Question about Jenn-Air Refrigerators
Jenn Air Ice maker keeps getting jammed JCM-22 BDS ..have asled Jenn Air for the ladst 6 months and not oncce have they responded
SOURCE: Jenn Air JCD2389GES ice dispenser problem
my ice maker is not making ice.
Posted on Mar 26, 2008
  • 3422 Answers
SOURCE: ice maker doesn't work. changed filter. light on ice maker door still on.
Just check THIS link out.It will solve your problem.
From my side i believe it is the control board which has to be replaced and it will work again.
Goodluck..
Posted on Apr 05, 2008
  • 9 Answers
SOURCE: Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
Posted on May 01, 2009
  • 864 Answers
SOURCE: Jenn-Air refrigerator is not making ice but it's dispensing water
It can take up to 24 hours for a new ice maker to make ice.  Check it tomorrow.
Posted on May 31, 2009
SOURCE: Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Posted on Sep 07, 2009
Ice maker ice jam
Not a whole lot you can do but to keep the frost down.
If you are able to move the items in the freezer to another freezer and let it sit overnight, all your problems will melt away....
Until a couple months later when it builds up
Make sure to double check your freezer is sealing correctly, bad gasket causes moisture to be sucked in.
Here are some basic ways to slow the buildup
How to Avoid Freezer Frost
Feb 10, 2016 | Samsung Refrigerators
Why does the ice keep sticking to the ice maker and jamming it
this often happens if the temperature in the freezer fluctuates from either opening the door a lot, adding a lot of food at once, or if there is a problem with the door seal. try turning up the freezer setting and see if it continues.
May 13, 2011 | Jenn-Air JCD2389G Side by Side...
I have a Jenn-Air Refig with the freezer on the bottom. The ICE maker is not working and I think it might be frozen. How do I disconnect the ice maker so i can thaw it out?
Why not do a quick thaw and move the frozen goods over to the firdge for a few minutes and grab a blow dryer. This should give a temporary fix until you can pin point the problem. Be kind to me please with a Thumbs up. I am a long ways away and can only help a little. Raz
Apr 09, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
4 year old jenn-air refrigerator not making ice
first please check you water delivery chanel behiend icemaker, it may freeze up... second you water valve on bottom part on the back is duel( one valve for water dispencer and another one for ice maker) you have to check if it is a power going to that icemaker valve, unplug icemaker inside freezer and plug back now check for power but you have acting fast, ask somebody for help... and third it could be icemaker it self... good luck for additional questions please totalcarefl@yahoo.com
Sep 09, 2009 | Jenn-Air JCD2295HES Side by Side...
Jenn-air ice maker, stand alone unit, will not shut off, keeps producting ice.
There should be a sensor inside the ice maker bin that tells the ice maker when its full. It may be a wire or an arm on top of the ice. If you accidentally knocked that off the ice maker won't know when the bin is full and just keeps making ice
Jul 07, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
May 31, 2009 | Jenn-Air JCD2295HES Side by Side...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Ice maker does not despence ice
thanks for the question if it only clicks & a hum its jammed if a click but no humm it could be the motor remove the motor and give it 110 volts on the bench this will tell you thanks the appliance doc
May 13, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
