Question about Roper REX4634KQ Electric Dryer
Runs no heat
Put newheating element on it still wont heat
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Check for 220v will not heat with only 110v
Posted on Nov 25, 2013
Honeywell wiring diagrams
WE R GOING FROM A HONEYWELL TAYSTAT500 THERMSTAT (HEAT PUMP) TO A NEW HONEYWELL to (WHOLE NEWHEATING/AIR CONDITIONER) WITH A HONEYWELL RTH8580WF1007 THERMOSTAT? WHERE WOULD THE C WIRE BE. WE DO NOT HAVE A WIRING SCHEMATIC FOR THE OLF THERMOSTAT. IT HAS 7 WIRES. HELP?
Jan 10, 2014 | Heating & Cooling
Newheater core new thermostat clean hosesnew anti freeze why no heat?
Depends.
Are the heater hoses getting hot ?
Is the engine warming up to normal temp ?
If yes, you could have a problem with a blend door under the dash.
The blend doors direct air thru the heater core and the vents.
Dec 23, 2012 | Cars & Trucks
How do i change the element on a samsung dryer
Hello.
When the dryer just isn't getting your clothes dry anymore, the culprit is usually the heating element. The dryer part may look intimidating, but you can replace the heating element.
Step by step instructions
TOOLS NEEDED New heating element,Screwdriver, Needle-nose pliers.
1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
4 Unscrew the screws holding the element in place and pull it out.
5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Thanks.
Sep 26, 2011 | Dryers
My amana dryer wont put out heat. I've taken the heating element off but it doesnt look broken anywhere. I changed the fuse on the element 2 months ago because it wasn't putting out heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 21, 2010 | Kenmore 62602 Electric Dryer
My dryer wont heat up or shut down
It's not heating up because the heating element is broken and should be replaced. It won't shut down because the thermostat isn't sensing heat and continues to run while expecting heat. So replacing the heating element should get it running properly.
Mar 23, 2010 | Whirlpool LER5636P Electric Dryer
Wife put washing up liquid into the machine and let it run it was full of bubbles and now it wont heat the water think the element is gone but the timer wont move past the heating stage if i replace the...
if you put manual detergent that hapend, it could burnd electronis card (or mechanical timer-programer blowup), thermostat or the presostat, the heating element must be OK.
Feb 23, 2010 | Dishwashers
Heating element is out.
Instructions Things You'll Need:
  1. Step 1 Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
  2. Step 2 Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
  3. Step 3 Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
  4. Step 4 Unscrew the screws holding the element in place and pull it out.
  5. Step 5 Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
  6. Step 6 Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
  7. Step 7 Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Dec 01, 2009 | Kenmore 62602 Electric Dryer
Heat elament is out
  1. Unplug the dryer from the wall before starting. Find the dryer heating element cabinet. For most dryers this is located in the back, however it can be in the front. Find the compartment on the dryer.
  2. Remove the screws or clips to get into the compartment to expose the heating element and wires. Use a needlenose pliers to carefully remove the element wires.
  3. Detach the can shaped object that may cover the heating element. Tip the can backward to slip it off the hooks holding it in place. Some models place the heating element with the can, while others provide easier access to it.
  4. Unscrew the screws holding the element in place and pull it out.
  5. Put the new element in place, and replace the screws to secure it in the dryer. Put the can back in place and connect the element wires before putting on the cabinet cover.
  6. Run the dryer on fluff with no heat, and go outside to make sure enough air is getting through the vent system.
  7. Break the new heating element in by running your dryer on high heat for 10 minutes without any clothes in the dryer. This cleans oily residue off the element and keep the clothes from getting smoky.
Sep 23, 2009 | Washing Machines
It runs but timer wont advance dryer wont heat.
did you change out the limit switches? they control the heat to the element... and it sounds like you need a new timer
Jan 22, 2009 | Whirlpool GGQ8831L Gas Dryer
Kenmore 80 series dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
Roper REX4634KQ Electric Dryer Logo
35 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
