I have a lg50pq30 TV. All of a sudden it has a line down left side of picture.
    Master:
  • 688 Answers
Most likely one of the Buffer PCBs on the left side, the part numbers vary; you will find those part#s , price & availability listed in the following web site: http://www.shopjimmy.com/catalogsearch/result/?q=LG+50PQ30-UA&restrictBy[master+part+type]=Buffer+Board&restrictBy[known+models]=LG+50PQ30-UA
Posted on Nov 30, 2013
SOURCE: green line down the left side
try changing the resolution to 720. You'll need to do this from either your cable box or your direct tv receiver and not from the tv. Hope this helps. Let me know how you make out. don_mendez@hotmail.com
Posted on Jan 19, 2009
  • 111 Answers
SOURCE: Hi, our Vizio LED TV has a green line running down
logic module
Posted on Feb 03, 2010
  • 375 Answers
SOURCE: My new 43" samsung 4+
This doesn't sound like an easy fault which you will be able to fix yourself, I would send the unit back for a replacement.
Hope this helps
Posted on May 09, 2011
  • 302 Answers
SOURCE: 52" Sony Bravia TV has a thin Blue line down left
A line on an LCD screen can be cause by the screen itself going bad or the T-con board. The T-con board the attached to the screen on the backside and covered by a heatshield. If you get teh part number from it you can find it online from one of the many retails that might have it. Like www.interliquidparts.com
Posted on Jun 06, 2011
SD Tech
  • 14553 Answers
SOURCE: dark line down the middle of my flat screen tv
Most LCD and PLASMA sets use two boards (some combine them into one board) that drive the Display Panel (the entire front screen unit) so I would suspect one of yours is bad.
The other unpleasant possible cause is where the left board is connected to the Display Panel (entire front screen unit) you have a problem inside that Display Panel and that is fatal as there is no way to get INSIDE the panel---it can cause both lines and a dark picture on one side of the screen.
Posted on May 26, 2012
Lg50pq30 wen turing on it blinks 1red, two blue , then back to red
please look at this post ignore, the picture, its fixy stuck. look at the post page it might help as lg never released the blink code for this tv. http://www.fixya.com/support/t9984080-lg_plasma_50pq30_will_not
Feb 01, 2018 | Televison & Video
VIZIO 42 CLASS RAZOR LED SMART TV M420KD picture has lots of green ghosting and thin white vertical line through left side of screen also
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Jan 24, 2014 | Vizio Televison & Video
Problems with sky tv
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 12, 2017 | Televison & Video
Dark line down the middle of my flat screen tv
May 25, 2012 | Sylvania Televison & Video
On the screen I see on the sides of every object a shadow, it,s green on the left side and red on the right side accompanied by some little horizontal red stripes. It started doing it all of a sudden a...
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Hitachi 65TWX20B 65" Rear Projection...
Mitsubishi tv model wd 73727 and how to take tv apart to clean marrow
my mitsubishi 73" set is 4+ years old. all of a sudden the color is all wrong. after a couple of minutes of clear picture the colors change--blue is green and red is yellow. a little while later everything has a red tint to it and there is a line going down the center of the screen. to the left the picture is still relatively sharp, but the right hand side is terrible. I'm hoping this is just the lamp.
Rick
Woodland Hills, Cal.
Apr 12, 2009 | Televison & Video
Green line problem
I had the same problem when we hooked up an hd satellite box. It's a simple solution using the Philips remote that came with your tv. The dial in the center of the remote with up down left right control will move the picture left or right up or down by holding the direction you want to go. Make sure to stand in front of tv.
Oct 28, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Magic focus grid not straight.
i'm no expert by any means; but I wonder if it could be as simple as the reflective screening on the inside comming loose. I have a 65" and I took it apart to clean it. The reflective screening looked to me like it could be a weak point. Just a thought.
Jul 04, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
LG colour TV RI32CZ10RX problem with picture
My LG tv has suddenly got a problem with the picture. Whilst watching the tv with no problems at all, the picture was suddenly reduced to a thin vertical line down the centre of the screen and an awful smell seemed to come from the tv There is a short ckt in your tv in horl. section. 1 isolate power from horizontal section. 2 check for normal output from power supply. 3 check parts in horl output section a hor.output transistor b diode & cap in h/output trnsformerckt. c check for print. d if all are ok check for eht transformer. e if every thing becomes then reconnect hor output section supply. f put on the set.
Sep 23, 2007 | Televison & Video
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
