Question about ElectroVoice SxA250 Main / Stereo Speaker
Where can I find the fuse and the fuse "holder" for this unit?
  • 2,113 Answers
SHARP R-8570 MICROWAVE BLOWN FUSE DO U NEED TO REPLACE HOLDER
You need to know why the fuse blew first. two places that will cause the fuse to blow is excessive current being drawn from a shorted winding in the transformer or a bad magnetron unit. If the holder is loose, pinch the metal parts that contact the end of the fuse slightly to restore proper contact with the fuse.
Sep 09, 2017 | Sharp Microwave Ovens
I have a Panasonic inverter microwave. Was working perfectly an hour ago. Now totally dead. There is no light or anything. Have checked plug and fuses. No smell or anything. Can you please help.
Could be a shorted inverter blew fuse and unit dead. Or bad fuse holder got fuse hot and melted fuse so now unit dead. Must check fuse first and if bad replace and try, if it blows as soon as it tries to heat probably bad inverter. If it works for a long while then quits maybe bad fuse holder not grabbing fuse tightly making it over heat. So then bad by temperature not amperage.
Jun 20, 2017 | Panasonic Microwave Ovens
Where is fuse located
Leonard, first, unplug the microwave and then turn it around so that you are looking at the back of the unit. Take the screws out that hold the cover onto the unit, most will be accessible from the back, but some may be on the side as well. Once you have all of the screws out you can remove the cover and set it aside. Find where the power cord goes into the back of the unit and follow the black wire from the cord to where it stops. Usually it will go either to a circuit board where your fuse will be located or it will go directly to the fuse holder. The holder could be a block mounted to the unit or it occasionally goes to an in-line fuse holder. The fuse will be stamped with the amperage rating on one end of the fuse on the metal collar. You need to make sure that you replace it with the same amperage fuse. Hope this helps!
Feb 16, 2015 | Panasonic Nn-sd697s Microwave Oven Single...
The fuse box under the hood, one of the fuse insert is broke so I need to replace the whole box. I need help to find the part ant the name of the part
You can call it a fuse box or panel. The unit usually comes as part of the harness. You can usually find a good used unit in most scrapyards or, you can make a "work around" by detaching the box and locating the wiring that feeds and is served the broken fuse holder. Then, all you need to do is buy an in-line fuse holder and bypass the original by attaching the wires from the holder to the backside of the panel. Use one rated at or above whatever the fuse you are replacing and use the same fuse that belongs there. If you do this, the only caution is to make sure you don't pinch any wires when you put it back together. It sounds complicated but it's far easier than installing a complete unit and it shouldn't cost you more than $10.00.
May 11, 2011 | 1996 Jeep Grand Cherokee
Where is the fuse located?
In general you can locate the internal fuse by opening up the microwave cabinet. To get to the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board.
Jun 01, 2010 | Westinghouse WST3504 Microwave Oven
Replace the fuse within the microwave
Hello :
To locate the fuse, remove the outer cabinet of the unit, which is usually held in place with a few screws. Once the outer cabinet is removed, follow the power cord into the unit. It will take you to the fuse holder, where the fuse sits. The fuse holder is located two or three inches into the unit, and may be attached to a power board .
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
good luck .
please rate !
Mar 31, 2010 | GE XL1800 1100 Watts Microwave Oven
Where is the main fuse?
Hello :
The picture bellow is showing a blown fuse .
please rate .
Mar 29, 2010 | Kenmore 80412 Microwave Oven
No response from company on Oster 12 bottle wine refrigerator
just replace the 5amp fuse on circuit board with a 6.3amp. tada!
use an exacto knife to remove the shrink wrap on both ends of old fuse. heat ends with a soldering iron and pull away old fuse. solder new 20mm in line fuse holder from radio shack to both poles insert 6.3amp fuse and done. at least mine works again! $6.00 total cost!
Dec 15, 2008 | Oster 12-Bottle Wine Cellar - Black
BRAVETTI CONVECTION OVEN MODEL K5345H
open by unscrewing screws on back and along left side bottom. this lets you swing up the cabinet showing the electrics. the red power line going to the timer is held in place by a metal wire holder that is riveted to the base. wire has a white sleeve between its insulation and the metal wire holder. slide wire and sleeve out to the side of the holder. slide sleeve to side along wire, revealing fuse. need a solder iron and an electronic parts store to get replacement fuse and solder it in. reassemble.
the fuse is a resistor that blows when unit is getting hot. use lower resistance fuse or just hardwire the power line straight through, no fuse, but watch for overheating (not likely) and maybe use breaker outlet
Oct 15, 2008 | Microwave Ovens
BLAUPUNKT TRAVELPILOT E1 RADIO/SAT NAV
Nov 21, 2007 | Car Audio & Video
ElectroVoice SxA250 Main / Stereo Speaker Logo
41 people viewed this question
Top ElectroVoice Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
 Grubhead
Grubhead
Are you an ElectroVoice Audio Player and Recorder Expert? Answer questions, earn points and help others
