Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
I have a SAECO VIENNA SUPERAUTOMATICA (230v) which is 10 years old. Last week I started to make coffee, heard a pop, hiss and then steam came out of the top two vents. Subsequently, when attempting
My SAECO superautomatica is approx. 10 years old and 230v (bought in Germany). Last week I started to make coffee, heard a pop, hiss and then steam came out of the top two vents. Subsequently, when attempting to make coffee, 1) the water leaks into the bottom housing; 2) coffee grinds show up dry in the drawer; 3) no water or coffee comes out of where it should; 4) no steam or water will come out of the wand; 5) it takes longer for the water to heat up. Is this the boiler/coil (or something else) and if so, how do I fix it? Appreciate any help. Thanks
SOURCE: Saeco Vienna superautomatica Machine
if you open the steamer, does it work correctly? and if u request hot water does it come out?
if not, then its the pump..
Posted on Dec 30, 2007
  • 1089 Answers
SOURCE: need to take out brew group jammed
Hi
Look on the left side where the box should be. In the left side towards the botton there is a long opening. Take plastic knife and slide it in while the machine is on and blinking and see if the brew unit will cycle. The drip tray has to be in for this to work. There is a metal bar that has to be pushed toward the rear of the machine to cycle the brew unit.
Posted on May 22, 2009
EsWorld
  • 1618 Answers
SOURCE: My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Posted on Apr 07, 2010
espressonist
  • 1711 Answers
SOURCE: how do I clean my Saeco Vienna SuperAutomatica
In order to proceed with decaling of the espresso machine you need to have the solution appropriate for decaling an espresso machine.
Different brands of espresso machines, like Krups, Saeco, Gaggia e.t.a. have their own brands of decaling solutions. You should know that all of these are similar products so you can use them in all different bands if you don't have the one of you specific brand without any problem. So if you have Krups machine and you can only find Saeco decaling solution you can use it with the same results.
One thing you should have in mind Never use any Vinegar as a decaling solution since this will destroy some parts of the machines not instantly but in long term since vinegar is corrosive to this parts.
So the first thing is to remove any water fitters or small softeners that are included in you water tank. Fill the water tank with water up to maximum, dissolve your solution in the water you do need only two to three spoonfuls of solution.
Switch on the machine and wait to warm up. When the machine is ready you can turn the water knob and start getting some water in a pot. Leave it for a couple of minutes and then again the same. Do these until you draw off all the water with dissolve solution. After that leave the machine for more than 20 minutes. Remove then the remaining water with solution from the water tank, rinse it and fill it with fresh water. Now draw again continuously hot water from the machine in order to rinse it completely.
The last portion of hot water taste it to be sure that is pure clean and if not refill the water tank again and perform another rinsing.
Now the machine is ready to be used again.
Try to do decaling every 20 to 30 days.
If you plan to leave the machine unused for along time perform a decaling in order to avoid the possibilities of having the machine stuck when you will try using it again after a long time.
A machine which is used frequently every day is more secure to work fine even without any decaling but machines which are used rarely is more possible to have problems of stacking out in water outlet or coffee outlet.
Posted on Jul 01, 2010
craig6773
  • 116 Answers
SOURCE: Where can I obtain a User Manual for a Saeco
http://saeco-usa.com/download/pdf/manuals/vienna-plus_en.pdf
Posted on Dec 02, 2010
Can I repair it myself?
Notice if you can hear the pump when you are opening for steam.If you dont hear it ther is a problem at the switch.If you hear it then the tube is just blocked with milk.
Apr 29, 2014 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna super automatica coffe maker produces very little coffee and it comes out very slow.
sounds like your pump. When you turn steam knob on, you should hear the pump go bump,bump,bump. When hot water is turned on, you should hear pump run steady.
Jan 07, 2013 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna leaking water from bottom of machine
The o-rings of the water tube coming out of the boiler need to be changed. Rubber O-ring tend to expand after extended exposure to heat.
Jan 03, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Superautomatica will not make a full cup of coffee
I'm wondering if you had any luck solving this? After 3 years of great coffee, my machine is only making a 1/4 cup or so. All parts are clean. I'm guessing something on the circuit board that the dial is attached to....thanks!
Feb 27, 2010 | Saeco Vienna SuperAutomatica Coffee...
Coffee and steam lights flash after using steamer and will not go solid
Hi
Once you have finished steaming, turn the steam button off, then open the knob and let the steam out. The water pump will turn on again and bring the temp back down. When the pump changes tone, the light will go off and you can brew again. It takes less than 10 seconds.
Dec 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
The nozzle for steaming is leaking.
The tap rod on the steam valve needs to be replaced.
May 08, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna "machine ready" light (second light) blinking--not allowing to dispense coffee.
Try to open the steam knob and make a cup of water(Tea).
Best regards
/Mirran
Oct 21, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
111 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
