Question about Dell TrueMobile 1184 Wireless Broadband Router (802.11b) 9U555 (9U555)
Router and aol
How can i setup the above router with aol for my laptop?
  • 49 Answers
Connect the Router to the modem using Ethernet wire and then connect the laptop with an ethernet cord also and run the set up cd. make sure you get the right cabling.
and if you wnat to go wireless , then after running the set up cd, and was successful to make the wired conenction worked, then you can unplug the laptop now from the router and check if able to detect signal form router. usually you will get the prompt on the lower right hand cormer of the laptop.
then if is able to detect the signal, then log -on to that network.
Posted on Oct 13, 2007
SOURCE:
I use AOL as my ISP, with British Telecom supplying my telephone line rental. On Friday 2nd my internet connection kept dropping out, and then eventually stopped connecting altogether. My original router...
If BT tested the phone line is OK but did AOL test the connection to the Netgear router and get the IP address of your Netgear router.
The phone connection is OK but the ADSL connection from the telephone exchange may not be working, that is why you are not getting an ADSL light.
Jul 12, 2010 | NetGear DG834 Router
I have a new laptop and although the wireless is turned on on the laptop, and my router is turned on and plugged in, the green light under 'WLAN' is off?! i have contacted aol who couldnt help and said it...
try going to the setup of your router by typing 192.168.1.1 in the address bar, going to wireless section and make sure it is enabled. also check what mode it is transmitting on ie mixed or B only or G only
Oct 01, 2009 | Computers & Internet
Wireless Connection
The WPA code is the password to access the router's network, so it can use your internet connection. As long as the Xbox has both the SSID and the WPA password, it can access the internet through the router.
The SSID ( Chris_PC_Network ) is mostly irrelevant to the network connection, and is purely aesthetical. Its only use is to help users distinguish between different networks (so you don't use a neighbor's network or vice versa).
May 24, 2009 | HP Pavilion dv6000z Notebook
Wireless connection problems
Its hard to diagnose cause the process starts long before your current setup..ie, programming your router. So I have attached a website from Microsoft that walks you thru the steps to set up your wireless home network so you can backtrack...good luck and let me know if you have any problems. Pls rate this solution.
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx#step3
Apr 20, 2009 | Lenovo IdeaPad Y530 Notebook
NetGear WGT624 Wireless Router
Was this in a sealed box and did you get instructions?
Out of the box, a Netgear router is fairly easy to set up. If you don't have a manual, here's a link to the quick setup guide.
ftp://downloads.netgear.com/files/WGT624v4_SM_30Apr07.pdf
Note on pdf page 20 that if you've somehow screwed it up, you can take a paper clip and reset the box to default. Then follow the manual setup instructions from the beginning of the document.
Carl
Sep 05, 2008 | NetGear WGT624 Wireless Router
New HP dv9000 lap top. cannot load sbc dsl from CD please advise
download the sbc setup software then it will let you setup the router then uninstall aol
Mar 02, 2008 | 2wire (1000-400108-001) Router
NetGear DG834G Router
First use the Netgear setup wizard:-
Open Internet Explorer
Enter http://routeraddress e.g http://192.168.0.1
Click Setup Wizard (top left)
Then for With AOL make sure you have set these values in the Netgear
ADSL settings as PPPOa
VC 0,38
MTU setting to 1400
If you still have problems
Start -> Control Panel -> Add/Remove Programs -> select AOL Connectivity
click Add/Remove -> use the repair option
Follow instructions to repair.
Once complete make sure modem is configured and switched on and
try restarting AOL.
It should search for your connection, find it and allow you to log on.
Feb 06, 2008 | NetGear DG834G 54 Mbps 802.11g Wireless...
Thomson SpeedTouch 576 wireless modem router
Connect your wireless modem router Sign on to AOL. Download the AOL Easy Installer for Thomson 576 Wireless Modem Router. When prompted to save the file to a location select an appropriate place (desktop is a good example). Once the AOL Easy Installer is downloaded, double click the file: ST_V1.exe This will launch the modem router installer and show the "Welcome" screen. Click the Start Installation button to continue. If you wish to cancel, click the Cancel Installation button. Read the next page carefully. The text advises to close any running programs, ensure to close your AOL software also. Click Next to continue. Please Note: Connect a DSL filter to each telephone socket that is in use for telephones, dial-up modems and fax machines, etc. If you require additional DSL filters, order online at AOL Keyword Broadband Extras. Notes: Ensure to use AOL 8.0 or above. The AOL account to be used for the modem router set up must be a General (18+) account. This installer is not supported with a modem router containing beta firmware.
Apr 24, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
AOL Broadband Cable
The following routers are the only models that support the AOL Broadband Cable service. Note: All Linksys routers support AOL DSL connections due to the standard PPPoE login and authentication connection type used with that service. Please be sure to check the version number of your router (which can be found on the underside label). Only the specific models and versions listed here are supported by AOL Cable: * BEFW11S4 * BEFW11S4 v2, v3, and v3.2 * BEFSR41 * BEFSR41 v2 * BEFSR11 * BEFSRU31 * BEFSR81 * BEFSR81 v2 * HPRO200 (Available from AOL only at this time) You must Enable the "AOL Parental Controls" option located in the Security tab of the web-based Setup utility pages of these routers in order to get a connection using AOL Cable. You may access the utility by visiting http://192.168.1.1 in a web browser and by logging in using the router's password (by default, the password is admin).
Feb 16, 2006 | Linksys HomeLink Phoneline (HPRO200)...
Dell TrueMobile 1184 Wireless Broadband Router (802.11b) 9U555 (9U555) Logo
78 people viewed this question
Ekse
Clive
Clive
