Question about Simpson Washing Machines
No power stopped working mid cycle when full of water. No power at all. Tried different appliance in power outlet,and there was power. Machine will not start or show any lights.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 10 Answers
Check if ac entered the pcb unit if its ok check the smps of the module
Posted on Mar 07, 2014
  • 1294 Answers
SOURCE: washing machine stops mid-cycle and full of water
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
Yozzer6821
  • 116 Answers
SOURCE: Door lock light flashing
More likely the PCB needs replacing - common fault, you could try a new door switch first cost £5 new PCB £65+ but is easy to replace.
Posted on Nov 09, 2008
barkencoa
  • 3463 Answers
SOURCE: washing machine stops mid cycle and lights start flashing
Drain the water by lowering the hose into a bucket or something and then try it on spin, if it spins o/k then you probably have blocked pump or filter.
The filter is located in the large black hose that is fastened to the bottom of the drum, remove and clean.
Hopefully this will solve the problem.
Plz rate this solution.
Thanks.
Posted on Dec 17, 2008
barkencoa
  • 3463 Answers
SOURCE: Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Posted on Jan 16, 2010
  • 33 Answers
SOURCE: My washing stopped working mid cycle. I checked
the timer is probably sticking (needs replacement) or lid safety switch stuck open. try restarting the load and if stops at the same place it is the timer unit, if it fills up with water and than stops - lid switch.
Posted on Mar 29, 2010
My Kenmore 20722(990) washing machine stopped mid cycle. It is full of water and clothes. I checked my circuit breaker, nothing tripped. I checked my ground fault switch, that wasn't it either. It is...
Go to the link below and enter your model number in the search window there. Sears has thousands of parts lists and line drawing illustrations that can aid in finding the reset button if present or any other part you may want to locate or replace.
Sears PartsDirect
BTW, it does not have to be a Kenmore or Sears-branded appliance. They have many others as well.
Mar 22, 2011 | Kenmore 20722
Dishwasher will not turn on,
OK check Fuses/Breaker.
Check there is actually power to the outlet, try another appliance in the actual outlet.
Try this below...
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle.This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method,
If none of the above work etc, then my advise is to get a serviceman to call. Contact a Whirlpool agent, and when they call, ask for a "quote" before allowing any repair work to be undertaken.
Manual link below. http://www.retrevo.com/support/Whirlpool-DU1100XTP-Dishwashers-manual/id/8232ci774/t/2/
Mar 02, 2011 | Whirlpool 24 in. DU1100XTP Built-in...
Just got washing machine...its used. However it stops mid cycle and is full of water. I have to stop it and turn the knob to a different setting (like from normal to permpress) and sometimes it will...
If it just stops in one of the cycles such as regular, it points to the timer being defective. Have you tried to complete a cycle in say, perma press pr delicate? If it works ok in the different cycles except one, it's most likely the timer.
Jun 21, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Mar 29, 2010 | Washing Machines
Hotpoint , no power, full of water
Turn off the water supply to the machine
Take the drain hose off the back of the machine and drop it into a bucket , you will need to do this several times.(Take off any clips that stop it from being laid flat on the floor)
Once all of the water is out of the machine try powering it up again, if it lights up do a spin to get the clothes dry , leaving the outlet hose in the bucket.
If that works then once the machine is dry try turning on the water supply with the machine turned off , if water runs into the machine then you have a faulty fill valve.
If that is ok then check the pressure switch and Air Bell which sits on the back of the main drum you could have a soap ball in the Air Bell which will false out the machine and cause overfilling
If there is no power check the mains supply to the wall outlet then the plug top wiring and any fuse fitted inside the plug top
After that it is down to a man with a test meter
Jul 17, 2009 | Kenmore Elite 45986 Front Load Washer
NO POWER
easiest way to get the clothes out is to power the pump up independantly of the machine. you will need a length of mains cable and connectors. having got the water out, you should be able to remove clothes. another way is to put the drain hose down at floor level into a bucket and this will drain most of the water away. the actual fault is rather more difficult but check there is power the machine side of the mains suppressor. another possibility is the door interlock.
May 11, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Washing Machines Logo
163 people viewed this question
Top Simpson Washing Machines Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
