Question about Acer Aspire Z5600 PC Desktop
Touchscreen not working.
Bonjour! My touch screen seem not to work. Well, the touchscreen doesn't, everything else does. - I've had this problem before and I've re-installed the PC so the touchscreen started working. - Now, I don't want to re-install my PC because then I'll lose my important files. So anything apart from re-installing the All-in-one will be AWESOME! Cheers.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 265 Answers
Do you hear a beep when you touch the screen? If you do it is more than likely a software issue, or the cameras are misaligned..
First thing to try is Scroll Lock Calibration.. Press Scroll Lock on your keyboard 5 times quickly, your cursor should move to the top left of your screen, press and hold your finger on it until you hear a beep, remove your finger and itshould automatically move to the top right, repeat for each corner, when it is done the cursor will move to the middle of the screen, and the touch screen should be working
If the computer does not beep when you tocuh the cursor and the cursor does not move when you remove your finger it means your touch is not being recognized... it could be a software or hardware issue, here is one way to find out..
First do a power drain.. shut down the computer and unplug everything from it (including the power cord) and press and hold the power button for 30 seconds.. Now boot the computer into BIOS by tapping F10 on startup.. inside the BIOS touch the screen.. do you hear a beep? if so it is a software issue, if not more than likely it is a hardware issue
A few other things you can try... open the Touch Screen Configuration Tool inside the Control Panel, make suire the touch screen and sound are enabled, select the Troubleshooting tab, click Restore Defaults, try the Calibration function... beyond that you could try System Restore/System Recovery..
Good luck
Posted on Nov 25, 2013
  • Edmunds Laucis
    Edmunds Laucis Nov 25, 2013
    Excuse me, I bet that I have a hardware issue then :/
  • Edmunds Laucis
    What can I do with that?
4 Suggested Answers
SOURCE: I installed my roomates dell xp pro sp2 on my acer
Purchase a legal copy. You can buy Vista with a downgrade option.
Posted on Apr 02, 2009
SOURCE: acer aspire z5600 touchscreen not working
see other solution
Posted on May 26, 2012
maxcarson
  • 7627 Answers
SOURCE: aspire 5600U touchscreen not working
Have you rebooted the machine?
Posted on Feb 23, 2013
TOUCH SCREEN DOES NOT WORK
There are three (3) possible Answers:
First: Your unit does not have TouchScreen.
If the part number has CF30xTxxxxx then the "T"=TouchScreen.
If your unit has touchscreen then,
Second: The TouchScreen may be disabled in the BIOS.
Check the BIOS and see if TouchScreen is "ENABLED".
If it is DISABLED, then ENABLE it usually by pressing
the spacebar key while it is highlighted and then
SAVE and EXIT the BIOS.
Third: You do not have the Touchscreen Drivers loaded.
Locate these drivers at the Panasonic Website:
http://pc-dl.panasonic.co.jp/dl/
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
Mar 17, 2014 | Panasonic Toughbook CF-30 Notebook
Garmin Nuvi 1300 touch screen not working
It sounds like you need your touchscreen replaced. The touchscreen is soldered to the LCD display, so the touchscreen must be unsoldered from the LCD display and a new touchscreen resoldered to the LCD display. Please do not attempt to do this yourself. You can easily damage the LCD display in the process. More information about touchscreen replacement can be found here:
http://www.sharc.net/gps_LCD_repair.htm
Apr 21, 2013 | Garmin nuvi GPS
My v touch pro touch screen wont work
b> The Touch Pro2, manufactured by HTC, is a smartphone designed to be used with the Verizon wireless phone network. This smartphone combines a cell phone, PDA, MP3 player and wireless Internet access into a small, portable device. If the device begins malfunctioning or freezing, you can perform a soft reset. A soft reset does not delete any of your saved information. It shuts the phone down and reboots the phone to the Verizon Today Welcome Screen.
Pull the stylus upward to remove it from the side of the phone. Push the back cover upward using your thumbs until it pops from the back of the Touch Pro2 phone. The back cover can then be lifted away and removed from the phone. Press the "Reset" button, on the upper, left side of the back panel using the stylus tip. The device will now restart and display the Verizon Today screen. Snap the back cover back onto the back of the phone. Touch Screen is Not Working
As most tablet PCs ,Phones and Mp3 players are full touchscreen devices, you use your touchscreen for everything you need to do on your Tablet PC. If the touchscreen stops working, you can't get much use out of your Tablet. Touchscreen issues are caused by hardware or software problems, but check with your manufacturer before attempting a DIY repair.
