Question about Dell Inspiron 6000 Notebook
Dell NTLDR is missing
I need to download the NTLDR file which is missing from boot. I can not start my computer without it.
jilpeshpatel
  • 259 Answers
SOURCE: I have a dell inspiron 5150 and it won't start up
inset the extrnal dvd drive attch with usb cable and insert the orignal windows cd dell recover cd and boot timepress F12 and select the extrnal drive and start your system setup.............ok
Posted on Apr 02, 2009
e-Guru
  • 3917 Answers
SOURCE: ntldr missing
Please check the hard drive . Seems the hdd is having bad sectors.
Posted on Jul 07, 2009
  • 101 Answers
SOURCE: AT BOOT MY COMPUTER READS NTLDR IS MISSING PRESS
Pretty much what lyzmorato said , except its taken me ages to type it :)
Are you using XP or Vista ? NTLDR missing means when your pc/laptophas started up it has tried to do the NTLDR check which basically looksat the hard drive on your computer and just confirms its o.k
THere can be a number of causes for a missing ntldr
1. Computer is booting from a non-bootable source.
2. Computer hard disk drive is not properly setup in BIOS.
3. Corrupt NTLDR and/or NTDETECT.COM file.
4. Misconfiguration with the boot.ini file.
5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
6. New hard disk drive being added.
7. Corrupt boot sector / master boot record.
8. Seriously corrupted version of Windows 2000 or Windows XP.
9. Loose or Faulty IDE/EIDE hard disk drive cable.
Ideally you should go through all these options , but if you have alaptop it can be difficult to take a part and check all the connections.
If you are not really computer literate I suggest you get someone whois to follow this guide, of seek help from a technician as this can bea little tricky. This is quite a long one!
When I had this message coming up on my pc it turned out that my harddrive was toast , so prepare yourself for that in a worst casescenario. You may want to remove your HD and back it up now if youdon't want to risk losing any data
Have you made any major changes , recently changed operating system or installed new software? Am assuming you are using XP
Hopefully your hard drive is not broken, and somehow these file havebeen deleted or corrupted, First things first, make sure you haven'tleft a cd or 3.5" disk in your machine that it might be trying to bootfrom
ONce you have made sure there is nothing inserted in the machine , youare going to need to access the bios settings on your machine,
Watch your pc as it boots up at the start , it should give you anoption to press a key to enter bios settings , press this key(sometimes its F2)
Within the BIOS menu, there should be a section that deals with theboot order of your pc , you need to change it so it boots from yourcd-rom first (if you dont understand what i mean by this check thislink
http://pcsupport.about.com/od/fixtheproblem/ss/bootorderchange.htm)
Remember to note down the drive letter of your cd-rom drive as you will need this later mine for example is D:
After you have done this stick in the Windows setup cd and restart your pc
When the welcome screen comes up press R on your keyboard to enter the recovery console
It may ask for an administrator password, if you haven't changed it just press enter
then type in these commands
COPY X:i386NTLDR C:
COPY X:i386NTDETECT.COM C:
Where the X is you need to substitute that letter for your cd driveletter so as I said earlier mine was D: , so on my pc it would read
COPY D:i386NTLDR C:
COPY D:i386NTDETECT.COM C:
(the c: represents your hard drive if it is different from c: you need to change it to whatever it is )
then take out the CD ROM and type exit
then restart
your pc. If this doesn't work you can always formatt your HD andre-install windows, I did this and it worked for about a daybutbecause my hard drive was corrupted the ntldr messga returned and Ieventually had to resort to buying another HD which sorted the problemfor me
Posted on Jul 29, 2009
  • 6 Answers
SOURCE: erorr code 2000-0146 ntldr missing ???
i could give you a long technical solution but the best is to re-install windows and select repair installation ,, it should fix the error ;)
Posted on Mar 10, 2010
joecoolvette
  • 5660 Answers
SOURCE: dell inspirion 6000 is showing "loading PBR2.....done. NTLDR IS MISSING.HOW TO FIX
Use the Restoration Disk. When asked choose Repair.
(Non-Destructive Installation)
You are missing basic Windows files. Boot loader files.
Also you may have to prepare to replace the harddrive. May have bad Sectors on it.
Means I would copy off all personal information, after getting that laptop going again, or you may lose it.
