger across to short the RCA/phono tip and ring. The sub should make a buzzing sound. You now know that the sub is working and the cable appears to be okay
Switch off the sub and reconnect the phono/RCA to the sub out socket on the receiver. You now know it is connected correctly.
Go in to the receiver's menu and check the speaker settings. Is subwoofer present? Yes/No
Are the satellites all set to Small? (they should be with this system)
Are you playing a 5.1 source in DD or DTS to ensure that the sub gets a signal? Play a BD or DVD.
On the speaker balances, is the sub channel set to 0dB?
As long as all the above is set as listed, then the only things stopping the sub working would then be insufficient volume at the sub's Vol control (so increase it), or an intermittent cable connection (wiggle the cable), or a broken subwoofer out signal at the receiver.
Aug 06, 2014 | Boston Acoustics Audio Players & Recorders
Planet Audio PX1500M Amplifier Problem
Check the FUSE to ensure that current is not cut off.
Jul 16, 2013 | Planet Audio PX1500M - 1500W MOSFET...
Kicker dx 500.1 keeps ruining my subs
if your sub isnt blown, i'd follow your own idea and look for a bad wiring connections, also what kind of head unit do u have? check the settings on ur head unit to see if there is a seperate setting for your amp/subs if it does have one, make sure it is set properly
if it does not have a setting like above, check the rca cable from the radio to tthe amp, and make sure that the rca cable is plugged in to " input instead of the output
Jan 15, 2013 | Kicker 2010/10 Dx500.1 Car Audio Monoblock...
Klh s120eth subwoofer not producing sound.
Normaly C26 has turned bad. It's 22uF/25V and is easy to access when module is disassembled.
Dec 29, 2012 | KLH Audio Players & Recorders
I have a a 12" alpine 1243d hooked up to an
You may have blown a fuse, check those to make sure they aren't blown. Verify that the connections are in place again and make sure the settings on the amp are correct as well.
If the fuse isn't blown and the connections are secure, I would make sure that the wire that you have ran from your battery is within the specifications for use with your amplifier.
Mar 05, 2011 | Alpine Type-R SWR-1222D Car Subwoofer
I have a jl 500.1 and a 8w7. The sub is playing but not really it will play sometimes but most of the time i am getting almost nothing. Am i using the wrong settings or a bad connection or blown sub?
Sounds like a bad rca connection. You need both rca jacks to be plugged in from your head unit, both left and right or you will not have full power you'll have half power to your sub/subs. Check your sub with a volt meter and see what it reads. Make sure if your head unit has a sub volume make sure it's turned up. Alot of people don't realize they have a seperate subwoofer volume on there deck and it's set to low, so check that. You could have bad rca cables. If all that is ruled out(best way by trying a different amp) the amp itself might be having problems. Don't think it would be in protect mode either.
Let me know if you have'nt allready.
Nov 14, 2010 | Jl Audio 500/1 Car Audio Amplifier
Nothing working! please help!
no it doesnt HAVE to be wired in it just lets you control the amount of output from the sub. however the spark could have blown out the internal workings of the amp. there are genereally multiple fuses on car amps. have you checked these? if they are blown replace and reinstall if not then it very would could be that the spark caused the amp to fry.
Feb 18, 2009 | Kenwood KAC-5203 Car Audio Amplifier
Sub and amp problem
You should get power even without the RCA cable.
I believe you should take time and check your connection.
please use the right cable for your sub. you need the right cable
to boost the sub. Check radio shark or Sam Ask for better sub cable.The better one don't come with your system.
Good luck
Jul 24, 2008 | JBL PB10 Subwoofer
Kicker 750.1 Amp wont play music
it is probably the rca inputs on the amp may have fried. was your cd decked turned up loudly before the power went out? did any wires accidently touch each other? If had worked fine and then suddenly stopped, than either a wire came loose or the inputs fried. try using different cables and I also suggest disconnecting power for 24 hours and then reconnect. If the green light is on then it is getting power and the problem is in the rca cables or the inputs
Jun 03, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Cant figure out my car audio problems!!!!!
There are a couple of tests you can perform. I'd first recommend checking the shield ground. You'll need an ohm meter. The details can be found on the following page.
RCA shield ground test
You can also test the output with the multimeter. Set the multimeter to AC volts. If it's not an auto-ranging meter, set it to a voltage range of ~2v AC. Disconnect the RCA cables from the head unit. Touch one meter probe to the outer ring of the head unit's RCA jack. Touch the other probe to the metal contact in the center of the RCA jack. With the head unit near full volume and a clean signal source, you should read at least one volt on musical peaks. If you have a bass disc or a test tone disc (~60hz sine wave), use those.
May 04, 2008 | MTX Thunder 8302 Car Audio Amplifier
Pioneer GM-5100T Car Audio Amplifier Logo
55 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
