Question about IBM ThinkPad A21m 2628 Notebook
Decide Boot method - IBM ThinkPad A21m 2628 Notebook
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
I have ahink center.. the control is u hit any key while booting to choose one time boot method..is that your question? on some machines its f9 on others its f12..depends on bios ver
Posted on Nov 26, 2013
What does error oxcoooo12f indicate?
There is an error in either an application or a damaged file. Try these;
Method 1:
Boot the computer in a Clean Boot state and check the status. A clean boot helps to verify if any third party application service or startup item is causing this issue.
Note: After you have finished troubleshooting, follow steps under "How to reset the computer to start as usual after troubleshooting with clean boot" in the article to boot to normal startup.
If issue persists, follow Method 2.
Method 2:
If issue persists, I would suggest you to perform SFC scan and check if that helps. The sfc/scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 11, 2016 | Computers & Internet
My micromax x600 mobile asking input phone lock code
visit www.hard-reset.com or see the result.Hard reset
Cold boot method: Hold the "Power Button" of the Pocket PC with one
hand while holding the stylus tip to push in the "Reset Button" with the
other. Simultaneously release both the "Power Button" and "Reset Button".
Appropriate situation: If a previous reset has already been attempted and
the Pocket PC is still unable to maintain normal operations, has no
response, or if the screen is frozen.
Before executing the preceding "Cold boot method", please carefully
consider the following instructions and then decide on the cold boot
method.
1. After a cold boot is performed, if no buttons are pressed, when Pocket PC automatically completes the system startup process, the last display will be the Today screen. This is identical to the reset result.
2. If a previous reset has already been attempted but the Pocket PC is still unable to maintain normal operation, consider the following solution:
After cold boot, hold the End Button eten_glofiish_x600_hard_reset_soft_reset_5.jpg on the bottom right of Pocket
PC until the system inquiry screen is shown, and then release the End
Button. Next, please read thoroughly through the instructions on cold
booting before continuing carefully.
Erase all data and load default?
The default is "No." If Yes or No was not
selected, after a few seconds the system will
automatically execute the default No.
If you long press Left Soft-Key for a few
seconds to select "Yes," then the system will
erase all data and load default. After your
Pocket PC restarts, follow the instructions on
the screen to complete.
Caution!
1. After performing a cold boot, the system will retain Microsoft Windows
and pre-installed programs. If you answer "Yes" to the question displayed
after a cold boot, other items such as the user's input data, newly installed programs and user settings will be lost.
2. There are two ways to retain your data, loaded default and registry:
Perform a Reset.
Performing a Cold Boot, and answer "No" when the above question
displays.
Jun 27, 2012 | Eten E-Ten GloFiish X600
How to connect 2 pc together
You can network two PC together without a LAN hub using a 10baseT crossover LAN cable. I recommend this method as you can add a LAN hub to expand your home network over other methods..
Check out this WEB site for this and other methods so you can decide which is best method for you.
http://compnetworking.about.com/od/homenetworking/a/connecttwocomp.htm
Mar 28, 2012 | Computers & Internet
I cant get past power on and dont remember password
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
Aug 15, 2011 | IBM ThinkPad T43 Notebook
Are there any other methods on how to perform SAFEBOOT / SAFEMODE? I only know 2 methods which are from the F8 key on boot-up and from msconfig under the boot tab.. some say that there are still other...
There is ONE other method you can try, but do NOT make a habit of it, because you COULD damage your computer. That being said, I use this method when I have no other option.
You SHOULD be able to FORCE Windows to enter "SAFE MODE" by shutting the power off (or unplugging it) while the system is starting to load Windows. After you turn the power on, try booting the computer. The system should notice that the previous boot attempt failed, and the computer should automatically boot into Safe Mode.
Apr 30, 2011 | Microsoft Windows XP Professional
Password for windows xp?
Method 1.
  1. Log in with any valid account.
  2. Bring up the command prompt.
  3. Type: net user
  4. You get a list of accounts
  5. Type: net user Administrator *
    • Type: net user (any account on that list) *
  6. It prompts for a password. Enter one, then enter it again when prompted to confirm.
  7. Log on as 'Administrator' with your new password.
  8. Edit: Please note that this might not work on a LIMITED account.
Method 2.
  1. Restart the machine and start pressing F8 immediately.
  2. Boot into 'Safe Mode' (it has a default administrator account).
  3. Make yourself a new 'Administrator' level account
  4. Reboot and log in with that.
  5. Proceed with Method 1.
Method 3.
  1. Boot the machine with a recent version of Linux that runs off CD.
  2. Mount the Windows drive (or volume with 'Documents and Settings' in it
  3. Access whatever files and folders you need to.
Method 4.
  1. Use a Windows 2000 recovery CD to boot the machine
  2. Start the 'Windows Recovery Console'
  3. Access anything you like
  4. Add a user with 'Administrator' privileges
  5. Even change the Administrator password
Method 5.
  1. Boot off your XP disk.
  2. Start an installation and 'Repair' your windows installation.
  3. When the progress bar says 'Installing Devices', press Shift-F10 to get a command window
  4. Type NUSRMGR.CPL to get the User Accounts control panel and change what you like.
Method 6.
  1. Pull the hard drive from the machine
  2. Install it in a drive enclosure
    • OR plug it into another machine's IDE/SATA/SCSI/(whatever it is) port and give it power
  3. Boot up with that second machine's normal boot drive as 'Administrator' and access or change permissions on any files on the drive you like.
  4. Put the drive back in its original case.
Method 7.
  1. Search Google for OPHCRACK (OPHCRACK live cd for bootable disk)
  2. Download it
  3. Install it (or if it's live cd use an iso program to burn it like WinIso or NERO)
  4. Run the program and choose import from local sam (check youtube for more instructions.)
  5. Then choose crack and wait for the password to be recovered.
Feb 18, 2009 | Toshiba Satellite M100 Notebook
I've forgotten my password on my hp notbook
There are a lot more ways, but these are 7 different ways how to do it.....I hope this works for you....Good Luck!
Method 1.
  3. Type: net user
Method 2.
Method 3.
Method 4.
Method 5.
Method 6.
Method 7.
  2. Download it
Feb 18, 2009 | HP Pavilion dv4000 Notebook
Windows could start because the following file is missing or corrupt: system 32/drivers/pci.sys
Hello:
You can try repairing the installation of windows.
You need a windows installation disk or system recovery disk.
insert the disk in the CD/DVD RoM
boot your pc from the cd rom.
the system will prompted you repair , press r and then select the 1 or 2(most probably 1)
supply password of the administrator. if no password strike enter
Type: chkdsk /r then strike enter
the system will check and restore.
wait until completed.
If incase its a recovery disk:
boot your pc in the cd rom
the recovery disk you got to option;
either ; you partition and format the entire disk
or leave the current file only the system will be deleted and restore the new system( Something like that)
you have to decide either of the two option. you can try each option:
all of that will be corrected by installation of new windows: windows installation method is here: http://support.microsoft.com/kb/316941
may this help,
melnavz
Sep 11, 2008 | Computers & Internet
Still stuck...
If you are referring to the NTLDR issue, you can achieve the same by booting from the XP CD and entering the Recovery Console, as outlined in methods 2 and 3 :o)
Sep 03, 2008 | EPoX EP-8K9A Motherboard
IBM ThinkPad A21m 2628 Notebook Logo
48 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
