Question about Memorex MT1194 19" TV
Memorex MT1194 19" TV horizontal out - Memorex MT1194 19" TV
Tv thomson black screen
this a problem from Raster, coming from HV flyback, rectifiier, horizontal output, and circuit from HV. repair.or go to the repair shop TV for fix it.
However you must reset the code, download from www.fitness.manualsonline. com or memorex.com or www. remotecodelist.com and try it again.
God bless you
Jul 22, 2012 | Thomson RCT311DA1 Remote Control
I have a horizontal line through the tv with no picture
By now you've probably replace this with a Flat Screen LCD, LED or Plasma unit. But the answer to your original problem is a loss of vertical drive. Possibly just a bad solder joint @ the vertical IC.
Apr 12, 2012 | Memorex MT2274 27" TV
My tv has a black screen with a horizontal line across it, but i do get sound
Turn the T.V. off. Your could burn that line into the T.V. Your Vertical IC probably has a bad connection or went bad. It's got about between 5 and 8 pins on it. Try resoldering the connection points on the board before taking it in.
Jun 16, 2011 | Memorex MT2271 27" TV
I have sound but have a black screen with a horizontal line across it
your picture tube may be malfunctioning -- all of the information for the screen is being squished into that horizontal line. If this is the case, you can buy a new picture tube and install it, but that would be the only fix. the only other thing I can think of that might cause this issue would be if you have a large speaker next to your TX. The magnet from a large speaker can distort the television, but it usually gives you a funny green distortion near the magnet without killing your whole screen so it seems unlikely that this is your problem.
May 26, 2011 | Memorex MT2271 27" TV
Tv wont turn on
If you want to DYI this tv yourself be careful for voltages.
Check the power board for standby +5 volt to the power botton.
If there is none, check the powerboard for open contacts; fuses, fried resitors or the FET. A photo-coupler sometimes is also the problem. Its a small black part with 4 to 6 pins that overbridge and regulate the need for voltages from the main and the powerboard.
If there is power but the tv still wont start, check the horizontal output.
Success
Aug 26, 2010 | Memorex MVD2019 19 in. TV/DVD Combo
Memorex MVUC821 TV/DVD. Everything works except the TV.
Just bought the Memorex MVUC821 & the DVD Player will not open using the remote or front panel button!!!
Mar 23, 2010 | Memorex MVUC821 Player
Horizontal line across screen
HELLO
This is called "Field Collapse". Line collapse is different (a single vertical line) in the centre of the screen.
But field collapse is usually a fault in the field circuit (possibly a field output IC has gone short circuit) or electrolytic capacitors have dried out. The same can happen in a CRT TV - looks as if LCD panels are the same way! I think you will have to take this to a service centre.
GOOD LUCK! (:-)
Sep 12, 2009 | Memorex Televison & Video
Programming Device Control code for Memorex MVT2135B
21479 is the Sansui code that worked for me with the Memorex TV/VCR combo MTVT2135 and the Comcast Custom DVR 3 Device remote.
Jan 20, 2008 | Memorex MVT2135 13 in. TV/VCR Combo
TV makes a reoeated cricket sound & won't turn on.
You have a short somewhere in your set. Most likely the horizontal output transistor.The sound that you are hearing is the power supply being overloaded. If the horizontal output is shorted, you probably have a bad flyback (high voltage) transformer. You need to have it checked out by service tech also ask for an estimate. Stargazer
Mar 25, 2007 | Memorex MT2271 27" TV
Memorex tv
There is a capacitor going bad and is not charging all the wayor it takes a while to charge,is an electrolitic cap so it has polarity and the replacement needs to be conected the same way,the circuit board has the marking were the negative and the positive are and the cap is marked too,he should be a 1.5 microfarad at about 160 volts and sometimes is close to the vertical Ic,if you are familiar with tv service this information should help but if you are not too familiar seek the help of a servicer,it should not be too expensive,the vertical IC might need to be resoldered.Let Us know if you need more help.
Oct 10, 2006 | Memorex MT2206 TV
Memorex MT1194 19" TV Logo
20 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Radames Pagan
Radames Pagan
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