Hardware Issues Damages to the surface of your Tablet PC can cause the touchscreen to malfunction or stop working entirely. For example, putting pressure on the screen, such as placing the Tablet PC in a bag with other heavy items, can cause cracking along the screen. Exposing the screen to water, even in small amounts, can cause the electrical system within the touchscreen to malfunction. If the electrical system malfunctions, the touchscreen stops working properly. b> Screen Sensitivity b> Pressing the touchscreen on your Tablet PC sends a signal to the internal motherboard. The motherboard then transmits to other components, such as the hard drive. The accuracy of the touchscreen depends on the screen's sensitivity. Many Tablet PCs include a program for calibrating the touchscreen. This program may fix minor responsive issues. Even a small amount of dirt or debris can effect how the touchscreen responds. Cleaning your touchscreen with an electronics cleaner or a microfiber cloth may help improve sensitivity. b> Software Issues b> A driver is a software program that interacts between hardware devices and an operating system, Your Tablet PC needs the right drivers for your OS to work correctly. Outdated or missing drivers can cause the touchscreen to work improperly, or not respond at all. Visit the manufacturer's website to find the right drivers for your Tablet PC. b> Repair b> While you can perform some minor repairs yourself, such as re-calibrating the touchscreen sensitivity or installing drivers, only perform a hardware repair if you have a good working knowledge of electronics, specifically Tablet PCs. Before attempting to repair your device, contact your manufacturer. If your Tablet PC has a warranty, completing an unauthorized repair may make you ineligible for claiming that warranty. Hope this helps
b>
Jan 20, 2013 | Visual Land V-Touch Pro (8 GB) MP3 Player
The touchscreen us not working at all, the other buttons work
Hello
Do not put lotion on your hands and do not touch the screen if your hands are wet. Any kind of moisture can affect the way the touchscreen operates. Moisture sometimes slows the response time from the screen to the operating system.
Check for a protective sheet on the screen. If there is some kind of a film or sheet on the touchscreen, the screen is likely not able to react to all of the sensitivities of the touch of a finger as it normally would.
If there is an application open and the touchscreen seems to not be working, simply close the application and retry it. A frozen application can usually be closed by pressing and holding on the circular button located just below the touchscreen.
Completely reset the phone by holding the "Home" button and the "Reset" button for a full 10 seconds until the phone resets.
THANK YOU FOR VISITING FIXYA
Mar 07, 2011 | Cell Phones
LG touch phone. Touch screen keeps blanking out, it that the touch screen will not work. Screen shows everything but the touch of the screen does not work. I have took out the battery and replaced it. It...
when phone is idle, the auto lock feature locks out the screen. you can set the time when lock engages or disable completely. To unlock, press top right corner button or use touchscreen options by sliding finger up from bottom to top or press unlock button on bottom of touchscreen
Feb 19, 2011 | AT&T Cell Phones
HTC Touch Pro T7272, touchscreen is dead
try hard reset. but do an back up as it'll wipe out everything from phone.
Aug 24, 2009 | Cell Phones
DS Lite bottom touchscreen seems "stuck"
i think you should either get a new ds or tap the touch screen hard. if tapping the touch sreen harder does not work then that means it is time for a new ds.
Jan 18, 2009 | Nintendo DS Lite Console
The touch screen on g900 sonyericson no longer works help please The touchscreen on my G900 also doesn;t work any more
SOLUTIONS....
YOU KNOW WHAT GUYS, I HAVE THE SAME PROBLEM. I WENT TO THE REPAIR SHOP IN SONYERICSSON AND THEY TOLD ME THAT THIS IS THE MAIN SICKNESS OF TOUCHSCREEN PHONE. IF YOUR PLANNING TO BUY TOUCHSCREEN PHONES BE SURE TO TAKE CARE OF IT EXTREMELY...
THE BEST SOLUTION IS THAT , IF YOU STILL HAVE THE WARRANTY CARD OF YOUR PHONE BETTER GIVE THE PHONE BACK TO THE MANUFACTURER BECAUSE THIS IS A UNIT ERROR...
Dec 16, 2008 | Sony Ericsson G900 Smartphone
Touch screen
try to calibrate the touchscreen. if it still does not work you need a new touchscreen.
www.fixphonenow.com can replace the touchscreen for $55.
thanks,
Oct 15, 2008 | Cingular Wireless 8125 Smartphone
Nintendo DS touchscreen problem
try calibrating the touchscreen....
Jan 08, 2008 | Nintendo DS Console
Acer Aspire Z5600 PC Desktop Logo
212 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
