Question about Toys
Andis superliner the motor in my andis superliner keeps vibrating, not running smoothly as it should with and with out the blade attached. is there any thing i can do to fix this or do i have to replace the whole machine?
    Problem Solver:
  • 5 Answers
Try some oil and see if that makes it go any smoother, or see if you can find an indivisual part
Posted on Nov 24, 2013
Testimonial: "wow that was fast...its not the blade thats the problem its the actual motor. it makes an unpleasant vibrating sound even with the blade off. im hoping i can possibly fix this because the trimmer is fairly new and would hate to spend money to replace it"
I wanna know how to fix Andis superliner clippers.mine just simply dont cut anymore??someone please help
If the clippers stopped cutting, they are probably clogged with hair on the inside of the clippers. I had two pairs of clippers where this happened. I took them to be serviced at a beauty supply store and they cleaned the hair from the inside of both pairs of clippers for me and they now work just fine.
Jul 12, 2014 | Andis SuperLiner Trimmer 04810
How do i open the motor to a black&decker 71&2 inch band saw ? my saw has started to make a lot more noise when runing
There are many reasons why band saw make noise. Here's are some "few checks" to do
1. Run the band saw without blade.
2. Run with a different blade.
3. Run the motor alone.
4. Check the bearings.
Another thing; incorrect speeds and feeds can cause noise and vibration.
Regarding about opening the motor, I can't help you with that. Try to check any other band saw motor manual reference.
I have Trajan 7x12 band saw, no vibration or noisy at all, I use Haltbar blade from sawblade.com
Jun 15, 2014 | Black & Decker Saws
My clipper smoked and now it wont run at all
Sounds like your motor went out. You might as well buy new clippers for the price to fix them. One thing that causes that is when you spray your coolant to not hold your clippers blade up. Keep them blade down. The coolant can run into your clippers and burn them up. You only want to use grease inside your clippers.
Jan 21, 2013 | Andis Agc Super 2-speed Clipper...
My clippers are frozen. They don't vibrate but the motor turns on.
Hi, How long have you been using the clippers? In my experience they can get clogged with hair quite quickly depending on the animal. I'd recommend removing the blade to better get at the hair stuck between the blades. Once the blade is off lubricate the appropriate parts following the guide in your operating manual. It's best to do this soon before the motor burns out. If you feel that the blades are too clogged, it's easy to buy a replacement blade for around 1/3 the price of a new clipper set.
Mar 12, 2011 | Andis Super Deluxe Pet Clipper Kit
Hi; i just bought a andis improved master clipper and the blades stop working right after i tried to adjust the voltage ,i can hear the motor running, but the blades don't move, please help me! thanks!
I just had this same problem. My andis Masters where working and they started making a loud sound and the blades stopped working. The Problem was there wasn't enough power. I used a screw driver and turn the power adjusting screw to the Right with a flat head screw driver.the sound got louder but after I keep turn it the blades started moving again and the blades got quiet again. Tada a Quick Fix.
Dec 26, 2010 | Andis Improved Master Hair Trimmer
Kelvinator Single Door Hardening Cabinet Flash Freezer fan
If the fan motor shaft is smooth with 1 flat spot the hub on the blade probably has a hex set screw that can be tightned with an allen wrench. If the fan motor shaft is threaded there should be a nut holding the blade on. Also yur motor bearings could be going bad causing vibration which damages the fan blade.
Sep 22, 2009 | Electrolux Freezer Kelvinator Single Door...
Hi I just got my heads redid on my 96ford taurus cause I blew a head gasket car had gotten to hot. Now dat its fixed my car runs fine but it has a vibration when im in park or come to a complete stop. It...
I would check your motor mounts, if your engine is running smooth, the only thing keeping you from feeling engine vibrations are your motor mounts.
Aug 05, 2009 | 1996 Ford Taurus
My GTO model Andis clippers blade is not properly aligning..how do I adjust it? I BOUGHT NEW BLADES FOR MY ANDIS LINER BUT IT STILL DOES NOT CUT SMOOTH AND SHARP. WHAT IS THE PROBLEM.
YOU HAVE TO OPEN DEM UP. TAKE OUT THE SCREWS ON THE TOP DEN TAKE OFF THE BLADE. ONCE YOU HAVE THE BLADE OUT THERE ARE TWO MORE LIL SCREWS UNSCREW THOSE (NOT ALL THE WAY OFF, JUST ENOUGH SO THAT THE BLADE WILL MOVE) ADJUST THE BLADE HOWEVER YOU WANT. IF YOU WANT IT CLOSE FOR A MORE DETAILED CLOSE LINE (NOT TO CLOSE AS DEY WILL CUT YOUR OR THE CLIENTS SKIN). YOU MUST TRY THEM OUT ON YOURSELF SEE IF THEY ARE TOO SHARP, IF THEY ARE TAKE THEM OFF AND ADJUST THEM AGAIN. EASIEST THING TOO DO IS USE A MIRROR, HOLD THE BLADE AGAINST THE MIRROR DEN MOVE IT AT AN 45 ANGLE DEN TIGHTEN THE SCREWS DER (BARBER TRICK).
Jan 22, 2009 | Andis T-Outliner Hair Trimmer
I have a andis outliner 2 and it was working fine then i took the blade off to clean it then whten i put it back togather it wont cut like befor, blade does not vibrate like before.
The blade has not been lined up correctly when it was put back on. For complete instructions on how to replace the blade please visit the Andis website at www.andis.com. Click on the service tab and then use and care. Scroll down to the model you have and click once more. If you need any additional help please call the Andis customer service department at 1-800-558-9441.
Thank you for choosing Andis.
Dec 11, 2008 | Andis Go 04630 Outliner Beard Trimmer
My andis clippers are experiencing blade not moving. it is not cutting.
Push top blade to right side right with finger,then turn clipper on and dip  into 3 in one oil,blades only,let clipper run for one minute,clean excess oil off blades,if clipper still want vibrate,take blades off the clipper and clean them,then place back on clipper, I've had this problem many times,i also repair clippers,adjust blades,etc...
Oct 09, 2008 | Andis 01690 Hair Trimmer
Toys Logo
71 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
