Question about Soleus 10,000 Btu Portable Ac Air Conditioner Heater Dehumidifier Fan X-lx-100
Using as heater and unit is blowing cold air
We are using the unit as a heater and it is blowing WARM air through the fan but cold air in the back. Why is that?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 215 Answers
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Posted on Nov 28, 2013
Sometimes it blows out warm air warm enough to warm an entire room, yet at other times is blows cool air that can kkep a room cool. I want it to blow cold at all times. how do i do that?
dry air feels cool on the skin
moist air feels warm on the skin
this is why the perceived temperature of air from unit changes
Apr 14, 2015 | Dehumidifiers
Using heater...cold air out of the back
With heat pumps that's the way they work. In heat mode they are using the evaporator as the condenser and it blows heat out the front and cold out the back. In cooling mode, a reversing valve switches the gas flow reversing the operation of the coils and it blows cold out the front and heat out the back.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
My dehumidier blows very hot air while working. Makes it hotter than it was before starting. Like a furnace.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in.
You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
Jun 26, 2013 | Windchaser WDH928 Dehumidifier
Why is the dehumidifier freezing up solid
Some units have a sensor and circuit to prevent this, because it is a common problem. If you can select a higher fan speed, that will help. If you can select a more humid setting (less drying), that will help. A simple work around is to use an extra fan for more airflow.
Jul 05, 2012 | Danby DDR4010E Dehumidifier
No water collected
check to see if the fan is blowing across the condenser. there should be warm air blowing out the back. if there isn't, the fan may need to be replaced so the heat exchanger can cool down. may be running too hot. also check the condenser in the front to see if the air flow is blocked with dust. if so, change the filter if it has one. if there is cool air blowing, the compressor may not be turning on.
May 11, 2012 | Dehumidifiers
Freezing up and bucket not filling
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils. To remedy this problem, you can try any of these: Warm up the room the dehumidifier is in. Put the dehumidifier on a sturdy table (the room air is coolest near the ground).
Turn the unit off until the room warms up.
Good luck
Aug 19, 2010 | Kenmore Dehumidifiers
Freesing up and bucket not filling
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils. To remedy this problem, you can try any of these: Warm up the room the dehumidifier is in. Put the dehumidifier on a sturdy table (the room air is coolest near the ground). Turn the unit off until the room warms up.
Take care.
Aug 19, 2010 | Kenmore 5230 Dehumidifier
This summer I have ice build up on top of the unit. I have a drain hose so the bucket is not full. I have cleaned the air filter. I have also removed the front grill and used a fine brush to remove dust...
Take care.
Aug 12, 2010 | LG LHD45EL Dehumidifier
My dehumidifier ices up. It will not remove moisture when it ices up. What can I do and is it under warranty?
Take care.
Aug 10, 2010 | Fedders A7DH45B2A Dehumidifier
The dehumidifier is blow cold air
Is it collecting water? The air coming out the back top half should be cool/warm. It will be a little warmer at the bottom near the compressor.
Apr 07, 2009 | Kenmore 54701 Dehumidifier
Soleus 10,000 Btu Portable Ac Air Conditioner Heater Dehumidifier Fan X-lx-100 Logo
376 people viewed this question
Top Soleus Dehumidifiers Experts
jeff5may32
john h
AZBen
AZBen
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
