Question about Electrical Supplies
Coleman generator 54 series
Starts but dose not put out power
    Prodigy:
    An expert who has answered 500 questions.
  • 573 Answers
Check the rotor rings for cleanliness, brushes. How long has it sat?
If a long rime, the rotor may need flashing, I can advise more if you check the above
Posted on Nov 25, 2013
  • 13 Answers
SOURCE: no power out put
this may sound silly, but check the reset breaker buttons
Posted on Sep 20, 2008
  • 211 Answers
SOURCE: coleman 5000 generator will not idle up under load
Hi
You have to find the governor linkage.There is a spring adjusting by a screw to increese speed to get more power.Try to locate it.
best regards savumihai71
Posted on Feb 03, 2009
sal_kh_sab
  • 98 Answers
SOURCE: I have a coleman 54-2000 generator 2250 was working great then it started making a noise & it quit puting out 120 volt down to 62volts so I took it apart I checked the rotor & it is shorted ou
you said that your rotor is damaged so you have to re-wire it ...as for the stator testing procedure ..bring an ohmeter and put one side on the first end of the wire and the other on the other end....check for electrical continuity...if it beeped or lighted or did whatever it should do...then the stator is fine if not email me please...
sal_kh_sab@yahoo.com
Posted on Oct 18, 2009
stunt driver
  • 5 Answers
SOURCE: Older Coleman 3500 Watt generator, sitting for
there can be many reasons. need more info:
Is it Inverter typr generator?
measure output voltage - anything?
take back cover off generator itself, measure continuity of stator and rotor, and visually inspect windings. You'll find AVR module there too, it may be the reason.
Posted on Jan 13, 2010
  • 905 Answers
SOURCE: generator runs, but doesn't produce electricity
Manuals and part lists:
http://www.powermate.com/productmanuals.php?cat_id=3
Contact information:
http://www.powermate.com/contact.php
Posted on Jun 12, 2010
Changed oil and gas filter and spark plug but wont start. wont pick up its gas
put a little gas directly in carburetor and see if it starts with air filter off. if it dose, drain carburetor using screw on bottom of bowel then put more gas in carburetor , and start it and let it run for awhile then put air filter back on. it should work.
May 18, 2015 | Garden
1998 chevy
can i put tyre size 14 to my sirion 2004 module 1.0l engine
Jun 23, 2013 | 1999 Chevrolet Silverado 1500
2011 polaris ranger cutting out
clean carb and all fuel delivery system lines
Mar 25, 2013 | Polaris 2011 Ranger 800 XP EPS
Cord wont pull
It seems like the engine is seized, it may not be too badly seized. Try taking out the plug, if necessary take the end cover off the alternator, and see if you can put a wrench on the rotor and turn it, if not then you will need tor emove the heads and see what's going on. Sometimes a lot of carbon in the heads can cause this, especially if it becomes disslodged
Feb 06, 2013 | Coleman 1987 Powermate Series 54 Electric...
Manual for powermate 54 series model#545020
what is the low pressure ( ) setting for a powermate 54 series
  • model 545020 is . because .i need a new fuel pump and dont have the manual for it thank you
Sep 30, 2012 | Coleman Powermate Powermate 5000W...
What is causing my sub to work when i put the car in drive?
dose it have a good ground? sounds like its getting feed back.
Apr 13, 2012 | 2007 Ford Focus (3 Door) Hatchback
Power washer will run fine for about 30 to 40 minutes then stalls, I wait a few minutes and starts but it runs rough and stops.
Sounds like a fuel problem eighter a filter or you have debrie in your fuel tank thats cloging the inlet from the tank to the carburtator . Its that or a problem with the water pump . That could also be clogging and putting exesive back prressure on the engine shaft causeing stalling . What dose your water flow look like do you loose that first before the engine starts to bog down or dose the engine go first and the pressure follow . Also do you winterize the mechine i owen and repair many washers if you need more info you need to give more pier_j
Feb 20, 2011 | Dewalt DPH3100 Gas Pressure Washer
Bike starts but has no power and it dose not seem to hit the rev limiter. just had new timing chain fitted new plug it also seems to get hot realy quick
There is a possibility that one (or both) of the cams may be one tooth out of time. Remove the head cover and spark plug then put the piston on TDC compression and check the cam gear alignment marks on both gears.
Sep 13, 2010 | 2004 Suzuki DR-Z 400 E
Electrical Supplies Logo
57 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
