Question about Soleus 10,000 Btu Portable Ac Air Conditioner Heater Dehumidifier Fan X-lx-100
Using heater...cold air out of the back
We are using it on heater mode right now but cold air is blowing out of the back. Why is that happening?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 215 Answers
With heat pumps that's the way they work. In heat mode they are using the evaporator as the condenser and it blows heat out the front and cold out the back. In cooling mode, a reversing valve switches the gas flow reversing the operation of the coils and it blows cold out the front and heat out the back.
Posted on Nov 29, 2013
Why is it blowing cold air?
A dehumidifier should blow cold air Carole. It takes in warm moist air, chills it, condenses the water out of the air and returns it chilled and dry to the room. That is the function of a dehumidifier. They often have the function of an air conditioner and blow cold air out of one outlet into the room and hot air out of the window via a venting hose. If yours is just a dehumidifier, it is working as designed
What were your expecting a dehumidifier to do?
Jan 15, 2016 | Amcor Dehumidifiers
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
My dehumidier blows very hot air while working. Makes it hotter than it was before starting. Like a furnace.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in.
You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
Jun 26, 2013 | Windchaser WDH928 Dehumidifier
No water collected
check to see if the fan is blowing across the condenser. there should be warm air blowing out the back. if there isn't, the fan may need to be replaced so the heat exchanger can cool down. may be running too hot. also check the condenser in the front to see if the air flow is blocked with dust. if so, change the filter if it has one. if there is cool air blowing, the compressor may not be turning on.
May 11, 2012 | Dehumidifiers
MY dehumdifier is blowing warm air ,Is there a fitler that needs to be cleaned and how is this done ? Model 3fdl5051 50pints
It's not unusual for a dehumidifier to blow warm air. As it may be in defrost mode. Even so, they still blow warm air.
The model number you furnished is slightly helpful. Knowing what brand it is, would be even better.
Never-the-less, the filter should be located behind the front louvers of the unit. Turn the Master ON/OFF Switch to OFF and unplug the unit. Remove the water collection bucket and look up inside the bucket holder, just behind the front louvers. You may see a plastic pull tab handle. If so, that's the filter frame. Pull it straight down and out.
If you didn't find it there, look on the right hand side of the unit, just behind the louvers for what looks like a a flip open door. If you see that, flip the door open and remove the filter.
The filter can be cleaned using a vacuum cleaner or if it's really dirty, wash it in warm water and dish washing liquid. Thoroughly rinse and allow to completely dry, before reinstalling it. NEVER operate the unit without the filter in place.
Hope this helped you. Please let me know. Thanks.
Jul 12, 2011 | Frigidaire Dehumidifiers
My dehumidifer collect water but the fan blows hot her so it makes the room hotter
This may be caused by running the unit in continuous mode, rather than timed mode. The heat is generally is generated when the defrost mode cycles on, to defrost the cooling coils. This happens more frequently, if the air space around the unit is obstructed or it's operating in a temperature range of 40 to 60 F. Cleaning the air intake filter at least once a week, can help solve this problem, too.
Maintain a minimum of 12" free air space around all sides of the dehumidifier. Use a timed mode rather than a continuous mode. Make sure the room is within the proper operating temperature range and clean the air intake filter weekly.
Hope this helped you troubleshoot and solve the problem.
May 28, 2011 | Maytag M7DH65B2A Dehumidifier
It blows cold air while in heat mode
I have the same problem, I have a defect in the heater electric circuit, 2 small electronic things that looked like small pens with red end, no idea yet what they do, are located directly onto the heater element are faulty, I bypassed them to test the heater and it worked, either one or both requires replacement, tomorrow I,ll go to adisson buying the 2 for 99 cents each, re-weld the circuit and bang, ready to run for another couple of years
Feb 15, 2010 | Danby DDR586R Dehumidifier
Unit blows out cold air while on dehumidifier
Liz; Check for a fuse somewhere in the heat circuit. The master breaker in the house panel also
Jul 07, 2009 | Dehumidifiers
The dehumidifier is blow cold air
Is it collecting water? The air coming out the back top half should be cool/warm. It will be a little warmer at the bottom near the compressor.
Apr 07, 2009 | Kenmore 54701 Dehumidifier
30 pint model # M30H3082A
A common problem - low on refrigerant. Unfortunately it's not a simple fix. Check your warranty to see if you're still covered for "Sealed system repairs"
Nov 30, 2007 | Kenmore 54501 Dehumidifier
Soleus 10,000 Btu Portable Ac Air Conditioner Heater Dehumidifier Fan X-lx-100 Logo
250 people viewed this question
Top Soleus Dehumidifiers Experts
NOEL
NOEL
J.D. Browning
J.D. Browning
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
