Question about KitchenAid Kitchen Ranges
HOW TO FIX A KITCHENAID SUPERBA SELECTRA DOOR HANDLE
DOOR HANDLE HAS FALLEN OFF
4 Suggested Answers
  • 254 Answers
SOURCE: Interior door glass cracked on my KitchenAid oven
thers the inner most glass then some inner glass packs then the outer determine waht u need take ur model and go to sears.com go to there parts direct or parts research link lookup ur model find the part number and a normal price ........anyways u are gonna have to take the door off and replace it, kinda hard to describr just have to get acesss inside and replace the glass... might need service might be cheaper if u have a local repair shop for u to take the door off and bring it in to them... to get that dooor off most have lil flappers or metal locks open the door fully inspect down by the hinge pulll those flappers back towards glass then move door to brooil position 3/4 way closed and lift striaght up... hope this helps reply or rate me if posible k thanks
Posted on Jan 28, 2010
aroracaty2
  • 503 Answers
SOURCE: kitchenaid supeerba selectra, cleaned oven
Most ovens with locking doors will be self-cleaning units, although you may on occasion find an oven with a lock intended to keep children from accidentally opening it while in use. There are two main kinds of locking ovens: Older models with manual levers, and electronic models with push-button controls, digital displays and electronic locks.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions
  1. 1
    Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  2. 2
    Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  3. 3
    Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  4. 4
    Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Sep 19, 2010
machinetech7
  • 1344 Answers
SOURCE: kitchenaide superba oven door handle
screw them back in, or get a little bit larger screws because those were not the ones that should have been in it to start with
Posted on Jun 06, 2012
Hi, I have a Selectra 30 and the panel has gone dark and the oven door is locked. If I unplug it and remove the back cover I can unlock the door manually. When I plug it back in the door locks again and...
First of all, why did you post a question about an oven under a dishwasher question? What is a Selectra 30? That is not the model number. The model number of the dishwasher in the subject does not help. Without knowing anything else, I would say you have a bad control board.
Dec 17, 2014 | KitchenAid Kitchen Aid Superba Series...
Kitchenaide superba oven door handle
Jun 05, 2012 | KitchenAid KESC307 Electric Kitchen Range
The handle has fallen off my stainless steel kitchenaid superba oven and screws go from inside edge toward front. Can't tell how to access without removing frame and that's another question!
Yes the door has to be disassembled to repair the handle. In some cases you can just loosen the sides and top and work with it on your lap without removing from the unit but it takes patience and an extra set of hands is nice to have around. Any visible screws have to come out first. Eric
Aug 18, 2010 | KitchenAid Architect Series KEBC107KSS...
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
Kitchenaid Superba Selectra 24
Before you decide to find out about the self cleaning feature... read this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
Heatman101
Mar 14, 2010 | KitchenAid KEBC107 Electric Single Oven
Kitchenaid Dishwasher Latch Broken
GET A FLAT HEAD SCREWDRIVER TRY TO PUSH THE LATCH TO OPEN THE DOOR...
Nov 02, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
Door Handle Loose and tightening with allen wrench does NOT work ...
Just did this on mine today. Use an allen wrench to back off both the upper and lower set screws (Note: you do not need to back them all the way out). The handle will then easily pull away from the door. With a 1/4" socket, tighten the screws holding the upper and lower lugs on the door. Place the handle back on and tighten the upper and lower set screws.
Jul 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
Handle loose on Refrigerator
I have same problem. Just called KitchenAid and they told me I needed a T-20 torque key - you can buy it from them or at a hardware store. Good luck.
Jun 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Open Questions:
Kitchen Ranges Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
