Question about Malber WD1000 Front Load Washer/Dryer
Burnt anti disturbance
Wd1000 has a burnt anti disturbance is this causing the machine not to dry
Malber WD1000 wont condense the water that is fed through during the drying cycle
Since it drains properly during the wash cycle, we know the drain pump and its impeller (propeller) work, and the coin trap (you called it a filter) and hoses are not clogged. By the way, turning the rightmost knob to "4" will start the pump-out cycle, so you don't have to open that trap-door at the bottom. To condense, the machine needs COLD water (spritzing on an internal screen) during drying. Make sure your cold water hose is connected to the outside (outboard) connection on the back of the machine. As a long shot: If the gray drain hose is pushed too far down into your home's drain pipe (more than 8") there could be a "back-siphon" where dirty water siphons back into the washer. It's a long shot, but it does happen.
Lastly, the controller board (mounted at top of right side) could be bad, and not sending on-off commands to the pump during drying. During drying, the drain pump should cycle on and off constantly, every few minutes. Do you hear it running? If you remove back (about 12 Torx screws), at your lower left you will see the pump. There are only 2 wires (120 VAC) and they can be connected either way. Stick a meter on the terminals and see if power is cycling on and off. If not, the controller board is bad.
You can order one from Malber (in NYC) by calling Nancy at 516-323-5299. Tell her Mike, in Wash. D.C., says hi.
Mar 06, 2015 | Malber WD1000 Front Load Washer/Dryer
Drying problem -
sounds like you have a washing machine problem , maybemore than a dryer . clothes should not be ringing wet from a washer ever.
Jan 20, 2015 | Malber WD1000 Front Load Washer/Dryer
How do I dry clothes
Either hang them up wet or put in clothes dryer
Nov 26, 2014 | Malber WD1000 Front Load Washer/Dryer
Malber WD1000 dryer timer starts running immediately when set, even in the middle of wash cycle
Call in the troops! You need to have the controller panel opened and checked for excessive lint and dirt. There is a short or two in that mess!
Dec 26, 2012 | Malber WD1000 Front Load Washer/Dryer
Malber wd 1000 just stopped working (power light won't go on) After a full wash and dry cycle the towels were still damp (started yesterday afternoon) was set to go through another dry cycle and it may or...
on my wd1000 i removed back cover and on top left side there is a electric/electronic component,i noticed a slight burn mark where one of the connections were.I cleaned and crimped it tighter and it has been fine ever since!
Sep 16, 2010 | Malber WD1000 Front Load Washer/Dryer
My Malber WD1000 over floas and does not dry = can you advise me
First off, I have found that my machine gets clothes 90% dry (or 75%). Also, when I first installed mine, I did not properly drain it. The drain hose you notice comes out the bottom of the machine, goes up to the top and then goes back down again. I had to take the hose from there back up again to create a trap that held the water so it did not flow back into the machine. (I figured this out by disconnecting the hose entirely and letting the water run onto the ground.
Hope this helps.
Feb 11, 2010 | Malber WD1000 Front Load Washer/Dryer
Malber wd1000
Two of the dials are dryer settings. There is only one washer dial, which basically controls the length of the wash and rinses, etc.
Apr 22, 2008 | Malber WD1000 Front Load Washer/Dryer
Malber WD1000 Dryer wont heat
I have a bit of experience with Malbers. When the dryer won't heat the most likely cause is the heating element wearing out. See my other posts to the same problem by saerching Malbers problems here. If you need more help, contact me.
Mar 16, 2008 | Malber WD1000 Front Load Washer/Dryer
Drying cycle malfunction
Unplug the dryer and replug back up again.
Put on wash /let it go thru the cycles.
Nov 27, 2007 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
21 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
