Question about Keurig K45 Elite Brewer
Brewing slow or not at all - Keurig K45 Elite Brewer
    Sergeant:
  • 479 Answers
Have you cleaned the water system sometimes using vinegar will help or a proffesional cleaner
Posted on Dec 23, 2013
Coffee brewing to slow
Have you taken the sprayhead off (remove basket and look up)? This copper tube gets clogged with lime/calcium and needs to be cleaned. They have a delimer that usually comes with a new bunn, (12 inch coily spring) that needs to be ran up the tube that the sprayhead is connected to. If it is still slow after that, the the tank itself has a buildup inside.
Feb 28, 2014 | Bunn NHB Coffee Maker
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
Why is my coffeemaker taking more than 4 minutes to brew a pot of coffee
  1. Be sure that your SPEEDBREW® Coffeemaker brew control dial is set to 'Brew Regular' when brewing regular coffee. Please note that using the 'Brew Decaf' setting will slow the brewing process. It is recommended that the 'Brew Decaf' setting be used when brewing decaffeinated coffee.
  2. Your SPEEDBREW® Coffeemaker may need to be cleaned.
Sep 02, 2011 | Keurig B50 Coffee Maker
Slow brewing
The coffee maker has three contributory factors for brewing experiences. First, putting enough water in container prior to brewing is expected to dispense in to coffee capture cup. Second, installing the component parts after inserting coffee leaflets should not hinder brew seepage into the cup. Third, allowing enough time for the brew to dispense is a requisite means to coffee impressions. Furth, coffee leaflets require appropiate numbers inserted at the container area lest the machine takes time to sock and dispense. However, refer to the device user guide for appropiate manufacturers instructures to user as expectations during brewing. Also, refer to the user guide to ascertain any conditions that may be signs of damage preventing fast brewing.
Jan 22, 2011 | Oster HDX23 12-Cup Coffee Maker
Will not brew
mcdevito75 here, Your coffee maker may need cleaning, specially if the brewing is very slow or a lot of steaming is happening when trying to brew. Or your machine is faulty. If the water doesn:t move from the resovoir to the brewing spot the machine is faulty and will have to be replaced.
Jul 10, 2010 | Cuisinart DCC-2000
Saeco Odea Go - slow to brew coffee, comes out of steam valve
The steam valve needs to be replaced, because the pins have been damaged from high pressure buildup, could have been caused from a very fine grind. You can also check the screen in the brew unit that might be blocked and causing the high pressure backup.
Nov 14, 2009 | Saeco Odea Go
Slow to brew
Make sure you are not using a paper filter and a gold tone filter at the same time.
Make sure the carafe lid is down all the way and that the center knob of the carafe lid is making contact with the spring at the bottom of the filter basket.
If the above conditions have been met, then decalcify your coffeemaker by running 1/3 carafe worth of vinegar and 2/3 carafe worth of water through your coffeemaker - use the self-clean button to do this - will take about 35 minutes.
Aug 23, 2009 | Cuisinart DCC-1200 Coffee Maker
Alternatively slow brew and water under drip tray
when you remove the brew groupyou see a plastic piece with 2 seal on it at the bottom of that there like a funnel with little hole hole get block with old coffee clean that so extra pressure come out thereif its block its should be full of water in there and for our slow brewing did you change coffee brand defferent expresso bean diff setting dont forget if you move the setting 1 move it only when our grinding coffee 2 when you move the setting dont forget to make a least 2 or 3 cup before moving the setting again let me no pierre
Jan 09, 2009 | Saeco Vienna De Luxe Espresso Machine
Brew time
this is not the norm. Sounds like a blockage problem. Descale the machine twice!!!! one after the other. and that should take care of it
Jun 20, 2008 | KitchenAid KCM514 Coffee Maker
Brew time
If you have hard water, minerals may have built up in the unit, slowing down the flow. You should be able to find some sort of mineral-dissolving treatment for it at your local grocery or hardware store. Make sure to run a few pots of plain water when you are done, to get any residue out!
Feb 21, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
Keurig K45 Elite Brewer Logo
677 people viewed this question
Top Keurig Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Keurig Kitchen Appliances - Other Expert? Answer questions, earn points and help others