Regards,
joecoolvette
http://en.wikipedia.org/wiki/NTLDR
http://computer.howstuffworks.com/hard-disk.htm
http://computer.howstuffworks.com/hard-disk7.htm
Posted on Dec 19, 2012
How do i get missing ntldr back
you are missing a key boot file for windows that is special to XP.
Load your installation disk.
restart your computer and when the F2 setup appears in right bottom corner (right after starting) press the F8 key (couple of times) and choose CDrom drive. (if you miss, try CTRL ALT DELETE--to reboot and try again.
(if that does not work, you will have to go into F2 setup and tell the computer to boot from the CDROM--you will find it by looking on each tab for a list of CDROM, Hard Drive, and listing of boot disk priority. Save you change by exiting BIOS set with F10.
At this point you can choose R for repair.
windows should repair itself. Once done, PC will reboot and you should be good.
** if other files are suddenly missing or other weird things, I would recommend a new install of windows. You should have up to date files for antivirus and malware.
Jul 14, 2014 | Dell Latitude D 600/610
NTLDR Missing or what?
You would have deleted the small kb file which contains the information of NTLDR from C: drive , Just download hire boot from net and boot it the first option in that you will see FIX NTLDR
Jan 21, 2014 | Dell Computers & Internet
When uploading windows 7 I get a message: Can't load windows at this time because of a hardware configuration problem or I get missing NTLDR how do i fix this?
First make sure there are no Disks in any of the drives CD , Floppy and Usb
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS.
Corrupt NTLDR and NTDETECT.COM file.
Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32
New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CDROM First verify that no FLOPPY DISKS or CD is in the computer, unless you are attempting to boot from a diskette Test all power and data leads that attach to your hard drive including IDE,SATA if ita flat 40 pin ribbon type it will be the first to fail. The leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty Make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
also When NTLDR is missing from your operating system it means that there is a problem with your boot loader, a bootstrap process that begins when you turn on the computer. A missing NTLDR means that your computer cannot boot to the operating system. This issue is only a problem on computers running Windows XP or previous operating systems as Windows 7 and Vista don't utilize NTLDR. Fixing the missing NTLDR is relatively easy so long as you have your installation disc.
Locate your Windows XP/2000 installation disc and place it in your CD/DVD ROM drive. If you don't have this disk, then you cannot proceed further. Restart your computer. When the computer restarts press any key on your keyboard when you are prompted, "Press any key to enter setup." Most computers are configured to boot to another device other than a hard drive. Since the Windows XP/2000 installation disk is bootable, you should see the prompt. However, if you don't see the prompt you may need to change your boot priority in your BIOS. To do so, enter the system BIOS by following the onscreen instructions upon startup. Then navigate to the Boot Priority menu and modify another device, such as a CD-ROM to boot prior to the hard drive. Then reboot your computer. After you have pressed any key, the Windows XP/2000 setup screen will appear. After loading, press the "R" key to repair the Windows installation. The screen will appear black. The computer requests which installation you would like to log in. Generally speaking, press "1" and "Enter." If you have more than one hard drive or more than one partition, the procedure may be different. You must know which hard drive or partition your Windows operating system is installed in. You are subsequently prompted for a password. If you haven't set up one up, you can just leave the query blank and press "Enter." The phrase "c:\WINDOWS>" and a blinking cursor subsequently appear. Type "copy d:\i386\ntldr c:\windows" (without quotes), where "D" is the letter of your CD/DVD ROM drive (your optical drive may be different, especially if you have more than one). Eject the CD from the drive and type "Exit" (without quotes) to restart your computer. The NTLDR file will be copied from the installation disc to your hard drive.
or If you've started your Windows XP computer and you see an error message to the effect that the "NTLDR" file is missing or corrupted, you've probably also noticed that the computer refuses to boot any further. This is because the NTLDR file is an integral part of the boot process and needs to be restored before the boot process can proceed normally.
