Question about Whirlpool Refrigerators
Gs6nbexr 001 - Whirlpool Refrigerators
What processors will are compatible with an hp 3396 motherboard
That motherboard uses the CPU Socket 1155 LGA. Pretty much any processor for that socket should work. (Source: http://browser.primatelabs.com/geekbench2/1112660)
Popular CPUs for this board are:
  1. Intel Core i5-3570
  2. Intel Core i7-377
(Source: http://openbenchmarking.org/linux/motherboard/HP/HP%203396)
Feb 25, 2015 | HP 339661-001 HP PCIx Cage DL760 G2 Mfr...
My whirlpool GS6NBEXR refrigerator ice cube maker leaves slimey, flaky residue at the bottom of my glass. What can I do?
Diana, if I understand you ok, the ice you put in the glass leaves slimy residue. So that slimy stuff has to be in the ice cube. Well remove the the ice maker unit and thoroughly clean this ice holder and throw away the ice cubes in the kitchen sink and see if leaves slimy stuff. As for slimy stuff, while the unit is out, check any leaks etc. BTW any smell?
Jan 06, 2014 | Whirlpool GS6NBEXR Side by Side...
Handling care and how to remove the dull spots on the Whirlpool GS6NBEXR Side by Side Refrigerator door
Clean it first with good kitchen cleaner. I recommend Mr. Muscle kitchen cleaner for the cleaning. (Plastic ok also) Then spray it with endust and wipe it clean. DO NOT spray endust directly onto plastic parts. Metal only. You can spray the rag first then wipe the metal. It should shine up nicely. Has worked for me for over 40 years when restoring used appliances.
Thanks for choosing FixYa.
Kelly
Nov 18, 2010 | Whirlpool GS6NBEXR Side by Side...
Gladiator Gaming case replacement front USB chip?
Hi
Here you go - the whole case will be cheaper than the controls
79.00 for the entire case is the cheapest way to go as they do not sell the control and that is why the number didn't bring anything - it would be 100,00 most likely - so your getting a deal here.
http://www.colordrives.com/black-gladiator-gaming-computer-case-only.html
Here are some more pictures - and the case is sold out here but the pictures are many - so you know what it is - also reading the reviews - I want one of these cases now.
http://www.newegg.com/Product/ImageGallery.aspx?CurImage=11-105-001-S02&SCList=11-105-001-S01%2c11-105-001-S02%2c11-105-001-S03%2c11-105-001-S04%2c11-105-001-S05%2c11-105-001-S06%2c11-105-001-S07%2c11-105-001-S08%2c11-105-001-S09%2c11-105-001-S10%2c11-105-001-S11%2c11-105-001-S12&S7ImageFlag=2&Item=N82E16811105001&Depa=0&WaterMark=1&Description=ATOP%20Gladiator%20AT878BK-C%20Black%20SGCC%20Steel%20ATX%20Mid%20Tower%20Computer%20Case
Apr 02, 2010 | A-Top AT878-BK Black Gladiator Gaming Case...
Stopped making ice eventhough everything is in its normal operating state.
Things to check first:
-is there water going into the icemaker (does your fridge produce water from the cold water spout ?)
-if not, then check the water line going to it
-if so then time to consider replacing the ice maker (very easy)
If you've had it a while then I'd replace it (they are easy to replace). Take a look at:
http://www.repairclinic.com/Appliance-Parts?s=t-GS6NBEXR-%3d%3d
(I've ordered from them before - actually an icemaker that is running nicely 2yrs later)
Aug 07, 2009 | Whirlpool GS6NBEXR Side by Side...
Hi, I have HP dv4000 model, Intel Pentium 1.60 GHz processors, Can I upgrade the processor? And what is the maximum upgrade for the processor? Regards, for more details and features...
According to the service manual, these are the processors your notebook will handle:
Part#
Intel Pentium M 2.13-GHz 396700-001
Intel Pentium M 2.00-GHz 396699-001
Intel Pentium M 1.86-GHz 393327-001
Intel Pentium M 1.73-GHz 383474-001
Intel Pentium M 1.60-GHz 383473-001 and 396698-001
Intel Celeron M 1.50-GHz 383471-001
Intel Celeron M 1.40-GHz 396697-001
Intel Celeron M 1.30-GHz 389036-001
So it looks like the Pentium 2.13GHZ is the top one.
Here is a link to the service manual for reference: This is on page 5-24.
Thanks fro using Fixya. A Fixya rating would be most appreciated.
Jan 26, 2009 | HP Pavilion dv4000 Notebook
Ice dispenser motor not working
try removing the ice bin from unit, try using dispensor now, can you hear it turning now??? if so empty your ice bucket possible frozen water on bottom of bucket preventing auger from turning
Feb 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Leak water on floor once a month
This likely a defrost cycle issue. Your drain tube is likely clogged. Get under there and clean it, clean your condenser while you're at it. Cut down door openings, open liquid in the fridge.
Jan 03, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
