Washer made horrific squealing sounds during the spin cycle. Tilting it up and examining the belt showed pieces of the melted belt stuck to the pulley on the top right. What needs to be replaced besides the belt?
SOURCE: Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
SOURCE: IUs very loud during spin cycle and you would
It appears Maytag no longer produces the type of quality product we have purchased since 1970... we've owned three Maytag Washers - our last "performa" is a piece of ****!