Insert your Windows XP disc into your computer. Restart the computer and press any key on your keyboard when the message prompting you to do so appears. Press the "R" key to open the Recovery Console and then press "1" and "Enter" in order to select your operating system. Type in your Administrator password (if needed) and press "Enter." Type "copy d:\i386\ntldr c:\" and press "Enter" and then type "copy d:\i386\ntdetect.com c:\" and press "Enter." Restart your computer and let it boot up normally. Since the NTLDR is freshly restored, the computer boots up properly. b> b>
Mar 02, 2013 | Dell Dimension 3000 PC Desktop
Dell inspirion 6000 is showing "loading PBR2.....done. NTLDR IS MISSING.HOW TO FIX
Regards,
joecoolvette
Dec 19, 2012 | Dell Inspiron 6000 Notebook
NTLDR missing on XP desktop
NTLDR is the boot loader for windows XP. This is the part the kick starts the entire process of XP loading. It is located at C:\NTLDR One of the easier ways to fix this is Either boot in to the recover console from a Windows XP disc, or download Hiren Boot CD, burn it to a disc. Insert the CD into your Dell and reboot the computer. Note you may need to enter BIOS and enable boot to CD/DVD. Once at the Hiren menu, select Boot Mini XP. Once the Mini XP loads you can copy NTLDR loader from the mini xp to your C:\ drive. Then remove the disc and reboot the computer.
Jun 11, 2012 | Computers & Internet
17HEWLET-PACKARD NTLDR IS MISSING
See the following web site for help on fixing this problem or alternatively, download a copy of Hiren's Boot CD and burn this CD image file (ISO) to a blank CD, then boot your computer from the CD and take the option on the boot menu to Fix NTLDR is Missing.
Jan 12, 2012 | Compaq Computers & Internet
NTLDR is missing
this is a very common Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes:
  10. Failing to enable USB keyboard support in the BIOS.
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
hope that it will be help full
thanks
Oct 27, 2010 | Dell Computers & Internet
Dell 100l ntdrl missing on start up
For some reason your boot files are missing.
ntldr ( NT loader ) is one of the main boot files that is missing.
possibly a boot sector virus.which corrupts the ntldr file.
Put the disc back in, and you can choose to either install the O/S, or you can repair the current O/S, go for the repair,
Should resolve the problem,
Then run a full system vius scan,
Should be good then
Regards
Richard.
Apr 20, 2009 | Dell Latitude 100L Notebook
Ntldr missing error
Ntldr is the Operating System bootup file. To boot into Windows, Ntldr file is must..
IF you have the Operating System disk with you, do the OS repair. This will resolve your problem...............
Sometimes, OS disk might be problematic, in such cases, you need to go with another disk to reload the Operating System.
Jun 21, 2008 | Dell Microsoft Windows XP Home Edition
My dell d600
NTLDR or NTDETECT Is Missing or Corrupt Error Message
Table of Contents secondary.gif Start the Recovery Console secondary.gif Repair the Missing NTLDR or NTDETECT File » Start the Recovery Console
  1. Insert the Windows XP CD into the CD or DVD drive.
  2. Restart the computer.
  3. While the computer is starting, repeatedly press F12 every 3 seconds to access the one-time boot menu.
  4. When the one-time boot menu appears, press the Down Arrow to highlight the CD-ROM option that appears, which is one of the following options: Onboard CD-ROM Drive or Onboard USB CD-ROM Drive.
  5. Press Enter.
  6. When the computer boots to the CD-ROM drive, press R to enter the Recovery Console.
» Repair the Missing NTLDR or NTDETECT File
  1. Boot the system to the Windows XP Recovery Console.
  2. Type map, and press <Enter>. Make note of the drive letter assigned to the optical (DVD or CD-ROM) drive.
  3. Type copy x:\i386\ntldr c:\ (where x is the drive letter for the optical drive), and press <Enter>.
  4. Type copy x:\i386\ntdetect.com c:\ (where x is the drive letter for the optical drive), and press <Enter>.
  5. If you are prompted to overwrite the file, type y, and press <Enter>.
  6. Type exit and press <Enter>.
  7. As the computer restarts, remove the Windows XP CD.
The files have been restored and the error message should be fixed.
You can check this website for further details.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=B93824605BF646F98FDFACA51E3A9B55&journalid=4F6F8BC06C3B5014E040AE0AB5E121D2&Query=TlRMRFIraXMrbWlzc2luZw==&SystemID=LAT_PNT_PM_D600&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
Pls let me know asap if we did resolve it.
Dont forget to rate me Fixya....
Cheers.
Jun 15, 2008 | Dell Latitude D600 Notebook
Dell Inspiron 6000 Notebook Logo
13 people viewed this question
Alun Cox
