Question about Pool & Spa
Sta rite heater code A20 SFI 828 r8 - Pool & Spa
    Champion:
  • 305 Answers
This is not an error code
Posted on Feb 13, 2014
4 Suggested Answers
  • 128 Answers
SOURCE: Sta-Rite Problem; Error codes R8, Won't stay on.
Its the top membrane where the control buttons are. The circuit board plugs in to it.
Posted on Aug 23, 2009
jharwell668
  • 640 Answers
SOURCE: what does R8 code mean on sta rite pool heater
These pool heaters have a very detailed and specific troubleshooting manual that will probably be the most helpful thing for you. They ask very specific questions about what appears on your heater and you will need to be looking at it to troubleshoot. Try walking through the troubleshooting guide below.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Posted on Aug 16, 2010
jharwell668
  • 640 Answers
SOURCE: shows r 5 code when power is turned on. sta-rite
The R5 is a sequence code in the boot up sequence where your error is occuring. There is nothing in the users manual for these pool heaters that explains this error. Your best bet, unfortunately, is going to be to call Sta Rite. Here is their customer service number: 1-800-831-7133
Posted on Aug 19, 2010
I reset the heater by shutting it off for about
sounds like temp sensor is bad
Sep 27, 2014 | Pool & Spa
What does R8 code mean on sta rite pool heater
Jun 24, 2010 | Sta Rite SR400LP Max E Therm Pool Spa...
Heater isn't starting...how do I reset? Error
The users manual for these pool heaters has a very detailed troubleshooting guide. I would start there. A pdf version is below.
Jun 05, 2010 | Sta Rite Sr200lp Max E Therm Pool & Spa...
Shows r 5 code when power is turned on. sta-rite
May 08, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
I have two error codes: 180/R9 anlong with 128/R8 HELP!
Error pertains to stack flue sensor setting.
There are two modes for low level programming and default is a (0) Zero but for outdoor spas this must be reset to a one ( 1 )
Just hold the off button down for 30 seconds let up, press down again, use arrow buttons on key pad to set from 0 to 1...press off again....play with it and see for yourself...I don't now why Sta-rite buries this information and makes us guess.
Again, on mine, this all pertains to the Stack Flue Sensor setting.... you can look at your heater and see what they look like...outside toward bottom the SF must be a 1 and not Zero or you get the quick flash 128-R8 notice...also, the Stack flue senor is finicky and connections must be good...use steal wool to re-seat but be careful as connector break off easily thus requiring a new stack flue sensor...
I accidentally discovered this when I turned the board upside down and spotted the LED red light on indicating a fault with the SFS**
I wish some one would tell us how to by-pass the stack flue sensor to make the heater work.
Good luck...hopefully the power button is close by and your board is working....
Jan 21, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Error AD0 SF0 180 r8
the stack flue sensor is bad make sure you order the identical part since is two model for thre same heater
Oct 09, 2009 | Sta Rite Maxi Therm 400k Btu Propane...
R8 Error
dont know what heater yuo got may be a board or temp sensor also post if automatic control
Sep 13, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Aug 21, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Jun 14, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Pool & Spa Logo
91 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
