Question about Dewalt DC385B 18v. Cordless Bare Reciprocating Saw Contractors Special
Dewalt battery seems to have loose conecton when installed in sawzall
2 Suggested Answers
  • 885 Answers
SOURCE: DEWALT DW938 18VOLT CORDLESS SAWZALL can it use
As long as the voltage of the battery is the same as the tool, the tool won't mind if the power is coming from a NiCd or lithium battery. You do have to have a charger that works with lithium batteries to charge them up. Chargers that can charge lithium batteries can also charge NiCd and NMH batteies. NiCd chargers are not always programmed to detect when lithium batteries are full and may continue to charge them to the point of melting or starting on fire.
Posted on Jan 31, 2011
I have a dewalt 18v sawzall dc385 type 2. It only runs at half speed. What's wrong?
Hard to tell without inspecting it, or more specific details. First things if check are the batteries reliability; then whether the contacts on both the battery, and tool are clean. If the contacts are filthy, scrap or sand the contacts lightly with an Emery file.
If it's not that, then it would have to be taken apart cleaned and inspected for excessive wear, or an electrical fault.
Jun 27, 2015 | Dewalt Saws
Broken blade in dewalt sawzall
Remove broken blade, install new one. These blades don't change themselves, unfortunately.
May 06, 2012 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
Replacing blade assembly on a dewalt 18v Reciprocating Saw Sawzall
Remove the foot, remove the boot (and yellow lever), pull shaft out all the way (so you have more room to work with), remove the spring clip from the clamp block, remove the lever and ball, the clamp block will then slide off once the wire clip that wraps around it is removed.
Apr 22, 2012 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
DW938 only works when I bump the underside, forearm and for only moments.
could be quite a few things but it is obviously a loose connection in the electrical system, I would suggest going to dewaltservicenet.com and downloading a parts schematic before removing anything. I am thinking the battery or switch but try another battery first and look at the contacts for dirt or arcing. Let me know if you need more assistnace.
Nov 11, 2011 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
DEWALT DW938 18VOLT CORDLESS SAWZALL can it use Lithium Batteries
Jan 31, 2011 | Dewalt Dw938 18v Cordless Reciprocating...
I have a DW938 and I cannot get the blade to lock into place seems like there is no lock at all.
Hi, If you look at the end where the blade goes in, on the right hand side (as holding it for use in your hands) you should see a yellow lever. First take out the battery, each and every time you change the blade. Lift up the lever, wear some gloves to protect your hand and pull the plade straight out. Push in the new blade with the teeth pointing down, and push the yellow lever down. You can replace the battery once you have completed the above. Hope that was of help to you.
Jan 13, 2011 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
Can I use a 18 volt XRP battery in the DeWalt DW938 Reciprocating saw?
Yes. Dewalt says the 18volt XRP battery is compatible with all Dewalt 18volt tools
Have a great day.
Dec 29, 2010 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
What is the problem when a dewalt reciprocating saw (cordless) losses power
I am assuming you are refuring to the battery life. To be honest with you it is not a new problem. The Sawzall uses more power than the battery can store, so there don't last.
If this is a new problem for you that you are noticing less power with fresh batteries., They could be bad batteries. Barrow someones, if you can and see.
I hope this helps you. Please let me know if you have any further questions or if that this did help you.
Aug 09, 2009 | Dewalt DC385B 18v. Cordless Bare...
Dewalt DC385B 18v. Cordless Bare Reciprocating Saw Contractors Special Logo
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
