SOURCE: transmission problems 4 a 94 s-10 blazer
These transmissions are computer controlled, and this sounds like you have electronic problems coupled with mechanical transmission problems. I suggest you consult a transmission specialist to diagnose your problems.
SOURCE: press accelerator, but car won't move
take the car to the trasmission guy, have them check it out.
you may have burn the troque converter.
SOURCE: BRAKE LIGHTS STAY ON ENGINE RUNNING BUT CAR WONT DRIVE
there is a button on your brake pedal lever that while braking gets
depressed, and turns on your brake lights. Now this component is a
plastic piece that can get knocked loose rather simply. You either need
to re-secure this component, or replace it
(you can get this part at any junk yard for nothing more than some pocket change)
SOURCE: My gear shift is stuck and will not move from park
do the brake lights work? the system has a lock out that keeps you from moving out of park unless the brake circuit is activated, hence no brake lights no park lock out release, if the brk lights do work u most have a stuck or defective park lock out solenoid.
SOURCE: car does not drive forward but works in reverse
Sad to say but your automatic transmission has bit the dust.
