Question about Car Audio & Video
Rear speakers and sub wont play in 2007 peterbilt 379
  • LOU Jan 20, 2014
    Hi benny gipson, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • 15 Answers
SOURCE: sound
first check the settings of woofer or dvd player (keep in 5.1 mode and RAW)
mail me clearly about the problem,
kanny_amancha@yahoo.com
www.kanny-sounds.blogspot.com
Posted on Jan 27, 2009
  • 19 Answers
SOURCE: where is turn signal flasher on 2000 peterbilt
the flasher is behind the left dash panel behind ur pyrometer
Posted on Aug 15, 2010
HansPP
  • 2510 Answers
SOURCE: Have a 2004 Peterbilt 379, looking for Specs for
Have a look at this site, it gives a comprehensive description for setting headlights:-
http://www.300cforums.com/forums/lighting-discussion/49644-aiming-headlights.html
However, headlight adjustment must conform to the relevant road ordinances and laws of the place of vehicle registration. For your own peace of mind and to comply with legal requirements I suggest that you take the vehicle to a registered center and have the lights set to the standards set by law.
Posted on Mar 04, 2011
  • 5546 Answers
SOURCE: Have a 2004 Peterbilt 379, headlight setting is
Yes, if you are running over- the- road just stop in a State that has vehicle inspections and they can set the lights to their specs. In those States that have an inspection setting the headlight aim is part of the job.
Next method, park your unit about 20 feet from a garage door or the side of a building or carwash. Use some tape or pencil and make 2 crosses. The passenger side is allowed to be high and slightly to the right. A correctly aimed right headlight will focus on the curb or lane marker with the right headlight spot-on the lane marker. This will mean you will be safely within your lane on the right side of your truck as long as the headlight hits the lane marker.
For the left light it is suppose to be almost straight ahead and not tipped out to oncoming traffic. In some States the left light is turned slightly towards the center of your truck. You can check against the crosses you put on the surface of the building and watch the beams move as you adjust the lights. Use some chalk to mark where the tires were so you can get into the same spot.
I had to do some Vehicle Inspections in Texas years ago. I want to say the headlights were suppose to be 42" high at 20 feet, but you have a Peterbuilt. And now some of the cars are barely 48" high.
Testimonial: "Thanks"
  • 9771 Answers
SOURCE: Air valve leaking air thru it when u release
If it's the same air valve that releases the parking brake then replace it so the brakes won't drag because of low air pressure. Air is APPLIED to release the brake so if the system air pressure starts to go low the parking brake will start to apply. This will eventually cause the brake drum to overheat and possibly start a tire fire.
Posted on Jan 14, 2014
What's wrong with gauges on cluster of 2007 peterbilt 379
I have no idea because you fail to mention what the symptoms are.
Nov 09, 2017 | Cars & Trucks
How do i find where the short is in my 379 peterbilt between door lock and dash lites?
Hi you have a short or break in the wiring its usually were the hinge movement operates that the wiring loom goes through.
Jan 08, 2016 | Peterbilt 379 1987-2007 ProTec Grille...
Where is the flasher relay on a 2007 379 Peterbilt
usually under the dash in the fuse block .
Sep 14, 2015 | Cars & Trucks
Where is bunk a/c expansion valve on 2007 peterbilt 379
It is on the passenger side, under the bunk, next to the evaporator. These are somewhat difficult to get to as you will stand on your head to get to them.
Jul 13, 2014 | Vehicle Parts & Accessories
Ac not working 2005 peterbilt 379
Pull the fuse box off of the piller and look behind it there is corrosion o the relays I bet . FYI
Nov 19, 2013 | 2006 Dodge Ram 3500 Truck
Fuse panel diagram for 99 Peterbilt 379
You posted this question in FixYa's Digital Camera area. Please repost in an appropriate area so the proper experts can see it and give you an answer.
Jun 13, 2012 | Cameras
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
