Question about Acer Aspire Z5600 PC Desktop
Touchscreen not working
The touch screen has always worked before, well... It happened once, I re-installed the windows and did restart. It worked. Now, I don't want to re-install the windows because I got some personal - important things, what can I do?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
you can save all your personal data and re-install the O.S. again, or try to go to the computer properties and check if the touch screen drivers are there , if not you need to install it.
Posted on Nov 25, 2013
I have an ASUS laptop with Windows 10 and my touchscreen has stopped working. I reloaded windows as I found the HDI driver for the touchscreen was ghosted-no luck. Still no driver for the touchscreen
device manager does not uninstall programs
you have to go to control panel select programs , select uninstall and then highlight program to be uninstalled the click on uninstall.
try to find the touch screen and then click on properties , find the driver tab and click on upgrade driver .
you could always go google and type in --user manual for asus touchscreen laptop--- and down load the pdf version
what you want may be included in the manual
Dec 29, 2016 | ASUS Computers & Internet
Touchscreen stopped working
1. turn off computer, wait 15 secs and then re-boot
2. Check for and install any Windows updates
3. Configure the touch display to identify your screen as a touch screen.
4. Search for and then select Tablet PC Settings from the results list.
This will vary with your model and Windows version. You are looking for SetUp of your touchscreen and Settings
Nov 26, 2015 | Gateway Computers & Internet
Touch screen will not work on laptop
Check all drivers are loaded for the touchscreen interface, if they are remove them and re-install.
If that doesn't solve your issue I would check the cable that connects the touchscreen and that the touchscreen is fitted correctly.
Mar 19, 2014 | HP HEWLETT-PACKARD ENVY TouchSmart...
Touch screen not working
Touchscreen computers and handheld devices are the newest wave of technological gadgets as of 2010.
While these devices function impressively, they can malfunction just like any other technical device.
Troubleshooting the touchscreen is simple and often will correct any issues.
Identify how the screen is behaving.
A touchscreen will malfunction in one of two areas--sensitivity or position.
If you touch the screen and the cursor is not centered on your finger, this is a position error and requires recalibration of the screen.
If you touch the screen and it does not register your touch without pressing hard, this is a sensitivity error.
If you touch the screen and nothing happens, this can be a sensitivity error or a malfunctioning screen.
Calibrate the screen.
For all main errors, calibrating the screen will correct the issue.
Every device has a different method of calibration but can usually be found under a "Tools" or "Diagnostics" menu option.
Reload the device.
For handheld devices, remove the battery and let the device rest for no less than five minutes.
For computer or computer system devices, power down the device, disconnect the touchscreen device from the computer and remove any power cords to it.
Allow the device to rest for five minutes.
Reattach the device or reinstall the battery and power up the device.
If issues persist, reload the software for the device.
For handheld devices, do a full wipe of the device and return it to factory specifications.
For add-on devices to a computer or computer system, uninstall the device and reinstall the drivers.
If reloading, registering or calibrating the device does not work, consult the manufacturer for possible warranty replacement options.
or if you are runnung windows 7
Connect the screen to a computer running Windows 7 using the supplied USB cable and a cable for the video signal.
Ensure the cables are properly connected.
If the screen does not respond to touch, please visit our knowledge base article USB detection problems in Windows.
or you might use the system to restore to resolve the problem
You can use the System Configuration utility to perform a system restore.There are three possible restore points:System checkpoints that Windows schedules
Manual restore points that you specify with the System Configuration utility
Installation restore points that occur before you install a program or a service
you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.
This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.Repeat steps 1 through 8 until you fix your configuration issue.
If the touch screen works erratically, please visit our knowledge base article Calibrating the touch screen in Windows
Mar 08, 2014 | Lenovo Computers & Internet
Dell studio one touch screen is not working
DO NOT install Dell Touchscreen driver as it does not work with MS Touch Pack
Update Windows
Install Dell Fingertapps Touch Zone.
Install Dell Cozi YouPaint, Dell TouchCam, TouchCam Update
Install MS Touch Pack. Find here - http://forum.tabletpcreview.com/showthread.php?p=179262
Install MS XNA 3.0
Install MS Bing Virtual Maps 3D
Install Next Window Touch Screen Driver 1.3.2.5. Find here -http://www.nextwindow.com/nextwindow_support/download_confirm.html
Optional - Uninstall MS XNA 3.0, Install MS XNA 3.1
Sep 02, 2013 | Dell Computers & Internet
Samsung SGH A897 mobile touch screen not responding to touch Incoming calls are operable
Did you try restarting the phone...??? If it didn't work try resetting everything. And even if that is not working then I would say it's probably a hardware error. You would have replace your touch panel. Could cost you a little bit. Rush to nearest samsung service center and get it done.
And also bear to put a screen gaurd always. I would not advise you to use touchscreen phones without screen gaurds.
Good luck
Jun 23, 2011 | Cell Phones
How can you get the touch screen or pen work on the dell latitude xt2? I can't figure out how to get the buttons to work or the screen to rotate.
What OS are you using ? Windows Vista or Windows 7 ?
In order to get the buttons and touchscreen working, you need to install the proper drivers.
Go to http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_XT2&os=WLH&osl=en&catid=&impid=
Select your operating system
and download the following drivers and install them in the following order :
  1. System Utilities : - > Dell Utility : System Software
  2. ControlPoint -> Dell - Application : ControlPoint System Manager
  3. Input device drivers - > Ntrig Application
Restart your computer. Run Windows Update Restart your computer Everything should work.
Feb 01, 2011 | Dell Latitude XT2 Tablet PC
My touchscreen is not working after i instal windows 7
Hi.
Based on the information you have provided, it seems that the issue is due to the Driver for the Touchscreen sensors.
As you have changed the Operating System, it is required to install the Touchscreen Device Driver for the Windows 7 Operating System.
Once the Driver is installed, the Touchscreen Device should work normally.
Please let me know the exact Model # of the Computer, so that I can provide you the link to download the Touchscreen Driver.
Hope this helps.
Please feel free to contact for further information and assistance.
Oct 23, 2010 | Computers & Internet
My Garmin nuvi 200w behaves erratically until it has been turned on and warmed up for around 10 minutes. Before this time the touch screen may not work or when pressed respond as if pressed at another...
First make sure the batteries are good and at normal room temperature.
Second, based on your question your touch screen is bad or needs calibrating....
Then
Try to recalibrate your screen:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
The screen on my Garmin Nuvi 200W won't respond. I tried the recalibration but the screen doesn't respond when I touch the dot. I also tried a hard reset and that didn't help either. Help please!
There is more than one calibration procedure, but for the 200 it is:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 follow the steps below:
If this doesn't work you have two choices
Buy a new one
Or
Send your in for repair. Go here for this option
http://www8.garmin.com/support/outofwarranty.html
Aug 23, 2009 | Garmin nuvi 200W GPS Receiver
Acer Aspire Z5600 PC Desktop Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
