Question about Motorola Xts2500 Holster/carrying Case
Looking for"bungie" holder
This is the little stretch loop that attaches to the back of the holster, comes over the top and loops down over the antenna to hold the radio in. This case is "open face" to accommodate use of the key pad on the model III. Any one having a couple of these or know where I can get them please write to carlmayo1948@hotmail.com Thanks
  • Francis Baker
    Francis Baker Nov 27, 2013
    This is the small elastic loop attached to a single snap that attaches to the back of the radio holster and loops OVER the antenna to hold the radio in place. I don't know if Motorola or anyone else still makes this type of swivel holster or not.
  • Motorola Master
  • 1,654 Answers
The carry case will have a number embossed on it somewhere. With this number you can contact your local Motorola dealer and ask them to contact Motorola Parts ID to obtain the part number of the bunge you are needing. The dealer may have spare or used ones on hand and could help you.
Best regards.
Posted on Nov 27, 2013
2 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: I am looking for the battery, 3AA batteries,
Sorry, parts were never made available for this unit. Your best option is to acquire a spare from ebay for parts.
Best regards.
Posted on Oct 10, 2011
Pre-attached chain with loop-hook
Most BBQ makers know that their ignition system will be the first thing to break so they give your a small match holder. The loop holds a short match so you can lower it down to light the burners manually, the chain just connects it to the grill so you don't lose it.
Jan 04, 2014 | Char-Broil Grilling
The stiches are looping on the underside of fabric.I have tightened the top tension to its maximum.I have the correct sized needle, the machine has been oiled and it is threaded correctly. What else can I...
There is an adjustment on the bobbin holder - the little screw on the plate. Make sure that the bobbin is tightly wound and that it is correctly inserted, the thread must double back on itself coming out of the holder.
Feb 19, 2011 | Vacuums
Ink cartridges will not move in place error # 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 - Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont...
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn't move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Jan 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
It wont print and everytime i try to print it says error #1200
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable2_bing.gif to reveal the gold screw beneath
7. Remove the ink cartridges2_bing.gif out of their carriage.
Figure 6 - Displays ink cartridge2_bing.gif carriage with ink cartridges removed.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
9. Lift the front cover open (if not already open) and plug in2_bing.gif the X4270. Cartridges should move to center as if preparing for replacement.
Click Here for the Documents
May 03, 2010 | Lexmark X4270 All-In-One InkJet Printer
Cartridge error 1203
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Posted by LEH at 5:39 AM
Labels: Lexmark x
1 comments:
MarCrazy said...
Lexmark X4270 Error 1200 Fix - Use link below to see how to fix
Text version below use link above to see pdf with images.
5. Cont…
February 27, 2010 10:27 AM
Feb 06, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error 1203
or
Labels: Lexmark x
1 comments:
MarCrazy said...
5. Cont…
Feb 02, 2010 | Lexmark X4270 All-In-One InkJet Printer
Cartridge error No. 1203 - LexmarkX7170 All-In-One
or
Labels: Lexmark x
1 comments:
MarCrazy said...
5. Cont…
13. Reattach the lever to the bottom assembly and slide back into place inside the X7170
15. Reassemble X7170 using steps 3-7.
Jan 21, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Broken Paper Roll Holder
You must google to find the manufacture to find if anything is still available; but I have 2 ideas : 1. form a hard wire loop (from coat hanger or #12 guage steel wire) and attach this wire loopto the back of calculator case with screws (you'll need to make an eye loop at one end for the screw to go through). 2. make a small wood block that sits on the desk or table and make a wire loop that is held by the wood block and of course the paper roll is held by the wire loop. Goodluck, Macgivor.
Dec 07, 2009 | Victor 1430-3 Calculator
Rival Crock Pot Travel locks
I used two pieces of light bungy cord from ACE Hardware and made loops to go from the handles on the crock then around the handle on the top. They stretch so you can't break the cover or crack or mar any surfaces. I made some longer ones for my NESCO. Works like a charm.
Dec 31, 2007 | Rival Crock Pots & Slow Cookers
How do I get the seal back on the inside drum
I did it! Thanks Paul, now I can cancel the repair guy that was scheduled to come in
two weeks.
No, you don't have to remove the front panel
To replace the boot gasket you first have to remove the old one. start by removing the outer ring, I used a needle nose pliers on the eyelet to stretch the spring a bit. This allowed for room so the ring came off of the outer gasket lip. To remove the gasket
off of the drum apply some down ward pressure on the gasket at the bottom. The
gasket will pop off in that spot, now just pull the rest off. I the used my needle nosed
pliers to pinch the clamp that holds the gasket to the water hose. The old boot gasket is now free from the machine.
Now to put the new boot gasket back on. A little tricky, be patient.
As you might have noticed there is a spring ring that will be holding the gasket once it is in place, put that aside for now. I followed Paul's advise, start the gasket at the top, work down one side then the other a little bit at a time, until the bottom is pushed
into place. Then came the spring ring part. That was tricky, I had to ask my 9 year old little girl to help dad. Note, keep the spring ring attached, It kept wanting to unhook itself. Start at the top, like you did with the gasket. I had my helper hold down the portion that was in place, while I worked the spring ring around some more.
Once the boot gasket is attached to the drum, attaching it to the outer ring is a piece of cake.
Nov 17, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Motorola Xts2500 Holster/carrying Case Logo
46 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
