Question about Rug Doctor Vacuums
There is nothing coming out of my Rug Doctor when trying to clean the carpet.
While pulling my rug doctor for cleaning, it appears that nothing is being sprayed onto the carpet.
SOURCE: won't spray water to clean rug
push in on the front of the water supply tank while holding down the trigger
Posted on Jan 12, 2008
reddevil6
  • 1673 Answers
SOURCE: No Water
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle also, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Bissel's Number is: 1-800-237-7691, they can tell you were to get service in your area.
Posted on Jul 13, 2008
SOURCE: hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Posted on Jan 20, 2009
garing
  • 998 Answers
SOURCE: On a Royal #CE6600 it will not spray water on rug,
spray opening may need cleaning (small wire may work)
Posted on Aug 31, 2009
heatman101
  • 43501 Answers
SOURCE: my bissell proheat rug shampooer wont wet carpet at all
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
gfhjdhg
Posted on Sep 30, 2010
Rug doctor deep carpet cleaner leaks the clean water solution out the bottom so quickly I can only clean a very small section of carpet per tank. You can watch it pour out
You have a crack or hole in the container holding the clean water solution. Also check any hoses going in and out for integrity.
Aug 26, 2017 | Vacuums
The switch on my machin will not go on what do i do their or whats wrong with that what do i do to fix it?I plug in the rug doctor then i flip the switch but it wont go on.
bad switch or broken wire in the cord . use a continuity tester to check from the plug to the switch. if the cord is good check the switch itself good luck
Apr 27, 2015 | Rug Doctor 95730 MP-C2D Mighty Pro Carpet...
Water pours out from underneath
Check your hoses inside the motor area. One may have come loose.
Jan 16, 2014 | Rug Doctor 95730 MP-C2D Mighty Pro Carpet...
Rug doctor shampooer sprayer quit, I think
You think ? If it did you will have to take it to a vacuum repair shop. That's not a DIY job typically.
Oct 19, 2013 | Rug Doctor Mighty Pro Carpet Cleaner
Rug doctor repair manual
<Consumer.Support@rugdoctor.com> said: "Thank you for your inquiry about a schematic for the Mighty Pro machine. The only place that can be acquired is through Rug Doctor's manufacturing facility. You can contact our manufacturing facility at 800-964-4362 and ask for Parts. They will be able to provide you with what you are requesting."
Rug Doctor Consumer Support
Rug Doctor, LLC ' 4701 Old Shepard Place ' Plano, TX 75093
http://www.rugdoctor.com
Sep 07, 2013 | Rug Doctor Mighty Pro X3 Value Pack - Blue
Find water pump rug doctor
is it your own machine or a hire machine?
Your best bet would be your nearest rug doctor distributor or try ebay.
Tony from DirtMaster
Feb 25, 2013 | Rug Doctor 95730 MP-C2D Mighty Pro Carpet...
Rug doctor won't spray water
I had the same thing happen to mine. I looked at the hose in the water tank and the screen at the end if the hose was slimy and clogged. I took the screen off and cleaned it up, put everything back together and it works like new again. Only 2 screws and a screen.
Oct 17, 2012 | Rug Doctor Mighty Pro X-3 Ready Pack...
Can't get Bissell carpet cleaner back together
I've purchased 2 of these both are broke again, although I may fix one again and give it away instead of throwing it in the trash. You can tell by all 10 pages on this site that these machines are just **** that is poorly designed. Just ordered a Rug Doctor Mighty Pro from Kohls with 30% off for $503. You won't even find 1 problem on this site on a Rug doctor. Also you can research them as I did and 98% of their owners was very satisfied, alot of whom used bissell prior to Rug Doctor. You will also see that the performance is way, way better and not even close on cleaning.......
Feb 10, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
Top Rug Doctor Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Rug Doctor Vacuum Expert? Answer questions, earn points and help others
