Question about Martin Yale Intimus 502 CC Shredder
Paper light stays on,but everthing looks ok. is it possible i can download a manual for this machine. thanks
    Habit-Forming:
  • 17 Answers
Look up the company name online, go to support and you should be able to find it. also try blowing or using a vacuum to suck all the shredded stuff out of it. be sure to unplug it first. turn the shreadder head over and clean it out.
Posted on Dec 05, 2013
Paper full issue
you can usually download the manual for these things online. just start with a search of the company. and go from there. it\'s probably just a sensor messed up or had a piece of paper covering it. some times the answer is as easy as unplug it, turn the shredder head over and blow it out or use a vacuum to suck it out. put it back together and see if it works.
Nov 24, 2013 | Office Equipment & Supplies
I have a asus p4p800-vm motherboard I have everthing hooked up right the front panel wires power from the processor and power supply led lights hdd reset everthing but when I plug the computer up nothing...
Hi, maybe you should download a manual.
From here:
http://www.asus.com/Motherboards/Intel_Socket_478/P4P800VM/#download
Just to check you have connected everything right.
First select your operating system.
Select manual and click on global for download.
The file has to be unziped before you can read it.
Have you installed the ram module and cpu correct ??
If you have installed a wrong type of ram it will not boot at all.
Does it makes any beep sound ??
Is the powersupply ok ??
If you are useing the onboard graphic check for loose connections.
Check with the manual that all connections are in order.
Aug 28, 2011 | ASUS P4P800-VM Motherboard
Fan and light stay on all the time,but everthing works ok
replace the IO circuit board.
thanks
please rate my work
Aug 27, 2011 | Sharp R-1470 Microwave Oven
I have a Brother model HL-2040. The printer was working fine. I put some additional paper in it and clicked print and all the lights started flashing. I looked for a paper in the printer wrong and...
Red paper light is on means that there is no paper fed in the machine. Follow the steps below to clear this issue:
- First remove the paper tray from the machine. - Then remove all the paper from the tray. - Fan the paper well or run your fingers through the edges of the paper. - Adjust the paper guides of the tray. - Then reload the paper back to the paper tray. - Put the paper tray back to the machine. - Lastly press the go/blue button.
Printer should print the document.
Hope this helps. Rate if it works. Thanks
May 09, 2011 | Brother Office Equipment & Supplies
Paper light keeps blinking, paper full, won't print
Paper light blinking could mean a few things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 12, 2010 | Brother HL-2040 Laser Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Problem with plotter
That sounds like a carrage movment problem. When you load paper the carrage moves from the RHS very quickly. If your carrage is not properly lubricated you will get that fault. Before going further you must switch off and open the cover. Look along the length of the belt (just below on the aluminum) if there ere lots of reddish pieces and a dust like substance it means that your carrage belt will need replacing. If the belt is ok, then move the head to the middle of the machine by hand and apply a drop of thin oil (sewing machine) to either side of the carrage on the bar. Move the head slowly left and right to lubricate the bar. It then should be ok.
Good luck
Dave
Jun 02, 2009 | HP DesignJet 450c InkJet Printer
The word SERV apears on my car when I start it and stays on, what
It means that a SERVICE is due. The orange man symbol is showing there is a problem with the airbag system.
Apr 05, 2009 | 2004 Renault 181
CANON PC920
POSSIBLE BAD EXPOSURE LAMP, SOUNDS FUNNY BUT THIS MODEL WILL SEND JAM CODE WITH BAD EXPOSURE LAMP. CHECK TO SEE IF LIGHT IS IN PREHEAT MODE. ALSO THE EXIT PAPER SWITCH GETS BROKEN OFF ON THIS MODEL...
Nov 29, 2007 | Office Equipment & Supplies
Martin Yale Intimus 502 CC Shredder Logo
100 people viewed this question
Top Martin Yale Office Equipment & Supplies Experts
gbob59
1Teddybear
1Teddybear
Tom Chichester
Are you a Martin Yale Office Equipment and Supply Expert? Answer questions, earn points and help others
