Question about Cuisinart Tea-100 Perfectemp Programmable Tea Steeper & Kettle
Circuit schematic Tea Maker
Well i have a cousinart Tea maker, a couple of weeks ago it smoked and stopped working, after checking i found that there is a small power supply where there were components burned, to be specific a LNK304dn, an OL resistor and a disk capacitor, after some research i found that the circuit is an implementation of the LNK304, almost all components are as advised in the LNK304 datasheet but thera are some of the components in the input 2 of them burned that aren't as advised in the datasheet, i did research again and i'm pretty sure that it is a snubber configuration since there is a 5 ohm resistor in series with the disk capacitor and this two components are in parallel with a diode, my problem is that the capacitor was completely burned and it is impossible to identify it's value, i supposed that it is at least a 125V or a 1000V capacitor probably 100pF since i can barely see a 1 before the burned area, so i supposed the only way is to see the schematics of these appliance or the power supply configuration which i supposed it might be used in other appliances, thanks in advance guys!
Noggin
  • 944 Answers
SOURCE: No Power
I guess you have the manual, but here is the link if anyone else needs it; http://www.cuisinart.com/share/man/25_man.pdf the unit is still under warranty, so contact cuisinart on: 1800-726-0190. http://www.cuisinart.com/contact/ It sounds like there is probably something significantly wrong, not able to check without voiding the warranty - first check plugging the coffee maker into several other outlets, just in case it is the plug that is the issue, try wiggling the power cord at the machine end - make sure it is dry first in case it has a loose contact just inside, bet even if this is the case it still needs to be fixed. Apparently cuisinart are pretty good with repairs and replacements, but unfortunately you have to pay postage - maybe check at the store you bought it and see if they will do anything for you - most will if you ask right and have the receipt. Hope this helps :)
Posted on Mar 17, 2007
frcs68
  • 1605 Answers
SOURCE: Coffee Maker stopped working
you can take the coffee maker apart, from the buttom. there 3 to 4 screws holding the inside guts together. take a look the themo fuse. it should have anumbe rstempted on it. go to local appliance repiar shop and get a themo fuse.
replacement make be difficult. the themo fuse is cramped, not soldered. (because of high temperture.)
at side from that, you can the the repair shop do the job or get a new one.
Posted on Nov 06, 2008
  • 2976 Answers
SOURCE: Recipe book blatantly wrong
I've found that the recipe books that come with most appliances, aren't very accurate. They don't accomodate different altitudes or even different countries. I hate trying to convert European recipes to American. European recipes list their dry ingredients by weight, not by volume. I had to find a recipe converting website to change a lot of those that sounded good.
Posted on Jan 03, 2009
  • 3 Answers
SOURCE: Cuisinart coffeemaker DCC-450 switch keeps turning off by itself.
There is a defect with your coffee maker. It uses a momentary switch, but is supposed to stay on for 30 minutes. I believe there is a common failure due to heat sensitivity of an IC on the board. I suspect this is a timer chip. See my other postings on this.
-Joe
Posted on Jan 11, 2010
  • 512 Answers
SOURCE: cuisinart CBC-00 series coffee maker seems to have lost power
Yes it has a short. Mine did the same. Cost to much to fix, cheaper To buy new one, if under 3 years old cuisinart will replace for $10 shipping charge. 1-800-726-0190
Posted on Jun 30, 2010
Why would my ice maker stop making ice?
Diagnostics does not tell you the water valve opens it only tells you the power was applied to the water valve
APPLIANCE 911
Jan 07, 2016 | Frigidaire Gallery Stainless Steel French...
Ice maker water line comes loose when water turns on
Sounds like your terminal connections on the water valve have gotten reversed. Try switching them..Also you may need new water valve..
Aug 03, 2017 | Refrigerators
Ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
jkkjffkj
Jun 27, 2010 | LG LFX25960ST Stainless Steel French Door...
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Can loose tea be used with this tea maker?
Loose tea can be brewed. I had researched more on the internet.
Jul 30, 2009 | Back to Basics IT400 TEA MAKER 2.5qt GLASS...
No power
Check the top of the tank, there may be 2 thermostats, one that sits on the tank and the other is in line with the element. One of those are not working.
Mar 24, 2009 | Bunn Iced Tea Maker 3 Gallon Tall w Ready...
Need New Tea Drop Part
http://www.householdappliance.com/sunbeam.html
go to this site and order what u need. please mark my answer as a fixya!
Enjoy your tea!! And, as a point of interest, my step son did the same thing and he is an engineer with a MBA..... lol
Feb 27, 2009 | Sunbeam Tea Drop Tea Maker HTM5B
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Will not despense tea
Brew vinegar through it. Stop the brewing cycle halfway through and let it sit overnight. Should work better.
Oct 15, 2007 | Sunbeam Tea Drop Tea Maker HTM5B
Cuisinart Tea-100 Perfectemp Programmable Tea Steeper & Kettle Logo
42 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
