My hp photosmart 5510 is leaving a thick black
My hp photosmart 5510 is leaving a thick black line when I copy or scan but is fine when printing, any ideas why?
  • 85 Answers
Clean the glass on scanner
Posted on Nov 25, 2013
  • 31 Answers
SOURCE: Black line when scanning or copying
If the line only appears when the scanner is used & not when printing directly from the computer, you are correct in assuming the problem lies in the scanner assy. There should be mirrors attached to the scanner assy which will gather dust and cause copy/scan problems. Remove the glass & clean the mirrors with a DRY cotton cloth. Do not use any cleaning solution on the mirrors as they are sometimes treated & can be ruined if they come in contact with a cleaning solution. Use the dry cloth to wipe off the lens while you have it apart.Also clean both sides of the copy glass while you have it off. Reinstall glass & test.Cleaning the optics solves the problem most of the time. Good Luck!!
Posted on Jun 25, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Posted on Oct 27, 2007
SOURCE: Error HP Photosmart 3310. No strart print, no scanning...
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
Posted on Feb 20, 2008
Ajkill
  • 2035 Answers
SOURCE: two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Posted on Nov 11, 2008
SOURCE: Can't scan on HP Photosmart C4380 even tho printing works fine
I am sick and tired of the problems i have with this PSC, but i have found a scanning solution and thought i would share it.
Use Microsoft Paint. It's not the best application in the world, but you can insert a scan from a scanner in the 'file' menu. :0) The scans are not of the best quality, but i'm grateful i can scan at all with this useless PSC.
Posted on Apr 18, 2009
How to print in only black and white
This differs depending on what program you are printing from and whether you are on Windows or Mac. Generally when you go to print you can go to the print properties and choose Black and White.
You can try checking the user manual: http://h10032.www1.hp.com/ctg/Manual/c02983578
Mar 05, 2015 | HP Photosmart 5510 Wireless e-All-in-One...
Hp photosmart 5510 is giving ink system error 0xc19a0042
It either telling you your ink is low,or cartridges need a cleaning,which your machine will do that for you.
Nov 17, 2014 | HP Photosmart 5510 Wireless e-All-in-One...
Why won't my HP Photosmart 5510 copy?
first you confirm scanning is working or not if it is working fine there is no issue with printer, if it is not working problem found with scanner assay you need to contact hp service center....
May 04, 2014 | HP Photosmart 5510 Wireless e-All-in-One...
Hp photosmart 5510 will print black even with new cartridge. Help!
so it seems like evrythng okay
May 19, 2012 | HP Hewlett Packard Photosmart 5510...
I have an Officejet 5510 all-in-one printer/scanner/fax. When do a manual print (laying paper face down on glass), it works fine. When I use the automatic feed the copies have black lines along the entire...
You need to inspect and clean the narrow glass and the white reference bar that sits above the narrow glass. Scratches, whiteout, and debris will cause the lines on scanned documents.
Dec 24, 2009 | HP Officejet 5510 All-In-One Thermal...
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
HP Photosmart C3180 prints a solid black line left side of paper ONLY when you COPY. When you print from computer, it prints just fine. It is only from COPY mode that the solid black line appears.Already...
Unfortunately, your C3180 printer needs some repairs done to it or you . A section of the printing arm that does the printing is faulty. This happened to me and apart from replacing the arm (at considerable cost) I purchased a new printer at a much cheaper cost. You can use your faulty printer for printing from the computer but not for copying or scanning. MG
Jun 08, 2009 | HP Photosmart C3180 All-In-One InkJet...
Hp Photosmart 3110
I have changed the BLACK cartridge ( as suggested ) but still cannpt print or move breyond the PROBLEM Note that comes up to CHANGE the Yellow and Black Cartridge - I cannot SCAN or COPY leave alone PRINT - please suggest a solution - Thanks ,
Adrian
May 14, 2008 | HP PSC 2210 All-In-One InkJet Printer
Jun 25, 2007 | HP PSC 1610v All-in-One Printer
77 people viewed this question
k24674
